(2014-12-05, 22:59)bry- Wrote: [ -> ] (2014-12-05, 22:55)Chadman Wrote: [ -> ]Not sure if you're still looking for ideas, but I think selectable channel lists would be a cool addition to the sidebar. One for the kid, one for me, one for the wife. As it is, I have 200 channels and my daughter only uses about 24 and my wife about 10. For me, I use them all.
shot down - already tried
Ah, okay. I suggested if before, but didn't know it had already been tried.
trying to setup HDHOMERUN live channels.
I configure it on Autotune to Find HDHOMERUN and configure the path to HDHOMERUN using upnp.
Still the channels are not available.
Any instructions how can i setup hdhomerun live channels using upnp ?
AutoTune for hdhomerun finds only the first channel.
How to make it scan all channels ?
Manually modifying settings2.xml and adding the Channel_1_2 for other channels does not make a difference.
Can somebody post their settings2.xml for multiple channels.
<settings>
<setting id="Channel_1_type" value="9" />
<setting id="Channel_1_time" value="31" />
<setting id="Channel_1_1" value="5400" />
<setting id="Channel_1_2" value="upnp://address/Channels/v2/" />
<setting id="Channel_1_3" value="Listing Unavailable" />
<setting id="Channel_1_4" value="TV Listing Unavailable, Check your xmltv file" />
<setting id="Channel_1_rulecount" value="1" />
<setting id="Channel_1_rule_1_id" value="1" />
<setting id="LastExitTime" value="1417909547" />
<setting id="Channel_1_changed" value="False" />
<setting id="LastResetTime" value="1417909517" />
</settings>
Hey all. What is recommended size for channel logo's?
Try downloading the logo packs to see some options.
160x110 seems common to one pack. When I was making my text ones, I preferred to keep the 110 height, but make them wider.
(2014-12-07, 17:36)Chadman Wrote: [ -> ]Try downloading the logo packs to see some options.
Thanks Chadman! Which logo packs are you referring to?
hi
I have 2 questions about this addon:
1. is it possible that this addon will auto download subtitle in there is a missing subtitle for one of the movies or episodes?
2. is it possible to remove the pseudotv logo from the bottom of the screen?
thanks.
I am sure I am missing something stupid. Working on a new fresh windows install and I cannot even get it to install.
Stuck at 98% when downloading from Repo and from a zip file just hangs.
What am I missing?
(2014-12-07, 22:07)SOME1 Wrote: [ -> ]hi
thanks.
1: yes. Either set up a remote key using the keymap addon so it launches the subtitle add-on, or use the subtitle option in the side bar
2: in the settings there is an option to turn it off. I forget what it is called
(2014-12-07, 18:09)fr3qu3ncy Wrote: [ -> ] (2014-12-07, 17:36)Chadman Wrote: [ -> ]Try downloading the logo packs to see some options.
In the thread attached to Milkman's guide (link in the first post). I think the first few links are dead but on the later pages there is a good link.
Can anyone help me with recommending what settings I should use if I want to avoid the long populating/updating that occurs every time I open ptvl?
