2014-05-20, 14:24
(2014-05-20, 04:41)Dec64 Wrote: [ -> ]@Lunatixz
Getting errors on creating channels for certain live tv channels.
Code:03:38:01 T:140257737672448 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.ValueError'>
Error Contents: invalid literal for int() with base 10: 'I316.751025.microsoft.com'
File "/home/declan/.xbmc/addons/script.pseudotv.live-master/resources/lib/Overlay.py", line 289, in onInit
if self.readConfig() == False:
File "/home/declan/.xbmc/addons/script.pseudotv.live-master/resources/lib/Overlay.py", line 407, in readConfig
self.channels = self.channelList.setupList()
File "/home/declan/.xbmc/addons/script.pseudotv.live-master/resources/lib/ChannelList.py", line 158, in setupList
self.setupChannel(i + 1, False, makenewlists, False)
File "/home/declan/.xbmc/addons/script.pseudotv.live-master/resources/lib/ChannelList.py", line 512, in setupChannel
if self.channels[channel - 1].setPlaylist(CHANNELS_LOC + 'channel_' + str(channel) + '.m3u') == True:
File "/home/declan/.xbmc/addons/script.pseudotv.live-master/resources/lib/Channel.py", line 48, in setPlaylist
return self.Playlist.load(filename)
File "/home/declan/.xbmc/addons/script.pseudotv.live-master/resources/lib/Playlist.py", line 217, in load
tmpitem.duration = int(line[8:index])
ValueError: invalid literal for int() with base 10: 'I316.751025.microsoft.com'
What xmltv source are you using?
(2014-05-20, 13:12)tromy Wrote: [ -> ]Live tv artwork question:
This is an example of a m3u live channel created from PLTV:no artwork
#EXTINF:3600,PERSON OF INTEREST//LiveTV//..plot......//Unknown//2014-05-21 21:00:00//NA|NA|NA|OLD,tvshow|
pvr://channels/tv/All TV channels/3.pvr
I can edit it and add the title of the show:
#EXTINF:3600,PERSON OF INTEREST//LiveTV//..plot.......//Unknown//2014-05-21 21:00:00//NA|PERSON OF INTEREST|NA|OLD,tvshow|
So I have downloaded an image, named it "PERSON OF INTEREST-landscape" and put it in cache/artwork folder.That thing works fine.
Is it possible to auto search in the cache/artwork folder and find the exact name and not do this manually?
This isn't a good idea... what are you trying to do... do you have enhanced artwork and guide data enabled in livetv? Did you force channel reset after enabling?
(2014-05-20, 14:18)ianuk2005 Wrote: [ -> ](2014-05-19, 23:21)Lunatixz Wrote: [ -> ](2014-05-19, 22:17)ianuk2005 Wrote: [ -> ]Another quick question, I'm sure it's not possible atm but I have some playlists that have tons of episodes for one show and not as many for other shows. If I have it ordered random and set to only play a show one episode in a row i'd get for example show: ABACADABABDAC
so the epg is populated with a lot from show A and not many from show B,C or D.
If there a way to get it to go like show ABCDABCDABCD
There is already a rule for this...
Can you give me some more details on what rule will do that? I have my playlists set to random and the channel rule to only show one episode in a row and it will still go for example show ABACAC and not show ABCABC
Best effort , then you can select how many shows each...
