2014-04-01, 14:24
(2014-04-01, 09:39)gjwAudio Wrote: [ -> ]PTVL misbehaving with USTVnow channels...
Hi Luna
Bzzzzzt... it ain't happening. Manually built USTVnow channels from posted example (page 1), started PTVL, scrolled through EGP to new channels (11-17), got CBS to run, moved to CW... froze the NUC. Power button to the rescue.
So here's a whopping 3 mb Debug LOG to tell you all about it.
Just for curiosity, I ran USTVnow plugin directly, and all but ABC channel ran successfully. They may have trouble at the head end.
Please show me the error of my ways
Yeah, not my end... ABC apparently is region blocked for my location... weird!
(2014-04-01, 11:53)tromy Wrote: [ -> ](2014-04-01, 00:26)Lunatixz Wrote: [ -> ]::Update::
there is a chance the disable cache didn't take!
I'm pushing new code that will definitely disable the cache, try again after update...
::Update::
Okay try new code, this time disabling cache should work...
(2014-04-01, 00:43)kaiseruk Wrote: [ -> ]That fixed it, thank you!
That fixed my set up,too(non-english characters)
Yeah, because cache was causing unicode errors. But they fixed it.... It should be in the next update for the common plugin cache addon.
