I use the iHeart radio app on my iPhone or iPad and airplay it to my XBMC boxes to get local station content on my XBMC boxes...
they seem to change their stream url's often enough to break things so I just use the legit way and airplay...
(2012-08-03, 02:51)jz1276 Wrote: [ -> ] (2012-08-02, 07:27)artrafael Wrote: [ -> ]For the second station, try: http://64.37.241.111/mml/wemp.stream/playlist.m3u8
Thanks but it doesnt work. Cant believe there isnt a plugin or addon to play local radio stations.
Odd... it's working for me (listening to it right now). I'm also running Linux (Ubuntu 12.04 to be exact). Did you place the URL inside an .strm file? You may want to enable XBMC debugging, launch your station and, if it fails to play, check the
debug log (wiki) to see why it failed to play.
As far as an add-on to play streaming radio stations, many of these stations intentionally make it very difficult to listen to content unless you come in via a web browser or one of their approval apps for smartphones or tablets. After all, they want you to see their ads or station promos and using a "backdoor" to access their content isn't to their or their advertisers' advantage. As nokdim mentioned above, they frequently change their URLs to keep unofficial apps from continuing to access their content.
There are locals stations that make their content more readily accessible. For example, with the NPR add-on, you can listen to approximately 50 New York state public radio stations in XBMC.
Have you checked out Icecast or Shoutcast to see if these stations are available there?
A quick search on youtube looking for specifically "iheart radio xbmc" comes up with a short tutorial showing a work around for streaming all of their channels.
Perhaps you share the url?
Here is the Youtube link that shows you how to stream iHeart radio stations on XBMC.
Iheart Radio via XBMC
Simple and includes all of the iHeart stations, even the national "iHeart" ones.
