Here's what I just went through. Every single step. If it isn't listed here, I didn't do it. (LIbraries were not scraped and I added no media to keep this as clean as humanly possible.)
-== Full New Fresh Install of XBMC + Install USTVNow ==-
1 - Uninstalled XBMC.
2 - Removed the entire XBMC directory from AppData/Roaming/XBMC, making sure it was entirely empty.
3 - Redownloaded XBMC 12.3, installed.
4 - Redownloaded PseudoTV Live (commit 122c9fc15b824a3c53b82ccdb4a19278b3a22237)
5 - Redownloaded Luna's version of USTVNow.
6 - Started XBMC, System -> Settings -> Add-ons -> Install from zip file -> Install Luna's version of USTVNow, Quit XBMC.
-== Verify USTVNow Install, Install PseudoTV Live ==-
7 - Started XBMC, Videos -> Add-ons -> Right-Click on USTVNow, Add-on Settings.
8 - Put in my email and password for USTVNow account, left other options alone.
9 - Started USTVNow add-on -> Live -> Selected a channel to verify playback -> Closed USTVNow to return to XBMC's main screen.
10 - System -> Settings -> Add-ons -> Install from zip file -> Install PseudoTV Live (without -master on directory name), Common Plugin Cache gets installed as well as a dependency, Quit XBMC.
Logfile for this run:
http://pastebin.com/wfbVPWSz
-== Verify PseudoTV Live Install, Donor Settings, Setup ==-
11 - Started XBMC, Programs -> Right-Click on PseudoTV Live -> Add-on Settings.
12 - Scroll to Misc. tab -> Enabled "Enable Donor Features" -> Entered username:password -> Hit "Activate/Update Donor Features", toast message says "Donor features not updated..."
13 - Hit the OK button on the PseudoTV Live settings box -> Right-click on PseudoTV Live -> Add-on Settings.
14 - Scroll to Misc. tab, verify my name and password is still listed and "Enable Donor Features" is still turned on, Hit "Activate/Update Donor Features", toast message now says "Activated Donor Features"
15 - Quit XBMC.
http://pastebin.com/Rn53uWt4
** Bug: XBMC will always report script.pseudotv.live-donordownload: Donor Enabled? = false if the user has not hit OK on the PseudoTV Live dialog box first as until the OK button has been hit, the state has not changed yet! Attempting to enable donor features will *always* fail unless you've hit the OK button to make the Donor Enabled flag change state! **
This is likely what you were seeing with frieten's log with enabled = false earlier.
-== Verify PseudoTV Live Install ==-
16 - Start up XBMC, Programs -> Right-Click on PseudoTV Live -> Add-on Settings
17 - Autotune tab -> Enable AutoTune -> Enable "Warning this will delete..."
18 - Enable "Find USTVNow" (and nothing else)
19 - Misc. Tab -> Enable debugging (for more info if we can get it)
20 - Hit OK on the PseudoTV Live settings.
21 - Start PseudoTV Live.
22 - Dialog box pops up, "Auto Tune, Adding USTVNow Channels", title bar reads "PseudoTV Live - 15%", never continues.
Logfile for this run (until force close):
http://pastebin.com/xwpEnfec
Settings2.xml does not exist at the time of the force close and I never entered the channel editor.
Settings.xml has the following:
http://pastebin.com/NYNFLAdY
XBMC does not freeze or crash as things like the screenshot function still work here. It's been 20 minutes since I started and it's never advanced. Hitting the cancel button does not terminate the script. XBMC must be force-closed.
If there is user error anywhere in this, please let me know and I've given you more than what you asked for. So, at least one bug verified to exist so far. I am on an 80/10 cable connection, so internet connection slowness isn't an issue and I verified that your version of the USTVNow plugin responds nice and quickly.
No pressure though. I'm fine if you take a look at this after the weekend or something. I'm in no rush and just want to help get it working.
