(2014-04-16, 23:02)Dec64 Wrote: [ -> ] (2014-04-16, 22:38)Lunatixz Wrote: [ -> ] (2014-04-16, 22:06)Dec64 Wrote: [ -> ]How do i create such a link. Adding the content via the plugin to favourites, then copying that link into the settings2.xml does not work. I tested the same process on the discovery channel plugin and that does not work either.
I already wrote you instructions, read posts above...
ah sorry i did not see your latest edit to that post. As said before tho iv tried the favourites.xml route and it didn't work for any plugin i tried. U mention it needs to be edited? What specifically..? All the edits i attempted still didn't work. I attempted the json route as suggested but that seems way above me. I have no idea what Ajax end points are or how to find out what mine is ect.
place a uneditted discovery plugin link into a setting2.xml chtype 9 setup, force reset ptvl, run it and send me the m3u generated for that channel. m3u is found in userdata/script.pseudotv.live/cache/channelnumber.m3u
(2014-04-16, 23:14)Lunatixz Wrote: [ -> ] (2014-04-16, 23:02)Dec64 Wrote: [ -> ] (2014-04-16, 22:38)Lunatixz Wrote: [ -> ]I already wrote you instructions, read posts above...
#EXTM3U
#EXTINF:5400,Test//InternetTV//Testing internet plugin stream//InternetTV////LiveID|
plugin://plugin.video.discovery_com/?url=http://news.discovery.com/space/videos/is-sex-in-space-still-just-a-fantasy-video.htm&mode=playVideo
Just sits on a black screen
(2014-04-16, 23:25)Dec64 Wrote: [ -> ] (2014-04-16, 23:14)Lunatixz Wrote: [ -> ] (2014-04-16, 23:02)Dec64 Wrote: [ -> ]ah sorry i did not see your latest edit to that post. As said before tho iv tried the favourites.xml route and it didn't work for any plugin i tried. U mention it needs to be edited? What specifically..? All the edits i attempted still didn't work. I attempted the json route as suggested but that seems way above me. I have no idea what Ajax end points are or how to find out what mine is ect.
#EXTM3U
Create two strm files (txt file with a strm extension)
1 with:
2nd with:
plugin://plugin.video.discovery_com/?url=http%3A%2F%2Fnews.discovery.com%2Fspace%2Fvideos%2Fis-sex-in-space-still-just-a-fantasy-video.htm&mode=playVideo
Try to play them in xbmc which one plays?
Lunatixz Neither work.
Quote:22:35:10 T:140361324250944 ERROR: Playlist Player: skipping unplayable item: 0, path [plugin://plugin.video.discovery_com/?url=http://news.discovery.com/space/videos/is-sex-in-space-still-just-a-fantasy-video.htm&mode=playVideo]
22:35:12 T:140360059709184 NOTICE: Thread BackgroundLoader start, auto delete: false
22:35:12 T:140361324250944 NOTICE: CDVDPlayer::CloseFile()
22:35:12 T:140361324250944 NOTICE: DVDPlayer: waiting for threads to exit
22:35:12 T:140361324250944 NOTICE: DVDPlayer: finished waiting
2nd link
Quote:22:32:58 T:140359617214208 NOTICE: Thread DVDPlayer start, auto delete: false
22:32:58 T:140359617214208 NOTICE: Creating InputStream
22:32:58 T:140359617214208 ERROR: Error on dvdnav_open
22:32:58 T:140359617214208 ERROR: CDVDPlayer::OpenInputStream - error opening []
22:32:58 T:140359617214208 NOTICE: CDVDPlayer::OnExit()
22:32:58 T:140359617214208 NOTICE: CDVDPlayer::OnExit() deleting input stream
22:32:58 T:140361324250944 ERROR: Playlist Player: skipping unplayable item: 0, path [plugin://plugin.video.discovery_com/?url=http%3A%2F%2Fnews.discovery.com%2Fspace%2Fvideos%2Fis-sex-in-space-still-just-a-fantasy-video.htm&mode=playVideo]
These are changes i attempted to do on the sportingstreams link, removing the hex code's ect but come up against the same issue. So im kinda lost
(2014-04-16, 23:37)Dec64 Wrote: [ -> ]@Lunatixz Neither work.
2nd link
You need to find a valid link... If it doesn't play in xbmc its not going to play in pseudo.
(2014-04-16, 23:39)Lunatixz Wrote: [ -> ] (2014-04-16, 23:37)Dec64 Wrote: [ -> ]@Lunatixz Neither work.
2nd link
So the only way to get the true link is via the json addon linked? Alright well thanks a lot for your assistance, sorry to be a pain.
(2014-04-16, 23:40)Dec64 Wrote: [ -> ] (2014-04-16, 23:39)Lunatixz Wrote: [ -> ] (2014-04-16, 23:37)Dec64 Wrote: [ -> ]@Lunatixz Neither work.
2nd link
Usually the favorite link works... Depends on the addon I guess.
PTVL is freezing /hanging while streaming USTVnow channels that are autotuned. I am on Gotham and running 3.7 on a Mac Pro (OSX 10.7). I originally thought it was a guide issue (running concast). I switched to default, and without fail, I freeze after changing channels or scrolling through the guide. I have a log
here that may help. I am sure it is most likely user error, but I can not figure out what I did wrong. Any help would be appreciated.
Trying to create a settings2.xml for Pseduo-TV Live (PSTVL) on Verizon Fios proved to be quite challenging. Many channels that need to be reviewed, which makes things pretty cumbersome. So we took the time to create a script for it. I am not a python programmer, nor a programmer at all for the matter. I am sure that this can be improved by a skilled individual in a number of methods.
howto -
https://dl.dropboxusercontent.com/u/5885...mltvpy.pdf
script file -
https://dl.dropboxusercontent.com/u/5885...v/xmltv.py
if you have question, PM me. Please DO NOT post here to keep the thread relevant to its subject matter.
Hopes it helps someone out.
(2014-04-17, 19:11)ylafont Wrote: [ -> ]Trying to create a settings2.xml for Pseduo-TV Live (PSTVL) on Verizon Fios proved to be quite challenging. Many channels that need to be reviewed, which makes things pretty cumbersome. So we took the time to create a script for it. I am not a python programmer, nor a programmer at all for the matter. I am sure that this can be improved by a skilled individual in a number of methods.
howto - https://dl.dropboxusercontent.com/u/5885...mltvpy.pdf
script file - https://dl.dropboxusercontent.com/u/5885...v/xmltv.py
Thanks for the contribution, I will review it and add it to the OP
From your experience is there anyway I could improve upon the hdhomerun auto tuning feature?
Auto tuning currently pairs a strm with it's xmltv data via strm file name. Does this not work for you?
(2014-04-17, 18:46)omnicroncs Wrote: [ -> ]PTVL is freezing /hanging while streaming USTVnow channels that are autotuned. I am on Gotham and running 3.7 on a Mac Pro (OSX 10.7). I originally thought it was a guide issue (running concast). I switched to default, and without fail, I freeze after changing channels or scrolling through the guide. I have a log here that may help. I am sure it is most likely user error, but I can not figure out what I did wrong. Any help would be appreciated.
Your log has way to much stuff going on... can you start a clean xbmc instance,and load ptvl till your problem. then send that log?
thanks
Hey guys,
I just found this add-in today and am very interested in it. Sorry I am at work and cant dedicate the hours required to read through the entire forum.....
I have a couple quick questions.
1. Does this add-in work on Adroid builds of XBMC?
and 2. Is there a list of supported USB OTD DTV Tuners (that work with Android)?
Bill
(2014-04-17, 20:07)bilbo6209 Wrote: [ -> ]Hey guys,
Bill
the tuner would need to be connected to a PC that could serve the tuner streams to ptvl. Read first 3 posts.
(2014-04-17, 20:13)Lunatixz Wrote: [ -> ]the tuner would need to be connected to a PC that could serve the tuner streams to ptvl. Read first 3 posts.
OK Sorry I didnt catch that the first time I read it.... In the Sources you list that it can be set up for a homerunhd... does that require a PC backend also, or can PsudoTV Live point at the homerun directly?
(2014-04-17, 20:28)bilbo6209 Wrote: [ -> ] (2014-04-17, 20:13)Lunatixz Wrote: [ -> ]the tuner would need to be connected to a PC that could serve the tuner streams to ptvl. Read first 3 posts.
Yes, hdhomerun doesn't require a backend it hooks directly to your home network and it works in xbmc android.
