Good Job Bucha!
Thanks for everithing you doing.
Thanx, the big part was modded and designed by jugger75, so big part of credits to him
is not there for download
here it is inside. try to reinstall repo if you do not get it
Force refresh my repo and you'll be fine, no need to reinstall the repo.
Really, force refresh is something we have since xbmc dharma, so ... Hmmm
i get some errors
16:04:30 T:14876 ERROR: Couldn't load font name: font10_title(Arial-Bold.ttf), trying to substitute arial.ttf
16:04:30 T:14876 ERROR: Couldn't load font name: font12_title(Arial-Bold.ttf), trying to substitute arial.ttf
16:04:30 T:14876 ERROR: Couldn't load font name: font13_title(TidyHand-Bold.ttf), trying to substitute arial.ttf
16:04:30 T:14876 ERROR: Couldn't load font name: font24_title(TidyHand-Bold.ttf), trying to substitute arial.ttf
16:04:30 T:14876 ERROR: Couldn't load font name: font28_title(TidyHand-Bold.ttf), trying to substitute arial.ttf
16:04:30 T:14876 ERROR: Couldn't load font name: font30_title(TidyHand-Bold.ttf), trying to substitute arial.ttf
16:04:30 T:14876 ERROR: Couldn't load font name: font35_title(TidyHand-Bold.ttf), trying to substitute arial.ttf
16:04:30 T:14876 ERROR: Couldn't load font name: font50caps_title(TidyHand-Bold.ttf), trying to substitute arial.ttf
and then crash
(2012-05-17, 16:51)Nimo Wrote: [ -> ]i get some errors
and then crash
Thanks fixed in svn
Some initial bits I've noticed...
The Season view in "TV shows" displays "Stafel", not "Season"
The main menu doesn't seem to use the vintage font properly - it doesn't change for the menu item, and in the sub-menu - only for the item currently selected.
The TV shows in progress doesn't work properly (for me).
But this skin is amazing, a nice breath of fresh air. You should be proud!!
Also - random movies. They seem to be selectable, although not displaying, even when not enabled in the settings. Also, when they're enabled, selecting a movie causes the title (Ramdom movies) to disappear!
Going to start a buglist in the first post, thanx for reporting.
cirrus vintage svn will come to passion? or do i need tortoise continue?
Wow looks great! Always liked the concept, never thought it would get to a releasable state!
I'm gonna try it out
I'm without computer 2 months and look.
I want my computer back, wanna check this skin, looks cute!
