(2014-03-02, 16:47)bigsteel99 Wrote: [ -> ] (2014-03-02, 16:40)Lunatixz Wrote: [ -> ] (2014-03-02, 16:13)bigsteel99 Wrote: [ -> ]Hey @Lunatixz still can't get donor features to work but that's ok PSTVL Is still a darling and will continue to donate.
But i have a another problem when i interleave channels and do a force refresh, when i bring up the EPG, it cuts out and i have restart xbmc
it happens with all the skins.
http://xbmclogs.com/show.php?id=141568
let's not move past the donor issue, please send me a log that shows donor features failing...
I haven't received one full log yet that shows a problem...
I just pm you the logs
Two issues with your log.
1) no debug data, please enable debugging. I PM'ed you directions
2) your running Gotham, which "should" work, but I currently do not offer support until its in final beta! Sorry!!
Is anyone still having issues with any new features donor or otherwise? please post links to full logs w/ debugging enabled.
Are there any success stories? anyone enjoying popcorn? new features?
(2014-03-02, 17:23)Lunatixz Wrote: [ -> ] (2014-03-02, 16:47)bigsteel99 Wrote: [ -> ] (2014-03-02, 16:40)Lunatixz Wrote: [ -> ]let's not move past the donor issue, please send me a log that shows donor features failing...
Just pm you the log i had debug enabled, if Gotham is found to be the culprit would be more than happy to downgrade.
and i am ever grateful for your help.
Tested you tube "favorites" works great!
popcorn works great,too(i don't use autotune i created 4 channels with different options and all worked)
Thanks, Luna
(2014-03-02, 18:04)tromy Wrote: [ -> ] (2014-03-02, 17:23)Lunatixz Wrote: [ -> ] (2014-03-02, 16:47)bigsteel99 Wrote: [ -> ]I just pm you the logs
Thanks, Luna
First off let me say thanks for all of your help. I downgraded to frodo internet tv and popcorn movie works great,
but i still can't get commercials and trailers to play from the internet, trailers work from the xbmc library but not from the internet.
log
http://xbmclogs.com/show.php?id=141693
First of all a big thank you for taking on this project and helping so many people. The whole idea of live streams and commercials/bumpers/trailers is just what I've been dreaming of. But, alas I am having problems.
I can install psuedotvlive and get it to run with the predefined channels. And if I copy my settings2 all my channels work. However, if I force a channel update it goes to a black screen while scanning regardless of if it's the generic channel setup from first install or if it's my settings2. I have followed the post 1, 2, 3 instructions and scanned the forum trying several ideas, but nothing seems to help. Here is the debugging file
http://pastebin.com/DjbNet2q
Thanks for any help
Hi.
Noob question.
Help please
How do I prevent the program to read the strm files?
I mean I want only local files are used to.
is it possible?
(2014-03-03, 02:17)LARQ Wrote: [ -> ]Hi.
Noob question.
Help please
is it possible?
Uncheck the setting under misc.
ok, this is an awesome addon, but it does not install on my ouya. it says addon does not hve the correct structure. It installed and runs smoothly on my pc. I have spent 14 hours on this and cannot figure it out. Including a master reset of the ouya, 3 different versions on xbmc, i just dont understand. any help would be so very helpful.
(2014-03-03, 02:06)Antisthenes Wrote: [ -> ]Hi,
Thanks for any help
I got it to work. It seems that the problem was my network drives where set up as NFS, When I switched it to SMB it worked flawlessly. Your fork is awesome please keep up the excellent work!!!
(2014-03-03, 21:25)demarini Wrote: [ -> ]ok, this is an awesome addon, but it does not install on my ouya. it says addon does not hve the correct structure. It installed and runs smoothly on my pc. I have spent 14 hours on this and cannot figure it out. Including a master reset of the ouya, 3 different versions on xbmc, i just dont understand. any help would be so very helpful.
What's the error. I had a similar situation (pseudotv.py error) w/ xbmcbuntu on laptop, but was resolved by installing dependencies in 1st post. Try that, if not, post a log
thanks steve. I tried the dependencies, some would not install. they seemed to load fine but not install. i will try again tonight. the error that shows in addon does not have the correct structure.
Are you installing through ssh or drag/drop directly into addons folder?
through smb share folder
ahhh i think i see what you are saying. have to ssh into ouya.
Luna,
Quick question, can settings.xml be backed up when performing an upgrade and over-ride the one create with a new installation? or is it recommended redo all settings?
