This is the Screensaver you all are waiting for (not).
I quickly hacked together this Nyan Cat/Pop-Tart Cat Screensaver.
Download here
Source here
Have fun
-sphere
so mad !
there will be TV murder with this !!!
LOL... I don't know if I want to install this.
would be cool if the background stars could move a bit too. and of course a rainbow in it
Music! needs the music!
Awesome, by the way.
I already worked on a version which included (endless) music - but it made me so mad that I removed it again
Sure, I will re-add it... The Question is opt-in or opt-out?
If you are mad enough to enough use it I would say you deserve music. So opt out
Although it might interfere with perhaps music you are playing at that moment when it kicks in.
An update is available via zip
Changelog:
Quote:0.1.0 (13.08.2013)
- added optional animated background (default enabled)
- added optional animated rainbow (default enabled)
Sound is problematic
- PlaySFX is unstoppable, can't play in loop and takes only .WAV.
- Internal Player exits Screensaver on playback start (I guess playback resets the internal idle timer or is counted as action)
Download Version 0.1.0
Have fun,
sphere
awesome, something to annoy the wife with
Version 1.0.0 is now available in the official repository, have fun.
could u make like a .gif to show us how it looks like? or a video?
Kodi on top of OpenELEC ARM (Raspberry Pi) halts and reboots, when I try to set this screensaver
Hello, has anybody got this working on a Fire stick? When I install it, all I get is the purple screen without the cat! Help! I need this :-D
Hello,
There is a little problem with this screensaver on Rpi3 , Nyan cat appear on top of a black boxe.
Could someone with adequate skills may try to fix it ?
Thanks by advance
(2016-08-30, 06:27)Calcifer-73 Wrote: [ -> ]Hello,
Thanks by advance
(ETA: I am seeing this issue on Kodi 16.1, on a Raspberry Pi 2 running OSMC)
To speak a little more about this problem, it appears the nyan_cat.gif and rainbow.gif files are no longer layering on top of background.jpg, but are instead rendering at the same level. This means the two gif files with transparent backgrounds are letting the screen image below the screensaver to show through.
Is anyone able to look further into this issue?
