fusion migma v3 for XBMC 12 Frodo
GITHUB
https://github.com/butchabay/skin.fusion.migma.v3
todo list
• strings
• changes to skinning engine for frodo
• code clean up
• bugfixes
• pvr
roadmap
Commited to GITHUB, 20.03.2013
• skin widgets complete
• random and last items widgets complete
• strings not complete
• fixed some bugs
Gave this a quick look on my gaming pc, looks and runs identically to Fusion for XBMC 11, Nice work, finally a reason to upgrade my HTPC!
Latest commit to GITHUB
• skin widgets movies and episodes
• dialog video info --> choose art and artwork downloader
• fixed some bugs
• first part of untranslated strings
just notice the update. great work butchabay, yours efforts are really appreciated.
(2013-03-18, 13:41)emptyhead Wrote: [ -> ]just notice the update. great work butchabay, yours efforts are really appreciated.
Thanx, there is still a lot to do left on my list
(2013-03-19, 17:48)Emrad Wrote: [ -> ]First i want to thank you for this great skin, i tried almost all skins and this one for me is one of the best, cirrus vintage is very nice to. I made an account on this forum just to say thanks and to say what i will like to see in this great skin.
- finish time in the OSD
- option for bottom menu bar
Some views for movies and tvshows that i will like to see in these skin:
movies
- dvd case wrap from back row skin: http://iceimg.com/i/4d/bc/578267abff.png
- info slide from simplicity: http://iceimg.com/i/1a/35/6ae74e01aa.png
- 3d cover info from minimedia: http://iceimg.com/i/c4/f3/8b5c351e91.png
tv shows
- rightlist logo and clearart+thumb from cirrus extended v3: http://iceimg.com/i/9d/4f/c3fd11f2f3.png
- wheelinfo-clearlogo from minimedia: http://iceimg.com/i/bb/cc/06e11ef2a4.png
- logo fanart from neon: http://iceimg.com/i/0e/1e/882fc3e785.png
Thank you for consideration and i hope is posible to add this features so i can make it my default skin. Cheers!
Hi, i don't think i'll add other views, there are already a lot of them in every category ... will keep the look and feel of fusion as it is.
- finish time in the OSD --> i'll look into it
- option for bottom menu bar --> hmm, too much work, that would mean to change all postitions in every part of the skin, that's not my intension.
• strings
• fixed some bugs
Great to hear this is still being worked on. I've tried other skins, but I always come back to this one.
Btw, are you planning to fix up the bugs on your todo list from Eden V2 for the Frodo version? I posted this awhile ago in the Eden thread and it still seems to be an issue with V3 unless it's intended to be that way or I'm overlooking some setting. Sorry if it's already on your todo list.
(2012-10-13, 05:22)chris295 Wrote: [ -> ]Hi, I think I have found another bug, plots don't seem to be scrolling in the Episodes2 Viewtype for TV Shows. I'm using XBMC Eden 11.0. Not sure if it was always this way or a recent occurrence.
Thanks for keeping this skin alive man.
Yes sure, i'm going to fix this and other bugs from v2.
Thanx
Still working on this? Hope so, best xbmc skin iv had, and id love to have it working with frodo aswell
Slowly getting there, btw the skin already works on frodo.
Your v3 from github? or the old v2?
I just updated from Eden to Frodo.
Can Fusion Migma V3 read the "old" .tbn movie posters used in Eden? Is there a setting somewhere?
EDIT: Never mind. It looks like the skin does in fact use my .tbn files. The problem is that some of my movie folders have poster.jpg, which supercedes the .tbn I want to use. I'll delete the poster.jpg.
