Hello everyone. I've just gotten my grubby mitts on a Harmony 700 and would like to whip it into use with XBMC. I would appreciate it immensely if you could give me your IR receiver recommendations
TIA
Any cheap MCE remote and USB dongle should work.
Hi there, thanks for the reply
. I assume you mean MCE remote OR USB dongle?
I use Flirc with my harmony (flirc.tv)
(2012-05-12, 11:50)pseudo7 Wrote: [ -> ]I use Flirc with my harmony (flirc.tv)
I leaning towards Flirc by a smidgeon..I assume it's still registered on the Harmony as an MCE?
(2012-05-12, 11:46)matt77303 Wrote: [ -> ]I used the receiver from this
http://www.maplin.co.uk/media-centre-ir-remote-385365
Matt
Hey Matt,
Nice to see Maplin still charges through the nose
Quote:I leaning towards Flirc by a smidgeon..I assume it's still registered on the Harmony as an MCE?
No. MCE (and other Microsoft remotes) are the only ones it doesn't work with due to none standard frequencies.
I wrote a review which was on the front page for a while:
http://xbmc.org/natethomas/2012/04/15/fl...trol-xbmc/
Shame Flirc is o/s at the moment.
[/quote]
Hey Matt,
[/quote]
too true, but from memory it was cheaper when i bought it, and i had it there and then.
Matt
+1 for MCE receivers. They show up as keyboards to the computer, so they can control any application very easily.
(2012-05-12, 11:13)jander Wrote: [ -> ]Hi there, thanks for the reply . I assume you mean MCE remote OR USB dongle?
Yeah, the receiver from any MCE remote will work. I bought a cheap one from Newegg a while ago just for the receiver, and then programmed my Harmony 650 to control it.
Thanks for all the recommendations. A friend gave me an CiT Media Centre Remote which has an w-01RN. I saw an XMBC wiki stating it should work out of the box, but I've had not luck with it (and the Harmony 700, haven't tried the crappy remote that came with the receiver). Linux does detect it, but that's about it. Should I be spending any more time trying to make it work or just bite the bullet and go for a known-to-work MCE?
I have tried for a long time to get odd ball remotes to work. MCE remotes just work. I would just get one. It will work for years to come.
