(2014-05-11, 23:09)Lunatixz Wrote: [ -> ]This problem with "PIL" missing, may be a bigger issue then I thought...
I plan on implementing a lot of enhanced gui stuff which depends on this library... seems that some builds of XBMC are leaving it out... or using a build of python which doesn't include it...
Ah, quite unfortunate. Thanks for looking into this.
Got a second RPi that I might toss OpenELEC on and give PTLV a go on that and see if I have any better luck. Been needing an excuse to switch over anyway. Hopefully not all RPi XBMC builds decided to skimp on that lib.
so should i not update pstvl on my ouya? since it works perfect atm.
(2014-05-11, 23:39)scilz Wrote: [ -> ]so should i not update pstvl on my ouya? since it works perfect atm.
It's not a matter of not upgrading... its a matter of wither you will be able to use this plugin in the future...
I need to find out more about this missing module, for now it will be safe to upgrading starting with tonight's update.
Just a follow up FYI. Booted up OpenELEC, added my video library, installed the addons, installed PTVL, and it opened up first try no problem.
So yeah, if anyone else is having issues with RaspBMC it's worth switching over to OpenELEC it would seem. If PseudoTV is one of your main addons, like me, that is.
2 days later edit: OpenELEC seems to have broken a fair amount of other things, mainly my library updating properly. Switch over with caution...
::Update::
Git will be updated within the hour, it will require a mandatory donor update if applicable.
Fixed a few issues, USTVnow, Donor BCT's and some Super Fav tweaks...
Do you have a minimum donation amount? I mean I only have like a buck in my PayPal and I don't want to be insulting lol but I definitely wanna donate and don't wanna wait til my next refill
(2014-05-12, 01:25)Lunatixz Wrote: [ -> ]::Update::
Will the update fix the issue on ouya? I am ready to donate once it works! Thanks for all your hard work.
(2014-05-12, 01:37)ridflea Wrote: [ -> ] (2014-05-12, 01:25)Lunatixz Wrote: [ -> ]::Update::
I installed the new build on my ouya, phone, and tablet and it is working great! Thanks so much. Donation coming your way!
Hi Luna,
I just donated. So do I download your master again? Should I wait until my donation account to be activated before I try all the updated features?
You have to wait till Friday lol that's when he sends the donor logins
Aww shoulda waited til Thursday then lol
So I just re-downloaded and installed the plugin from the first post (I assume that's an updated link) and now my XBMC just doesn't do anything at all when trying to add USTVnow channels. It just sits there saying Adding USTVnow Channels for eternity, and won't do anything when I hit cancel.
What am I missing?
Never mind. Just read its "Gotham Only". I've been waiting for a few plugins to get updated but it's nothing really important so I'll just go ahead and update again. Hopefully it works!
Just updated anyways and I am happy to report USTVNow works great! Happily awaiting my donation to activate for the all the other goodies!
