hi tried several add ons none of them will display locations or i ger script error
its as iff its not connecting online
any help please
If you have KitKat, it will not let Kodi write to the settings file where your locations are stored. I had to use es file explorer (which has root access) to edit the file myself.
The only thing is, you have to know what your location id is. For instance, in yahoo weather, the location id for selbyville delaware is 2490638. It is a long trip to that settings file
The path is android/org.xbmc.kodi/files/kodi/userdata/addon_data/weather.yahoo/settings.xml
If you have Kodi on you PC, you can get you location ID number from the settings file there, then edit your android file. Looks like this.
<settings>
<setting id="Location 1" value="Selbyville (US)" />
<setting id="Location 1id" value="2490638" />
<setting id="Location 2" value="Costa Mesa (US)" />
<setting id="Location 2id"value="2385447" />
<setting id="Location 3" value="" />
<setting id="Location 3id" value="" /.
</settings>
that is what your file should look like except with your location and id number. as you see, I only set 2 locations...
