I get the error message "One or more items failed to play, check the log files" when I try to play movie files via ip-adress/SMB connection.
I run xbmc on ATV2,
Here is my
Log file
Very thankful for any helps.
12:34:32 T:131751936 INFO: FileSmb->Open: Unable to open file : 'smb://Macbook:@192.168.1.4/XBMC/Movies/zipzipzipobfuscated.mkv'
you provided "macbook" as username and didn't specify a password - what ever your server is - it doesn't like that or the server is somehow missconfigured...
(2013-02-01, 23:34)Memphiz Wrote: [ -> ]Code:
I dont have any password why I didn't specify. I can see all the files on ATV that I've on the shared folder on my macbook pro but can not play them.
Have finally solved the problem now. I restored the ATV2 and jailbroken it again (don't know if this was necessary, but wanted to be sure)
And I tried this way to share my files from macbook.
On macbook; settings>sharing I've added the folder I want to share.
On the ATV2; XBMC> Videos> add videos ... > Browse> zeroconf browser .. there You should find your computer, choose the (AFP if apple) folder there you will find the files you want to watch
this works even with external hard drives
check
AFP (wiki) though - before posting any issues with it ...
Guys I need Help! I have been using xbmc the past few days and I mostly used tvc cabo verde from tv portuguesa(add-on). Well I got a error today when I tryed to open the stream that read " one or more items failed to play, check your log file". My log file is uploaded to
http://xbmclogs.com/show.php?id=138261 I dont know what to do and i need a solution ASAP.
Wrong forum mate, ask in the Windows section. This is IOS spesific
