hi all,
i have found an rss feed for australian tv which would make a better datasource for mytv.
i am new to python scripting, so please bear with me a little.
what i am trying to do is import the channelid and name tags from
http://www.d1.com.au/d1xmltv....risbane
any ideas?
thanks,
kahooli
kahooli,
i'd be more than happy to have ago at using that rss feed instead of the html scraping method used at present.
i just need to get v1.08 out the door first, so if you can wait a few days ... ?
cheers link thou.
it was easier than i thought, so it'll now be in v1.08
provided programme descriptions are a bit poor thou.
setup:
select provider and region in datasource_ausrss.py
one thing i'm unsure of is the start/stop datetime provided for each prog.
eg 20050929130000+1000
is that indicating your gmt+10 hours ? even if it is, i'm unsure if i should be adding that offset to the time ?
in its present form, its not added, but let me know if the prog start times are wrong because of this.
i just need to double check this code, then v1.08 *should* be uploaded to xbmcscripts tonight.
Quote:one thing i'm unsure of is the start/stop datetime provided for each prog.
it is indicating that the time mentioned before it is gmt+10 (ie already had +10 included in it), not gmt+0.
example the channel ten news on a weekday is at 5pm and finishes at 6pm...
Quote:<start>20050930170000 +1000</start>
<stop>20050930180000 +1000</stop>
thanks for your work, and i cant wait to download it. :bowdown:
ok. should be right th
i've put a yousenit link in the main mytv thread, last post on last page probs.
u can dl from that. v1.08a
cheers
