Full Version: Avalon
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41
Avalon a skin from MediaPortal
A project from reazorFX and wileecoyote
Original description of Avalon:
The team that brought you "Maya" is proud to annouce a brand new skin called Avalon!
We have been designing and developing for about one year on a 1920x1080 skin that will offer a clean
and simple layout without compromising the ever growing need for information at a glance.
You will have the choice between several layouts to suit your needs. All configurable from within MP.
(A special thanks to the StreamedMP Team for sharing their code and inspiration)
As you all know from "Maya" we hold on to the concept of making all screens as consistent as possible
for a better user interface experience. (should also enhance the WAF)
ToDo:
-PVR support
-Personalize the widget aera (sort and place)
-Ability to have Music directly go to Playlists.
-Custom menus (go to specific addon or path)
-More views
-Font with accent's
-Audio track LED
-Homemenu fanart whit the new movies like in Nox
Thanks to:
- Many thanks to the XBMC-Nerds: mad-max, don and all the other great guys from xbmc-nerds.
- joostzilla and Team Mediaportal for the great Skin!
- Hitcher for Foundation and Repo support
- Shinu for support, suggestion, ideas, icon and fanart
- vicmanpergar for Spanish translation
- sling for Dutch translation
- ElPolo for French translation
- donabi for Qlock2
Very clean looking.
Out of curiosity how similar is the skinning engine?
great looking lots of info in one screen.
Just this morning I as looking at this skin imaging how cool it would be if it were on XBMC. Are you psychic reazorFX? Big Grin
I sat down with the skin engine idle. I have connected directly to the Foundation (thanks Hitcher) started to code.
very nice skin at first look!!! when it will be available to install?
(2012-05-21, 11:52)joselbcn33 Wrote: [ -> ]very nice skin at first look!!! when it will be available to install?
Btw, It's just the home main menu and you're asking when to install this skin ? Smile boy oh boy ...
@reazorfx: Do the original designers know you are porting this skin to XBMC?
(2012-05-21, 20:14)joostzilla Wrote: [ -> ]@reazorfx: Do the original designers know you are porting this skin to XBMC?
this should be a problem when I porting the skin? Know the makers of the mediastream or focus their skins to Media Portal port? There are any copyright problems?
Greetz
So this was the author of Avalon!
I'll wait what this says about the porting before I go on.
I hope this is not a problem for the guys of mediaportal..
It's all good it's 'GNU General Public License'.
(2012-05-21, 21:04)reazorFX Wrote: [ -> ]So this was the author of Avalon!
I was just teasing a bit Smile We dont have any problem with your port.
XBMC skins have been ported to MediaPortal so often i am glad it happens the other way around for once Smile
(2012-05-20, 21:36)Hitcher Wrote: [ -> ]Very clean looking.
Skinning engine is similar mediaportal is Frodo's work when mediaportal started Frodo used xbmc and built on top of that a lot has changed since but its easy to pick up.
Also see the new skin they are working on called Titan its based around Avalon looks fantastic i actually use Avalon
Titan mediaportal skin
Great news! Big Grin I thought when I read gnu on the Mediaportal-Side. And Hitcher it also say. Wink
I think that is just great to have AVALON on XBMC.
Then I can continue. Notepad on and go.
(2012-05-20, 23:36)Shinu Wrote: [ -> ]Just this morning I as looking at this skin imaging how cool it would be if it were on XBMC. Are you psychic reazorFX? Big Grin
Angel
