Full Version: Supert tv heeeeelp!
You've probably seen me gloating, and I think that the script has become more mature and can be released to the public now.
SuperTV is the designated successor to the rtmpGUI plugin for XBMC, with a fancy EPG. It now reads source lists from other plugins, too.
The idea behind was to give the same experience you'd have with a Free-to-Air receiver in a given country, which I think has been accomplished for the countries in the list. In the rtmpGUI list you'll find lots and lots of international channels that are not listed in the country lists, and there is blackoutworm's list as well (EPG for it is planned for v1.1, as LiveTV's EPG has to be adapted), which comes with lots of always up-to-date sports streams.
Everything else is explained on the Homepage.
I'll have to remind you that in this version with the full EPG, it is still somewhat experimental. However, I've implemented parts of the EPG into the old rtmpGUI plugin as rtmpGUI+.
Got error when installing it on both Ubuntu and iPhone 4s.
Error "Add-on does not have correct structure..."
(2012-03-12, 08:19)dtsexpert Wrote: [ -> ]Got error when installing it on both Ubuntu and iPhone 4s.
I'm working on that.
same problem here - same message
XBMC eden RC2
Windows 7 64bit
I've updated the zip, should work fine now.
Getting script failed message Sad
(2012-03-12, 09:52)angelworld Wrote: [ -> ]Getting script failed message Sad
Could you post the logs?
No more error message. After installation, the the plugin shows under Program, click on it, get error "script failed: SuperTV"
Thanks,
(2012-03-12, 09:59)HansMayer Wrote: [ -> ]
Er sorry I am still new at this...trying to figure how to post log.....
http://wiki.xbmc.org/index.php?title=Log_file
But try the new 1.0.1, it may work for you.
My log file:
01:14:49 T:140220033353472 NOTICE: -->Python Interpreter Initialized<--
01:14:49 T:140220033353472 ERROR: Error Type: <type 'exceptions.ImportError'>
01:14:49 T:140220033353472 ERROR: Error Contents: Bad magic number in /home/hhle/.xbmc/addons/SuperTV/resources/lib/__init__.pyc
01:14:49 T:140220033353472 ERROR: Traceback (most recent call last):
File "/home/hhle/.xbmc/addons/SuperTV/default.py", line 18, in <module>
if __name__ == "__main__": from resources.lib.main import main;main(BASE)
ImportError: Bad magic number in /home/hhle/.xbmc/addons/SuperTV/resources/lib/__init__.pyc
(2012-03-12, 10:09)angelworld Wrote: [ -> ]
getting script error too
File "C:\Users\Mike\AppData\Roaming\XBMC\addons\SuperTV\default.py", line 18, in <module>
                                            ImportError: No module named lib.main
also would you need to be signed up to filmOn ?
12:19:35 T:2772921200 DEBUG: Process - Entering source directory /home/d/.xbmc/addons/SuperTV
12:19:35 T:2772921200 DEBUG: Instantiating addon using automatically obtained id of "script.SuperTV" dependent on version 2.0 of the xbmc.python api
12:19:35 T:2772921200 INFO: -->Python script returned the following error<--
12:19:35 T:2772921200 ERROR: Error Type: <type 'exceptions.ImportError'>
12:19:35 T:2772921200 ERROR: Error Contents: Bad magic number in /home/d/.xbmc/addons/SuperTV/resources/lib/__init__.pyc
12:19:35 T:2772921200 ERROR: Traceback (most recent call last):
File "/home/d/.xbmc/addons/SuperTV/default.py", line 18, in <module>
ImportError: Bad magic number in /home/d/.xbmc/addons/SuperTV/resources/lib/__init__.pyc
12:19:35 T:2772921200 INFO: -->End of Python script error report<--
12:19:35 T:3044038400 DEBUG: ------ Window Init (DialogKaiToast.xml) ------
12:19:35 T:2772921200 INFO: Python script stopped
12:19:35 T:2772921200 DEBUG: Thread XBPyThread 2772921200 terminating
12:19:35 T:3044038400 DEBUG: waiting for python thread 32 to stop
12:19:35 T:3044038400 DEBUG: python thread 32 destructed
12:19:40 T:3044038400 DEBUG: ------ Window Deinit (DialogKaiToast.xml) ------
12:19:44 T:3044038400 DEBUG: ------ Window Deinit (Pointer.xml) ------
12:19:45 T:3044038400 DEBUG: ------ Window Init (Pointer.xml) ------
12:19:45 T:3044038400 ERROR: Control 1 in window 10099 has been asked to focus, but it can't
12:19:50 T:3044038400 DEBUG: ------ Window Deinit (Pointer.xml) ------
12:19:59 T:2739030896 DEBUG: Thread Jobworker 2739030896 terminating (autodelete)
12:19:59 T:2674912112 DEBUG: Thread Jobworker 2674912112 terminating (autodelete)
12:20:00 T:3044038400 DEBUG: ------ Window Init (Pointer.xml) ------
12:20:00 T:3044038400 ERROR: Control 1 in window 10099 has been asked to focus, but it can't
12:20:06 T:3044038400 DEBUG: ------ Window Deinit (Pointer.xml) ------
12:20:09 T:3044038400 DEBUG: SECTION:UnloadDelayed(DLL: special://xbmcbin/system/ImageLib-i486-linux.so)
12:20:09 T:3044038400 DEBUG: Unloading: ImageLib-i486-linux.so
12:20:11 T:3044038400 DEBUG: ------ Window Init (Pointer.xml) ------
12:20:11 T:3044038400 ERROR: Control 1 in window 10099 has been asked to focus, but it can't
12:20:11 T:3044038400 DEBUG: SECTION:LoadDLL(special://xbmcbin/system/ImageLib-i486-linux.so)
12:20:11 T:3044038400 DEBUG: Loading: /usr/lib/xbmc/system/ImageLib-i486-linux.so
12:20:12 T:3044038400 DEBUG: ------ Window Deinit (Pointer.xml) ------
12:20:42 T:3044038400 DEBUG: SECTION:UnloadDelayed(DLL: special://xbmcbin/system/ImageLib-i486-linux.so)
12:20:42 T:3044038400 DEBUG: Unloading: ImageLib-i486-linux.so
12:20:46 T:3044038400 DEBUG: ------ Window Init (Pointer.xml) ------
12:20:46 T:3044038400 ERROR: Control 1 in window 10099 has been asked to focus, but it can't
12:20:47 T:3044038400 DEBUG: SECTION:LoadDLL(special://xbmcbin/system/ImageLib-i486-linux.so)
12:20:47 T:3044038400 DEBUG: Loading: /usr/lib/xbmc/system/ImageLib-i486-linux.so
12:20:48 T:3044038400 DEBUG: ProcessMouse: trying mouse action rightclick
12:20:48 T:3044038400 DEBUG: CGUIWindowManager:TonguereviousWindow: Deactivate
12:20:48 T:3044038400 DEBUG: ------ Window Deinit (MyPrograms.xml) ------
12:20:48 T:3044038400 DEBUG: CGUIWindowManager:TonguereviousWindow: Activate new
is this it?
1.0.1 should fix all those bad magic numbers and lib.main not found.
We happy?
