Hello,
I want to announce my web interface for Tvheadend. It consists of the following modules:
- mobile web interface with iPhone look'n'feel (works well on other smartphones, tablets and also on desktops)
- EPG timeline (vertical EPG) with the channels on y-axis and time on x-axis
- listings magazine with the channels each on a separate column
It's completely written in JavaScript, HTML, CSS and you only have to copy some files to get it to work.
The project is hosted on GitHub:
https://github.com/polini/TvheadendMobileUI
Nice ! Can it be used on a openelec installation with tvh?
Should also be possible with openelec. You have to find the right directory to copy the files. Must be somewhere in the Tvheadend addon directory: ~/.xbmc/addons/*tvheadend*/
Do you have JavaScript enabled?
Which browser/device?
IE 10, javascript is enabled
Didnt tested IE so far... Can you check the JavaScript console (F12) for error messages? Or try Firefox?
Good work, that man - looks really good.
A couple of comments, if I may:
1. Install path is /usr/share/tvheadend... and not /usr/local/share/tvheadend... - on my system (Xubuntu Precise/12.04 with a self-build dpkg install), anyway!
2. Timeline view: timing axis is in German (4 Uhr, 8 Uhr, etc. instead of 00:00-03:59, 04:00-08:00, etc.)
3. I'm getting no channel icons in the EPG view. I suspect that's simply because I don't have any defined in tvheadend (they're not picked up from Lyngsat for some reason - my problem!) and normally only use XBMC. They're all defaulting to
http://IP:9981/static/mobile/undefined, though, which just comes out as a placeholder image.
4. There's no default web page, so you have to specify index.html (i.e.
http://IP:9981/static/mobile doesn't work)
No criticism intended, though - I think it's looking really good, as I said. Thanks for the work here!
PS Works fine in Chrome, but fails on IE8 on XP (at least). Developer console suggest that there's something IE doesn't like about line 45:
Object expected index.html, line 45 character 1
... which is:
<body id="body" onload="init();">
I think IE doesn't play nicely with document.body.onload-type commands for some reason.
(2013-04-15, 22:39)Prof Yaffle Wrote: [ -> ]1. Install path is /usr/share/tvheadend... and not /usr/local/share/tvheadend... - on my system (Xubuntu Precise/12.04 with a self-build dpkg install), anyway!
Is mentioned in README now
(2013-04-15, 22:39)Prof Yaffle Wrote: [ -> ]2. Timeline view: timing axis is in German (4 Uhr, 8 Uhr, etc. instead of 00:00-03:59, 04:00-08:00, etc.)
Is corrected
(2013-04-15, 22:39)Prof Yaffle Wrote: [ -> ]3. I'm getting no channel icons in the EPG view. I suspect that's simply because I don't have any defined in tvheadend (they're not picked up from Lyngsat for some reason - my problem!) and normally only use XBMC. They're all defaulting to http://IP:9981/static/mobile/undefined, though, which just comes out as a placeholder image.
Is corrected
(2013-04-15, 22:39)Prof Yaffle Wrote: [ -> ]4. There's no default web page, so you have to specify index.html (i.e. http://IP:9981/static/mobile doesn't work)
Needs changes in Tvheadend itself. I hope TvheadendMobileUI will be included in Tvheadend in the future, then the index.html should be the starting page...
IE should now also work.
Thanks for the quick response. I can confirm your fixes.
Also, on IE it now loads, but there are still some errors (e.g.
Message: 'tmdbApiK' is undefined
Line: 2 Char: 1 Code: 0
URI: http://IP:9981/static/mobile/tvh_custom.js
Message: Expected ')'
Line: 1 Char: 40 Code: 0
URI: http://IP:9981/static/mobile/epg.html
So it looks as if Internet Explorer still needs some debugging - although I might mean the browser, not your code ;-)
WOW! Great work! Tvheadend really needs some UI-Update
hello, i use tvheadend on clean install with ubuntu 12.04 lts, when i go on mobile web page i have an error 500... it is normal?
Did you copy the files from the git repository?
yes i copy the files from git.
