2013-01-13, 12:15
2013-01-13, 14:26
thanx for setting that git repo up.
I made some updates on the new image tags in Frodo. You could apply them with the following patch.
The patch is based on the new git repo.
2013-01-13, 18:29
Download DialogExtendedProgressBar.xml is missing in repo.
Download it here : http://www.mediafire.com/download.php?ghphfwfei6ga6f4
2013-01-13, 20:09
if i select 'music' from main menu...screen becomes black. i can use 'esc' button to get back to main menu.
anyone else with this bug?
2013-01-13, 20:18
Yeah, I'm having the same issue. I'll have a look.
2013-01-13, 20:38
Is there a frodo compatible script.library.editor to edit the film genres in the film information?
2013-01-13, 20:45
Nope, currently no library editor for frodo...
2013-01-13, 22:02
does this version not have the option for Right List View?
2013-01-13, 23:07
(2013-01-13, 22:02)SamHill Wrote: [ -> ]does this version not have the option for Right List View?
There is still a rightlist view, nothing has changed since the last version.
You just have to enable it in the skin settings.
2013-01-13, 23:42
hey,
just threw the skin through my skinning tool, some things you should fix (always double-check first):
Unused Includes:
WindowTVShowTitleCommons
ButtonHorzHomeSubCommonValues
GlobalVideoWindow
ContainerMovieSets
Undefined Includes:
WindowTitleHomeButton
SideBladeRight
StartUpNoCustomfocus
StartupCustomFocus
Bannerlist
Breadcrumbs
Breadcrumbs-Weather
clock
Animation_CommonFade
XML Errors:
Processing ViewsTVLogoRightlist.xml
Unerwartetes Token 'reversible'. Erwartet wird ein Leerzeichen. Zeile 135, Position 57
Processing script-LibraryEditor-genre.xml
Unerwartetes Token 'id'. Erwartet wird ein Leerzeichen. Zeile 30, Position 26.
Processing MyMusicPlaylistEditor.xml
Das Start-Tag 'controls' in Zeile 5 Position 4 stimmt nicht mit dem Ende-Tag 'control' überein. Zeile 205, Position 4
Processing DialogContextMenu.xml
Unerwartetes Token 'border'. Erwartet wird ein Leerzeichen. Zeile 17, Position 29
Undefined IDs:
41
37
124
10025
570
cheers,
phil65
Unused Includes:
GlobalVideoWindow
ContainerMovieSets
Undefined Includes:
SideBladeRight
StartupCustomFocus
Bannerlist
Breadcrumbs
Breadcrumbs-Weather
clock
XML Errors:
Undefined IDs:
41
37
124
10025
570
cheers,
phil65
2013-01-14, 00:10
Hi phil, thanx for checking. I know this skin needs a big, very big code cleanup as it was my very first MOD.
Hope one day i'll get the motivation to do it ...
Cheers mate
Cheers mate
2013-01-14, 00:20
(2013-01-13, 23:07)paradix Wrote: [ -> ](2013-01-13, 22:02)SamHill Wrote: [ -> ]does this version not have the option for Right List View?
i dont even have a Skin option under the system settings. Am I missing something?
are we to place this on top of the existing Cirrus Extended 2?
2013-01-14, 01:04
Skin settings has moved to appearance.
2013-01-14, 02:17
(2013-01-14, 01:04)butchabay Wrote: [ -> ]Skin settings has moved to appearance.
My bad... must have overlooked this. Thanks for pointing it out.
2013-01-14, 12:41
(2013-01-13, 20:09)tesona1977 Wrote: [ -> ]if i select 'music' from main menu...screen becomes black. i can use 'esc' button to get back to main menu.
There was a bug in the MyMusicSongs.xml file. If you want to fix it, just remove the </control> tag in line 153.
