Just a day ago my pauze button didn't work any more. When I press it the screen stays on pauze but the sounds repeats te last 1 second over and over (stuttering).
Is somebody fromiliar with this problem or knows how to solve this?
The sound repeating is usually a sign that playback has stalled. we'll need to see a debug log to tell what's happening. Enable debug logging from System settings, System, Debugging, and restart XBMC then wait a minute or two for all the startup tasks to finish. Now play your file and press Pause to replicate the problem. When the sound starts repeating immediately close XBMC.
If you're using Windows open the debug log by pressing Windows-R and in the Run dialog type:
"%appdata%\xbmc\xbmc.log"
(including the quotes). Click OK and the log should open in Notepad. Copy and paste the log into
http://pastebin.com/ and post the link it gives you here.
If you're not using Windows see
http://wiki.xbmc.org/index.php?title=Log_File for how to get at the log file.
Allright first thing I'm going to do when I get home.
Thanks already
<log deleted - please don't post logs in the forum>
I hope you will find something in here. I started up xbmc. After that I played a movie 'Zookeeper' I pressed pause. And i'd wait for 5 sec or so and then closed the movie went to the log file uploader and sended it to my email address. I had to cut the log a bit to fit.
Please do not post logs directly in your reply... it creates too much clutter when trying to review the thread. Follow jhsrennie's instructions in post #2 above (emphasis mine):
(2012-07-16, 12:56)jhsrennie Wrote: [ -> ]Copy and paste the log into http://pastebin.com/ and post the link it gives you here.
Also, what you've posted above is not a
debug log (wiki). Again, see jhsrennie's instructions above:
(2012-07-16, 12:56)jhsrennie Wrote: [ -> ]Enable debug logging from System settings, System, Debugging, and restart XBMC then wait a minute or two for all the startup tasks to finish. Now play your file and press Pause to replicate the problem. When the sound starts repeating immediately close XBMC.
Be sure and post the entire debug log, not just a snippet.
Looking at your posted log, it appears you disabled debugging instead of enabling it? Thus, nothing useful for diagnosing your problem was captured in the log.
20:28:23 T:2903122624 NOTICE: Disabled debug logging due to GUI setting. Level 0.
20:28:23 T:2903122624 NOTICE: Log level changed to 0
Once again, to enable debug logging: System > Settings > System > Debugging > Enable debug logging (click on the radio button to illuminate it). Hit Escape repeatedly until you are returned to the main menu and follow these instructions previously posted by jhsrennie:
Quote: restart XBMC then wait a minute or two for all the startup tasks to finish. Now play your file and press Pause to replicate the problem. When the sound starts repeating immediately close XBMC.
Upload your new debug log to
www.pastebin.com and post a link here.
I can see playback starting at 20:28:36 and ending at 20:28:42. Presumably you pressed the space bar in between, but without debugging enabled it's impossible to tell what's going on when you press the space bar.
Is this the correct log file?
Is somebody looking @ the log? Can somebody update me?
