Full Version: Unable to Load Skin - Skin is Missing Some Files
I've just reinstalled after an HDD failure, installing Frodo RC2 in WIndows 8. My previous install worked perfectly so I'm unsure as to what is happening now.
Most times I try to change skin it tells me that the skin is missing some files. AeonMQ4 is the skin I'm trying to apply but it happens on several skins and, as I'm using the same skins I used previously (and downloading them from the repository) I don't believe its a skin issue. I thought maybe it is a permissions issue so I've made sure that both my user and administrator have full access to both the AppData folder and the Programfiles folder.
I'll see if I can attach the log file to this, but does this sound familiar to anyone?
Thanks Smile
I think the important part of the log is
21:21:34 T:4404 DEBUG: CGUIMediaWindow::GetDirectory (addons://all/xbmc.gui.skin/)
21:21:34 T:4404 DEBUG: ParentPath = [addons://all/xbmc.gui.skin/]
21:21:34 T:2892 NOTICE: Thread Background Loader start, auto delete: false
21:21:34 T:2892 DEBUG: Thread Background Loader 2892 terminating
21:21:35 T:4404 INFO: XCURL:Big GrinllLibCurlGlobal::CheckIdle - Closing session to http://feeds.feedburner.com (easy=08085A20, multi=03D80260)
21:21:40 T:4404 DEBUG: Keyboard: scancode: 01, sym: 001b, unicode: 001b, modifier: 0
21:21:40 T:4404 DEBUG: CApplication::OnKey: escape (f01b) pressed, action is PreviousMenu
21:21:40 T:4404 DEBUG: CGUIWindowManager:TonguereviousWindow: Deactivate
21:21:41 T:4404 DEBUG: ------ Window Deinit (AddonBrowser.xml) ------
21:21:41 T:4404 DEBUG: CGUIWindowManager:TonguereviousWindow: Activate new
21:21:41 T:4404 DEBUG: ------ Window Init (SettingsCategory.xml) ------
21:21:42 T:4404 DEBUG: Keyboard: scancode: 1c, sym: 000d, unicode: 000d, modifier: 0
21:21:42 T:4404 DEBUG: CApplication::OnKey: return (f00d) pressed, action is Select
21:21:42 T:4404 DEBUG: ------ Window Init (DialogSelect.xml) ------
21:21:42 T:4404 DEBUG: msg: PICTURE::LoadImage: Unable to open image: C:\Users\Arran\AppData\Roaming\XBMC\addons\skin.aeonmq.4\icon.png Error: (3)
21:21:42 T:4404 ERROR: Texture manager unable to load file: C:\Users\Arran\AppData\Roaming\XBMC\addons\skin.aeonmq.4\icon.png
21:21:43 T:4404 DEBUG: Keyboard: scancode: 48, sym: 0111, unicode: 0000, modifier: 0
21:21:43 T:4404 DEBUG: CApplication::OnKey: up (f080) pressed, action is Up
21:21:43 T:4404 DEBUG: msg: PICTURE::LoadImage: Unable to open image: C:\Users\Arran\AppData\Roaming\XBMC\addons\skin.aeonmq.4\icon.png Error: (3)
21:21:43 T:4404 ERROR: Texture manager unable to load file: C:\Users\Arran\AppData\Roaming\XBMC\addons\skin.aeonmq.4\icon.png
21:21:44 T:4404 DEBUG: Keyboard: scancode: 1c, sym: 000d, unicode: 000d, modifier: 0
21:21:44 T:4404 DEBUG: CApplication::OnKey: return (f00d) pressed, action is Select
21:21:44 T:4404 DEBUG: ------ Window Deinit (DialogSelect.xml) ------
21:21:44 T:4404 ERROR: home.xml doesn't exist in skin: skin.aeonmq.4, fallback to "skin.confluence" skin
21:21:44 T:4404 INFO: Unloading old skin ...
21:21:44 T:4404 DEBUG: ------ Window Deinit () ------
21:21:44 T:4404 DEBUG: ------ Window Deinit (SettingsCategory.xml) ------
21:21:44 T:4404 WARNING: CGUITextureManager::Cleanup: Having to cleanup texture button-focus.png
21:21:44 T:4404 WARNING: CGUITextureManager::Cleanup: Having to cleanup texture button-nofocus.png
21:21:44 T:4404 DEBUG: CTextureBundleXBT::Cleanup - Closed bundle
21:21:44 T:4404 INFO: load skin from: C:\Program Files (x86)\XBMC\addons\skin.confluence (version: 2.1.2)
21:21:44 T:4404 INFO: load fonts for skin...
21:21:44 T:4404 INFO: Loading fonts from C:\Program Files (x86)\XBMC\addons\skin.confluence\720p\Font.xml
21:21:44 T:4404 DEBUG: POParser: PO file has Win Style Line Endings. Converted in memory to Linux LF for file: C:\Program Files (x86)\XBMC\addons\skin.confluence\language\English\strings.po
21:21:44 T:4404 DEBUG: POParser: loaded 131 strings from file C:\Program Files (x86)\XBMC\addons\skin.confluence\language\English\strings.po
21:21:44 T:4404 INFO: Loading skin includes from C:\Program Files (x86)\XBMC\addons\skin.confluence\720p\includes.xml
21:21:44 T:4404 INFO: load new skin...
21:21:44 T:4404 INFO: Loading user windows, path C:\Program Files (x86)\XBMC\addons\skin.confluence\720p
21:21:44 T:4404 DEBUG: Load Skin XML: 1.64ms
21:21:44 T:4404 INFO: initialize new skin...
21:21:44 T:4404 DEBUG: guilib: Fill viewport on change for solving rendering passes
21:21:44 T:4404 INFO: Loading skin file: Pointer.xml, load type: LOAD_ON_GUI_INIT
21:21:44 T:4404 DEBUG: CTextureBundleXBT::OpenBundle - Opened bundle C:\Program Files (x86)\XBMC\addons\skin.confluence\media\Textures.xbt
21:21:44 T:4404 INFO: Loading skin file: DialogVolumeBar.xml, load type: LOAD_ON_GUI_INIT
21:21:44 T:4404 INFO: Loading skin file: DialogKaiToast.xml, load type: LOAD_ON_GUI_INIT
21:21:44 T:4404 INFO: Loading skin file: DialogMuteBug.xml, load type: LOAD_ON_GUI_INIT
21:21:44 T:4404 INFO: Loading skin file: DialogSeekBar.xml, load type: LOAD_ON_GUI_INIT
21:21:44 T:4404 INFO: Loading skin file: DialogBusy.xml, load type: LOAD_ON_GUI_INIT
21:21:44 T:4404 INFO: Loading skin file: DialogExtendedProgressBar.xml, load type: LOAD_ON_GUI_INIT
21:21:44 T:4404 INFO: Loading C:\Program Files (x86)\XBMC\addons\skin.confluence\sounds\sounds.xml
21:21:44 T:4404 INFO: CAEWAVLoader::Initialize - Sound Loaded: C:\Program Files (x86)\XBMC\addons\skin.confluence\sounds\cursor.wav
21:21:44 T:4404 DEBUG: AERemap: Downmix normalization is disabled
21:21:44 T:4404 INFO: CAEWAVLoader::Initialize - Sound Loaded: C:\Program Files (x86)\XBMC\addons\skin.confluence\sounds\click.wav
21:21:44 T:4404 INFO: CAEWAVLoader::Initialize - Sound Loaded: C:\Program Files (x86)\XBMC\addons\skin.confluence\sounds\back.wav
21:21:44 T:4404 INFO: CAEWAVLoader::Initialize - Sound Loaded: C:\Program Files (x86)\XBMC\addons\skin.confluence\sounds\shutter.wav
21:21:44 T:4404 INFO: CAEWAVLoader::Initialize - Sound Loaded: C:\Program Files (x86)\XBMC\addons\skin.confluence\sounds\notify.wav
21:21:44 T:4404 INFO: CAEWAVLoader::Initialize - Sound Loaded: C:\Program Files (x86)\XBMC\addons\skin.confluence\sounds\out.wav
21:21:44 T:4404 INFO: skin loaded...
21:21:44 T:4404 DEBUG: Activating window ID: 10019
21:21:44 T:4404 DEBUG: ------ Window Init (SettingsCategory.xml) ------
21:21:44 T:4404 INFO: Loading skin file: SettingsCategory.xml, load type: KEEP_IN_MEMORY
21:21:44 T:4404 DEBUG: ------ Window Init () ------
21:21:44 T:4404 DEBUG: ------ Window Init (DialogKaiToast.xml) ------
21:21:50 T:4404 DEBUG: ------ Window Deinit (DialogKaiToast.xml) ------
21:21:51 T:4404 DEBUG: Keyboard: scancode: 5b, sym: 0137, unicode: 0000, modifier: 10
21:21:51 T:4404 DEBUG: CApplication::OnKey: win-leftwindows (10f0d6) pressed, action is
21:21:51 T:4404 DEBUG: CWinEventsWin32::WndProcWindow is active
21:21:51 T:4404 DEBUG: CWinEventsWin32::WndProc: Focus switched to process C:\Windows\explorer.exe
21:21:54 T:4404 DEBUG: ------ Window Init (Pointer.xml) ------
21:21:55 T:4404 INFO: XCURL:Big GrinllLibCurlGlobal::CheckIdle - Closing session to http://mod-skin.googlecode.com (easy=0C724008, multi=00000000)
21:21:58 T:4404 INFO: XCURL:Big GrinllLibCurlGlobal::CheckIdle - Closing session to http://mirrors.xbmc.org (easy=081C1008, multi=00000000)
21:21:59 T:4404 INFO: XCURL:Big GrinllLibCurlGlobal::CheckIdle - Closing session to http://mod-skin.googlecode.com (easy=09D48048, multi=00000000)
21:21:59 T:4404 DEBUG: ------ Window Deinit (Pointer.xml) ------
21:22:04 T:3860 DEBUG: Thread Jobworker 3860 terminating (autodelete)
21:22:04 T:204 DEBUG: Thread Jobworker 204 terminating (autodelete)
21:22:04 T:2384 DEBUG: Thread Jobworker 2384 terminating (autodelete)
If anyone can help that would be awesome Smile
i'm having the exact same issue on two fresh installs on windows 8 64bit
when install load a skin I have the same error, when i do manual git pull it works, but not through xbmc interface. did you manage to fix it?
Anyone got a resolution to this as I am seeing the exact same issue on my win8 64bit xbmc install Sad
me also same error when I reinstall on my system into a, linux mint 13, I have installed xbmc via ppa all skins that I have downloaded via add-on module are not able to use, all of them has an error "skin is missing some file", I wonder why or what are the files missing, I have try Ace, Aeon Nox, Nbox, Transparency, Xperience 1080, I even try to manually download Aeon MQ4 to load is via "install from zip" module but unfortunately same error. Can Any one out there to resoled this. or maybe wi will revert to the old version eden.
Most likely you have permissions set incorrectly. What does your log say ?
Please upload a debug log (wiki)
Same issue here when installing master from zip. All the relevant info i can find in the log is here:
ERROR: failed to load requested skin 'skin.amber'
13:28:30 T:13276 INFO: Unloading old skin ...
13:28:30 T:13276 DEBUG: ------ Window Deinit () ------
13:28:30 T:13276 DEBUG: ------ Window Deinit (AddonBrowser.xml) ------
13:28:30 T:13276 DEBUG: ------ Window Deinit (Pointer.xml) ------
13:28:30 T:13276 DEBUG: CTextureBundleXBT::Cleanup - Closed bundle
13:28:30 T:13276 INFO: load skin from: C:\Program Files (x86)\Kodi\addons\skin.confluence (version: 2.5.12)
13:34:59 T:13060 DEBUG: Addon skin.amber requires xbmc.gui version 5.0.1 which is not available
After several attempts to install i just went into deactivated addons, activated it, and then was able to successfully change to amber.
Looks like an old version of amber? Looking at author's github, current is 2.0.12 and is calling for xbmc.gui 5.3.0, which is correct for Helix. Your log shows it was looking for 5.0.1.
scott s.
