Full Version: IMDB scraper feature request: support adult titles
Is it possible to get info of adult titles from IMDB with some scraper?
You can make adult titles searchable if you have a registered account:
IMDB Wrote:Why don't I find adult movies when I perform a search?
The IMDb contains over one million different titles. The aim of the database is to cover as many titles and genres as possible. As a result, some of these titles contain words or expressions that some of our users may find inappropriate and some movies themselves may also fall into this category.
To provide some level of control for those of a sensitive nature some adult titles have been made searchable only by users who are registered with the IMDb and have requested access to this material.
Adult titles cannot be located during a casual search. Only registered users can update their registration profile and activate/deactivate the option to include adult titles in searches and displays.
If you are registered already you can access the adult titles by updating your search preferences and selecting the 'Search Adult Titles/Names' option. Note: The option can only be set from this link.
Here is the page to toggle the adult preference: Search preferences
So if you can enable adult search using the browser should you not be able to enable it with an api too?
I would be extremely grateful if someone can fix a imdb adult scraper! Tongue
EDIT I know there are other scrapers for adult movies but imdb has as a lot of older titles which can be hard/impossible to find on other sites.
Ok, realized you can make your own .nfo with the imdb url in it. Then it gets the data.
It would be nice however to have a scraper able to do this automatically
+1
I'm pretty sure there is an adult scraper available already. Don't know if it uses IMDB though
(2012-06-17, 20:35)nozomi Wrote: [ -> ]Ok, realized you can make your own .nfo with the imdb url in it. Then it gets the data.
I'm using .nfo files to make the scraper find adult titles on imdb. However, even with nfo's, it only works on some titles. Any idea what would cause some not to work, and if there's a solution?
Example of an .nfo file successfully pulling an adult title from imdb:
<movie>
<title>An Act of Confession</title>
</movie>
http://www.imdb.com/title/tt0068169/
Example of it not working:
<movie>
<title>All Night Long</title>
</movie>
http://www.imdb.com/title/tt0197222/
(2016-11-22, 13:00)jessenick Wrote: [ -> ]I'm using .nfo files to make the scraper find adult titles on imdb. However, even with nfo's, it only works on some titles. Any idea what would cause some not to work, and if there's a solution?
<movie>
</movie>
<movie>
</movie>
Same problem here. Having enabled debug log, I can see that it may not be a parsing issue, as kodi/scraper has trouble finding/reading the nfo file itself: DEBUG: VideoInfoScanner: No NFO file found. Using title search for...
It could be a matter of file attributes/security.
(2018-08-09, 09:02)egpetridis Wrote: [ -> ]DEBUG: VideoInfoScanner: No NFO file found
That is a generic error that is attributable to a number of reasons
1. No NFO File
2. NFO File in the wrong location
3. Incorrect contents
to name a few. See Troubleshooting here... https://kodi.wiki/view/NFO_files#Troubleshooting
Also, once you fix the problem with the NFO files, ensure you have the Universal Movie scraper enabled and active for the Source? It is the only way you will scrape from IMDB.
