(2012-05-21, 04:00)Plaguester Wrote: [ -> ]Post the output of
dmesg | grep -i nvidia
Also post your /etc/X11/xorg.conf file.
[ 14.086651] nvidia: module license 'NVIDIA' taints kernel.
[ 17.960319] input: HDA NVidia Line as /devices/pci0000:00/0000:00:08.0/sound/card0/input6
[ 17.960757] input: HDA NVidia Front Mic as /devices/pci0000:00/0000:00:08.0/sound/card0/input7
[ 17.961112] input: HDA NVidia Rear Mic as /devices/pci0000:00/0000:00:08.0/sound/card0/input8
[ 17.961460] input: HDA NVidia Front Headphone as /devices/pci0000:00/0000:00:08.0/sound/card0/input9
[ 17.961803] input: HDA NVidia Line-Out as /devices/pci0000:00/0000:00:08.0/sound/card0/input10
[ 17.965192] nvidia 0000:00:03.5: PCI INT B -> Link[LPMU] -> GSI 23 (level, low) -> IRQ 23
[ 17.966429] nvidia 0000:03:00.0: PCI INT A -> Link[SGRU] -> GSI 22 (level, low) -> IRQ 22
[ 17.966460] nvidia 0000:03:00.0: setting latency timer to 64
[ 18.008532] NVRM: loading NVIDIA UNIX x86 Kernel Module 302.07 Fri Apr 27 10:55:55 PDT 2012
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig: version 302.07 (
[email protected]) Fri Apr 27 12:00:59 PDT 2012
Section "ServerLayout"
Identifier "Layout0"
Screen 0 "Screen0" 0 0
InputDevice "Keyboard0" "CoreKeyboard"
InputDevice "Mouse0" "CorePointer"
EndSection
Section "Files"
EndSection
Section "InputDevice"
# generated from default
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/psaux"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
EndSection
Identifier "Keyboard0"
Driver "kbd"
EndSection
Section "Monitor"
Identifier "Monitor0"
VendorName "Unknown"
ModelName "Unknown"
HorizSync 28.0 - 33.0
VertRefresh 43.0 - 72.0
Option "DPMS"
EndSection
Section "Device"
Identifier "Device0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
SubSection "Display"
Depth 24
EndSubSection
EndSection
Section "Extensions"
Option "Composite" "Disable"
EndSection
(2012-05-21, 14:43)wiz561 Wrote: [ -> ]I had the same problem, and got it working just fine with a little tweaking. Turns out that the nvidia driver wasn't being loaded, even though I had it installed. I found this out by checking the x11 log file in /var/log.
After that, I did an 'enable restricted driver' command thing from the command line. I forget what it exactly was, but it's the equivalent to the popup you get in the GUI after you install telling you to enable the restricted hardware. After that, things worked.
I checked my X11 logs. The drivers seems to be loading fine.
