The default weather addon frequently reports temperatures that have absolutely nothing to do with reality. Yesterday, it was 381 degrees, for example. I can't find anything to change in the settings, just my city name, which is correct. Any thoughts?
try a different weather provider and post a debug log
Okay, I'll post a debug log later. I am unable to try a different provider, because none of the others will install.
Do you put your htpc in sleep or suspend mode??
I noticed when I do that, every once in a while I get ridiculously high temps reported, but a refresh takes care of it.
It only happens after a sleep/wake cycle
I am on win 7, Eden, Transparency stable
(2012-06-05, 22:30)aptalca Wrote: [ -> ]Do you put your htpc in sleep or suspend mode??
Yep, same here. I'm running Eden on Lubuntu 11.10. I wrote a little script that is executed upon resume from suspend to refresh the weather.
I noticed this on one of my pc's that is not always connected to the internet, I assumed that had something to do with it.....
(2012-06-06, 23:24)ronie Wrote: [ -> ]if any of you could test the latest beta (v0.1.9) and let me know if that fixes the issue.
I removed my script to refresh the weather on system resume, installed 0.1.9 and then tested the suspend/resume cycle a few times and now the temperature doesn't go crazy anymore! Tried the beta on two different systems with equal success. Thanks!
(2012-06-08, 08:38)artrafael Wrote: [ -> ] (2012-06-06, 23:24)ronie Wrote: [ -> ]if any of you could test the latest beta (v0.1.9) and let me know if that fixes the issue.
ok, thanx!
let me know in case the issue ever re-appears.
Upgraded to May release (version 12 alpha 2) and this problem is completely gone.
