2012-05-12, 10:03
2012-05-12, 10:03
2012-05-12, 22:00
For true fullscreen make sure in settings\system\ video "Use full screen window..." is not checked.
If subtitles are showing when you have chosen "none" then they are most likely burned into the video. If that is the case there is nothing you can do about it.
2012-05-13, 10:02
2012-05-14, 00:06
You will probably need to use a scraper that is Chinese friendly. Check out the settings for the various scrapers for language options. If the information retrieved is wrong try to refresh it and make sure it chooses the correct movie. If it is still wrong, you can make your own custom .nfo file for the movie or try a different scraper. See the wiki for that information.
