Side question... if this has been answered elsewhere please just point me to it.
I autotuned USTVNOW with all 30 stations, but I only have the basic. I turned on Stream Validation, and I figured that would weed those channels out since there is no stream for them, but it didn't.
Is there a step I am missing?
Edit: Is it related to plugin validation level? I searched and found this.
(2014-11-15, 21:18)Lunatixz Wrote: [ -> ]
(2014-11-15, 20:47)BankerBankson Wrote: [ -> ]Can someone briefly explain the function of the "plugin validation level" setting? Hi vs Low?
Leave it on low for now... Low verifies the plugin is installed, High checks to make sure the plugin link is also valid.
Its currently to buggy for casual use.
Edit 2: Tried high validation, didn't work. It just removed all plugin related channels.
Any suggestions?
I am not sure what log to show since my problem isn't really an error. Essentially, my EPG is showing 30 min shows as an hour; it isn't doing it for all of them, but just some and it is seemingly random. All content is .strms.
Oh, and a side question, is there anyway to increase the media limit on Youtube channels? The channel I want has far more than 1000 vids, so it is seemingly just pulling the first 1000 then shuffling those rather than taking 1000 random videos.
(2015-02-19, 05:21)jaynford Wrote: [ -> ]I am not sure what log to show since my problem isn't really an error. Essentially, my EPG is showing 30 min shows as an hour; it isn't doing it for all of them, but just some and it is seemingly random. All content is .strms.
Details? What type of media? Source? Chtype?
As for youtube, 1000 is a reasonable limit. You can try splitting your channel into playlists using one of the many youtube playlist tools available online.
(2015-02-19, 05:44)Lunatixz Wrote: [ -> ] (2015-02-19, 05:21)jaynford Wrote: [ -> ]I am not sure what log to show since my problem isn't really an error. Essentially, my EPG is showing 30 min shows as an hour; it isn't doing it for all of them, but just some and it is seemingly random. All content is .strms.
This was happening with Netflix/Hulu strms that I added to my library using PseudoLibrary. I was doing it using TV Genre channels with rules, but I have switched to Custom Playlist channels and I am having the same issue. I have tried other .strm files from various add ons and I am still getting incorrect guide times.
(2015-02-19, 00:21)Lunatixz Wrote: [ -> ] (2015-02-15, 23:36)earlieb Wrote: [ -> ]@luna,
Think I found a small bug, When adding a channel through the configuration tool of these types: TV Network, TV Show, and playlist, then navigating to advanced channel rules to set the channel name. Once it is saved. It puts a leading space in the settings2 file for the channel name setting. I think this is why some users are reporting that their logos aren't showing up. Thanks. Hope it explained ok.
Thanks, I'll check it out.
This was a great find, I went through my settings2.xml file and every renamed channel had a space in front after the double quote. I removed the space and all the channel logos populated correctly. Thanks for posting the quick fix.
(2015-02-19, 05:57)jaynford Wrote: [ -> ] (2015-02-19, 05:44)Lunatixz Wrote: [ -> ] (2015-02-19, 05:21)jaynford Wrote: [ -> ]I am not sure what log to show since my problem isn't really an error. Essentially, my EPG is showing 30 min shows as an hour; it isn't doing it for all of them, but just some and it is seemingly random. All content is .strms.
Hmmm this is strange because your issue is bypassing all the norms.
1. Strms don't have a duration, unless its been scrapped by kodi or it has a matching nfo with duration info.
2. If no duration is found PTVL should default to 60mins not 30.
3. Playon never returns accurate runtimes, so PTVL uses a lot of guess work.
You will have to use the info above to trouble shoot...
(2015-02-19, 06:10)Lunatixz Wrote: [ -> ] (2015-02-19, 05:57)jaynford Wrote: [ -> ] (2015-02-19, 05:44)Lunatixz Wrote: [ -> ]Details? What type of media? Source? Chtype?
The .strms have been added to the library, so they should have that info. Is there a way I could make PTVL default to 30 mins, I'd settle for that.
(2015-02-13, 15:05)wyild1 Wrote: [ -> ]Morning Luna
I seem to have and issue with 0.5.8d. My screensaver never kicks in any more, nor does the system shutdown after 1 hour of being idle. Had developer fritcsh look at the logs and we removed PTVL and then my screensaver started working again. I think something in PTVL is preventing kodi from going idle.
Forum post: http://forum.kodi.tv/showthread.php?tid=218086
Log: http://xbmclogs.com/show.php?id=424849
Cheers!
I am experiencing this same behavior with the latest PTVL. I will work up a log and post so this can be looked at closer.
Are others having this problem?
Is the repository broken this now? First install here and Kodi reporting that the repository "returned no addons, listing may have failed"
(2015-02-19, 11:25)xexe Wrote: [ -> ]Is the repository broken this now? First install here and Kodi reporting that the repository "returned no addons, listing may have failed"
Force refresh on the repo
(2015-02-19, 12:36)bry- Wrote: [ -> ] (2015-02-19, 11:25)xexe Wrote: [ -> ]Is the repository broken this now? First install here and Kodi reporting that the repository "returned no addons, listing may have failed"
I had previously tried that but for completeness sake i tried again.
Same error. I will remove repos and add again
Edit: I have removed, reinstalled, restarted, check for updates, force refresh and every variation I can think of and every time the log says "returned no addons, listing may have failed".
(2015-02-19, 13:00)xexe Wrote: [ -> ] (2015-02-19, 12:36)bry- Wrote: [ -> ] (2015-02-19, 11:25)xexe Wrote: [ -> ]Is the repository broken this now? First install here and Kodi reporting that the repository "returned no addons, listing may have failed"
Which flavor of kodi are you running?
Experimenting with this in win7 x64 (as I know OpenELEC will be an another hurdle ).
Only just realized I am using 14.0. Upgrading to 14.1 and starting again.
Update: I dug a bit deeper. The repo zip points to "http://raw.github.com/Lunatixz/XBMC_Addons/master/zips" which redirects you to "https://raw.githubusercontent.com/Lunatixz/XBMC_Addons/master/zips" and promptly dumps you to a "Not Found" error.
Well I tried everything I can, does anyone know how to force ptvl to hide channels that have no content? I.E. USTVNOW stations that are no longer subscribed to.
(2015-02-19, 06:01)amcfarla Wrote: [ -> ] (2015-02-19, 00:21)Lunatixz Wrote: [ -> ] (2015-02-15, 23:36)earlieb Wrote: [ -> ]@luna,
I cant find my settings2 xml file on a mac so I just put a space before the file name for the appropriate logos. Worked like a charm!
