Hi
i just upgraded to Gotham to test PTVL with the latest build.
my settings consist of only
<settings>
<setting id="Channel_22_type" value="9" />
<setting id="Channel_22_1" value="5400" />
<setting id="Channel_22_2" value="http://192.168.1.1:9981/stream/channelid/18" />
<setting id="Channel_22_3" value="Channel 22" />
<setting id="Channel_22_4" value="Channel 22" />
<setting id="Channel_22_rulecount" value="1" />
<setting id="Channel_22_rule_1_id" value="1" />
<setting id="Channel_22_rule_1_opt_1" value="Channel 22" />
</settings>
the stream is a tvheadend server and it works in frodo and if i put it in a strm file (so i know the stream is ok)
once i start PTVL, it just says "no channels configured, would you like pseudotv live to auto tune channels"
once i go back to settings2.xml it is reset to default.
log error:
3:04:26 T:140269378848512 NOTICE: script.pseudotv.live PseudoTV Live /storage/.xbmc/addons/script.pseudotv.live-master 0.3.9
13:04:26 T:140269378848512 NOTICE: script.pseudotv.live-Globals: System Caching Enabled
13:04:26 T:140269283661568 NOTICE: Thread LanguageInvoker start, auto delete: false
13:04:26 T:140269283661568 NOTICE: -->Python Interpreter Initialized<--
13:04:26 T:140269283661568 NOTICE: script.pseudotv.live PseudoTV Live /storage/.xbmc/addons/script.pseudotv.live-master 0.3.9
13:04:26 T:140269283661568 NOTICE: script.pseudotv.live-Globals: System Caching Enabled
13:04:26 T:140269283661568 NOTICE: script.pseudotv.live-ChannelList: Donor Import Failed, Disabling Donor FeaturesNo module named Donor
13:04:26 T:140269283661568 NOTICE: Donor Import Failed, Disabling Donor FeaturesNo module named Donor
13:04:27 T:140269283661568 NOTICE: Requesting
http://www.google-analytics.com/__utm.gi...2601650523
13:04:27 T:140269283661568 NOTICE: Pragma: no-cache
Expires: Wed, 19 Apr 2000 11:43:00 GMT
Last-Modified: Wed, 21 Jan 2004 19:51:30 GMT
X-Content-Type-Options: nosniff
Content-Type: image/gif
Date: Thu, 15 May 2014 02:20:43 GMT
Server: Golfe2
Content-Length: 35
Cache-Control: private, no-cache, no-cache=Set-Cookie, proxy-revalidate
Alternate-Protocol: 80:quic
Connection: close
13:04:31 T:140269283661568 FATAL: script.pseudotv.live-TVOverlay: FATAL ERROR: Unable to find any channels.
Please go to the Addon Settings to configure PseudoTV Live.
13:04:34 T:140269235627776 NOTICE: VideoInfoScanner: Finished scan. Scanning for video info took 04:33
13:04:35 T:140269667989248 NOTICE: service.libraryautoupdate-0.9.2 : update timers
13:04:35 T:140269667989248 NOTICE: service.libraryautoupdate-0.9.2 : Creating timer for Video Library
13:06:09 T:140269642811136 NOTICE: Thread AESinkNull start, auto delete: false
13:06:12 T:140269235627776 NOTICE: Thread JobWorker start, auto delete: true
13:06:12 T:140269235627776 WARNING: CreateLoader - Unsupported protocol(script) in script://service.openelec.settings/fanart.jpg
13:06:19 T:140270111663936 ERROR: CPythonInvoker(15, /storage/.xbmc/addons/script.pseudotv.live-master/default.py): script didn't stop in 5 seconds - let's kill it
13:06:19 T:140270094866176 NOTICE: Thread LanguageInvoker start, auto delete: false
13:06:19 T:140270094866176 NOTICE: -->Python Interpreter Initialized<--
13:06:19 T:140270094866176 NOTICE: script.pseudotv.live PseudoTV Live /storage/.xbmc/addons/script.pseudotv.live-master 0.3.9
13:06:19 T:140270094866176 NOTICE: script.pseudotv.live-Globals: System Caching Enabled
13:06:19 T:140269378848512 NOTICE: Thread LanguageInvoker start, auto delete: false
13:06:19 T:140269378848512 NOTICE: -->Python Interpreter Initialized<--
13:06:19 T:140269378848512 NOTICE: script.pseudotv.live PseudoTV Live /storage/.xbmc/addons/script.pseudotv.live-master 0.3.9
13:06:19 T:140269378848512 NOTICE: script.pseudotv.live-Globals: System Caching Enabled
13:06:19 T:140269378848512 NOTICE: script.pseudotv.live-ChannelList: Donor Import Failed, Disabling Donor FeaturesNo module named Donor
13:06:19 T:140269378848512 NOTICE: Donor Import Failed, Disabling Donor FeaturesNo module named Donor
13:06:20 T:140270111663936 NOTICE: Samba is idle. Closing the remaining connections
any ideas?
