(2015-05-22, 07:30)tromy Wrote: [ -> ]Quote:Added EPG/Overlay Artwork multi-threading, this should improve performance. Artwork is disable until channel building is finished only when background building is enabled.
Current build no longer needs the "Artwork Spooler" all artwork is queued/downloaded on demand. [Experimental]
This is the major update!No lag,epg runs like formula 1!
Great work
Agreed. I turned all of my art back on and it FLIES.
(2015-05-22, 09:57)RamboUnchained Wrote: [ -> ] (2015-05-22, 07:30)tromy Wrote: [ -> ]Quote:Added EPG/Overlay Artwork multi-threading, this should improve performance. Artwork is disable until channel building is finished only when background building is enabled.
Great work
Yup, What they said. This update has made both instances of my PTVL installs work ridiculously fast with all the bells and whistles turned on! Outstanding work, BRAVO!
maaaaaaaaaaan, you are the king!
seems to me the best build ever, can't see any bugs and it works great.
this week i finally had the guts to ditch cables,
and it's not easy when you have a wife and 3 kids that like tv,
kodi alone is not not enough for me to leave cables but kodi with stable PSTL is.
thanks alot.
keep up the amazing work.
seems I have an issue on my end. going to really need to sit down and see what crap is holding up the update.
congrats on the glowing responses to the new release.
(2015-05-22, 03:54)Lunatixz Wrote: [ -> ]V.0.6.2 pushed to repo... it's a major update, reworked 1080 skin, lots of fixes, tweaks and new features!
Including youtube fix! Check out Changelog for details: https://raw.githubusercontent.com/Lunati...ngelog.txt
Just a heads up...
I just got my donor username:password (thanks by the way...)
and I was having a hell of a time getting it to work...
turns out that I was being blocked from accessing
pseudotvlive.com
even though it showed active on
http://www.downforeveryone.com/
so after some digging it appears that if I change my dns settings to anything other than my internet providers dns
It works just fine. (currently just changed it to OpenDNS )
My only guess is that my provider (charter) is blocking the IP for
pseudotvlive.com
this could be an error that will fix itself...
However, my fear is that they are targeting pseudotvlive
Is anyone else having trouble with channels using Youtube? I've got a music channel that's set to a playlist with 299 videos, but PLTV is only wanting to scan 49 of those videos and it'll just stop. The channel's media limit is 500 and it used to work just fine in older PLTV versions.
Another channel is set to RT's Youtube channel and it's only scanning 40 out of 250 videos too.
Edit: Looks like it's something to do with the Youtube new coding. Not sure why it's giving numbers like 49 or 40 though
Has FilmOn support been dropped? I don't see it as an option in the auto-tune section anymore(FTV favorites). I'm guessing a link could be added manually, but was there epg created when it was in autotune?
I noticed the EPG categories in the guide: EPG/DVR/ADDONS?(at work, not sure of order). I tried navigating to these sections with my remote, but gave up and tried clicking on them with the mouse. Are these supposed to be accessed this way, or is it something on my end?
Is the side bar supposed to auto-hide so quickly/at all? I scrolled down to a button to read the scrolling text(couldn't tell what it did), and the bar closed before I had a chance to see what it was.
The EPG is much quicker on this version just from my initial use. Thanks for the update @
Lunatixz
I only wish Even Show Distribution worked... :-)
...does this update include a fix for Isengard or nah…?
might just be me... the on-demand button dosent seem to be working in the pstvl SIDE memu window... is it just me?
VERY VERY HAPPY with it up and running again, everything is snappier the art spool dosent seem to be a problem anymore. YT is back baby! thank you!!! with the exclusion of my comcast skin, ill just PS default. all good
Thank you again
I haven't said anything on these forums in a long time. I've been using Live since the start as well. This newest update is insane man. Well f'ing done. Flies like lightning now and the new guide looks amazing. Thanks so much for all you do on the best addon there is.
Hey guys! Does Directory channel type not grab metadata? How does one create a movie channel (local content) grabbing movies from collection? Movie genres works great but I want a movie channel that will grab all movies from the directory with epg data.
Will ANYONE please respond? Isengard support or no??
