2014-08-28, 13:38
You may have installed the launcher as shell. In this mode explorer is not loaded unless you specify the option 'Start Windows Explorer when xbmc is closed'. The launcher can be installed as shell if it is a dedicated htpc and you want xbmc to start directly without booting to desktop. If you want to view the desktop just keep explorer as shell.
(2014-08-28, 04:44)alexp4re Wrote: [ -> ](2014-08-27, 16:40)baijuxavior Wrote: [ -> ](2014-08-27, 08:50)alexp4re Wrote: [ -> ]thank you baijuxavior. omg. i just discovered this great app. i've been lookin for solution or something like this for awhile. will name my first born after you.
i have just 1 question. i have mine set to delay at 30 seconds. why is that while i'm scrolling down on chrome browser or typing this message to replay to you & i know it hasn't hit 30 seconds(maybe at 5 seconds), but it focus back to xbmc. the delay should start after the last key press right? but its not. its kinda annoying. what am i doing wrong? please advise. thanks.
win 7 x64, xbmc 13.2, aeon mq5
The delay is checked constantly, so when you had opened chrome the delay count may have reached 25 seconds and it will focus after 5 seconds. If xbmc focuses constantly then definitely there is some problem with the delay time handling. Check with another value. Are you using the GUI to set values? You can add chrome to external apps list and enable the option to disable focus when it is running.
baijuxavior - after a restart of my computer, i lost all desktop functions. just blank black screens. my only option was to open task manager. i even kill xbmclauncher process and nothing happen. even with a restart of windows in safe mode to try to do a system restore. a popped up window error of xbmc GUI; still no desktop functions, but just black blank screens. at this point i was getting very worried that i had to reformat my computer. good news, i was able to pop in a windows disk to do a computer repair & do a system restore this way. can you give me some insights of what happen. i would like to use your app. thanks.
win 7 x64, xbmc 13.2 gotham, aeon MQ5
