(2015-04-30, 23:26)Vaelek Wrote: [ -> ] (2015-04-30, 20:44)bry- Wrote: [ -> ] (2015-04-30, 15:52)johnston0536 Wrote: [ -> ]This interests me as well
only prompts you once if you do not. its suggestion not mandatory
That is not true. It will prompt and refuse to start every single time until you either do as it says or alter the script to bypass it.
I am having thee same problem. Disable the automatic video& music automatic playback notice prevent psudotv live to start. I tried disable in kodis configuration, restart the pc, nothing helps. Thank for anyone that can help.
I'm changing the prompt from "Required" to "Recommended".... and i'll have it only prompt once after each update.
If you use PTVL for any non local content, ie InternetTV, Plugins, Youtube.... Its highly recommended you disable both options.
(2015-05-01, 14:37)Lunatixz Wrote: [ -> ]I'm changing the prompt from "Required" to "Recommended".... and i'll have it only prompt once after each update.
Very nice. Do you happen to have any comment over the "Playback Failed 1/5" messages when hitting stop?
(2015-05-02, 01:56)Vaelek Wrote: [ -> ] (2015-05-01, 14:37)Lunatixz Wrote: [ -> ]I'm changing the prompt from "Required" to "Recommended".... and i'll have it only prompt once after each update.
Don't hit stop
Readme was changed to reflect this info... Proper way to exit PTVL is by hitting: escape,close and previous menu button.
Think of it this way, you don't hit stop on your cable box? you just flip thru channels....
(2015-05-02, 02:11)Lunatixz Wrote: [ -> ] (2015-05-02, 01:56)Vaelek Wrote: [ -> ] (2015-05-01, 14:37)Lunatixz Wrote: [ -> ]I'm changing the prompt from "Required" to "Recommended".... and i'll have it only prompt once after each update.
Don't hit stop
What's a cable box?
It will be a hard habit to break, but very well..
If you don't mine indulging my curiosity, what is the technical reason for this with PTVL? The original PTV and PTV Lite are not affected by this "issue".
(2015-05-02, 03:27)Vaelek Wrote: [ -> ] (2015-05-02, 02:11)Lunatixz Wrote: [ -> ] (2015-05-02, 01:56)Vaelek Wrote: [ -> ]Very nice. Do you happen to have any comment over the "Playback Failed 1/5" messages when hitting stop?
Don't hit stop
What's a cable box?
Review my code, its all open source
Can I get some feedback on 0.6.1c? any users having issues? are we bug free?
(2015-05-02, 03:36)Lunatixz Wrote: [ -> ][Can I get some feedback on 0.6.1c? any users having issues? are we bug free?
points to post
Also, 60mb log still available in bug thread. Will make additional ones if required.
(2015-05-02, 03:36)Lunatixz Wrote: [ -> ] (2015-05-02, 03:27)Vaelek Wrote: [ -> ] (2015-05-02, 02:11)Lunatixz Wrote: [ -> ]Don't hit stop
What's a cable box?
hey luna,
i have a problem with 0.6.1c,
after few minutes the plugin exit without touching mouse or keyboard, without changing channel or doing anything,
it happends every time, no matter what video or what channel im watching,
i tried both with "background updating" on and off, same result.
here is log, hope it will help:
http://xbmclogs.com/p9wfje6ht
thanks
(2015-05-02, 08:27)hasamba Wrote: [ -> ] (2015-05-02, 03:36)Lunatixz Wrote: [ -> ] (2015-05-02, 03:27)Vaelek Wrote: [ -> ]What's a cable box?
hey luna,
here is log, hope it will help: http://xbmclogs.com/p9wfje6ht
thanks
Ive been having this exact problem started today. Im in the middle of working on it... thought it was cuz i added a couple new channels so working backwards from there.... exit happens like clockwork around 6 mins after launch...
(2015-05-02, 08:48)wrichards Wrote: [ -> ] (2015-05-02, 08:27)hasamba Wrote: [ -> ] (2015-05-02, 03:36)Lunatixz Wrote: [ -> ]Review my code, its all open source
hey luna,
thanks
i didnt changed/added nothing...
(2015-05-02, 17:32)phsyraxion Wrote: [ -> ]hey luna,
thanks
Same problem here, the other problem is it keeps channel bouncing (channel times out and it goes to the next channel) especially when its trying to build the guide. I'll see about posting a log if I can figure out exactly how to recreate the problem. It's defiantly exiting the program at random at that's something I've never seen before.
(2015-05-02, 16:48)Lunatixz Wrote: [ -> ]When? after I push v.0.6.1d which will restore the original "customskin" folder and fix some minor issues mentioned here. You can lock in this version by disabling my repo in kodi.
Will the original custom skins folder still work in 0.6.1d? I understand you dropping all the skins temporarily, it turns into an administrative task that takes time away from more important things like core program development. I just want to hear that I can still develop customs skins and run/test them on my own rig moving forward beyond 0.6.1d. even if official support has been temporarily suspended.
the future looks bright, awsowme stuff commin
im continueing to to resolve the program exit problem.. any leads would help
EDIT: Update to d1 resolved problem. Thnak You
