(2015-07-13, 15:52)hasamba Wrote: [ -> ]Hey Luna,
couple of features i would like to see in PSTL:
1. when creating a live tv channel from plugin, the channel manager resolve the link/feed, its good in some cases but for free iptv services its usually a problem beacuse the link is changing every day or two, maybe a pointer like in "plugin type" can be done.
2. when my kids watch their movies channel, they like to press "i" and then "right arrow" to see the next movies (they look at the artwork and doesnt read the text), sometimes they can move 20 movies ahead until they find what they want, the problem is they cannot press "enter" to start the movie, the should close the info and start pressing ">" 20 times.
3. sometimes, something happen to the settings file and pstl ask to autotune, usually when it happends to my kids or wife they restart kodi and same shit happends again, but now the settings2 backup also gets deleted, im keeping a backup outside the folder but for the rest maybe its better to let the user choose how many backups to keep.
4. bring back "on demand"! i hate closing PSTL to find a "special request".
thanks.
1. PTVL is a middle man... if you want a "plugin" type link for a changing stream... you need to find a developer willing to create one
2. I'll look into it.. but it was designed as a preview, not a skip ahead.
3. Need to see a log, backup/restore isn't perfect.
4. On demand was brought back ask you requested... "Browse" in the sidebar... the new "Ondemand" menu is a WIP
[Update] - 2. feature added to next update... please next time post feature requests in the proper thread
http://forum.kodi.tv/showthread.php?tid=221353
(2015-07-13, 16:49)Lunatixz Wrote: [ -> ] (2015-07-13, 15:52)hasamba Wrote: [ -> ]Hey Luna,
thanks.
1. let me try to clarify, when im choosing in channel manager "internet tv" and "plugin", then browse to a plugin like vdubt and choose "cartoon network", PSTL translate it the ip address of the feed (doesn't leave it as plugin.vdubt/cartoonetwork/), later the developer change the "cartoon network" link to another feed, PSTL will no longer work.
in "plugin" chtype, for example plugin.reddit/funny... on each update PSTL will check for changes...
the behavior is different, if it was the same than the "internet tv" will continue to work.
2. thanks
3. i didn't talked about the option to backup/restore, i talked about the automatic backup that happends on every PSTL run, i cannot get a log because i cannot recreate the error on demand.
i didn't mention this issue as a bug, i thought that a feature that will let users decide how many settings2 backups they would like to keep before overwriting the 1st one would be nice, im sure there are and there will be alot of users that will not keep backup aside and will lose alot of configuration they work for.
4. thanks
5. again, i will love to be able to use non-english (hebrew) plugins with PSTL, alot of hebrew users that im talking with on forums about PSTL doesn't want to hear about it because of this reason.
6. you are the best
(2015-07-12, 21:38)digimars Wrote: [ -> ]Could someone help me with Best-Effort Channel Scheduling?
I have the following setup:
AdultSwim on channel 77
CartoonNetwork on channel 78
The intent is to have the AdultSwim channel NOT show up in the EPG, and only have it play on channel 78 starting at 9 PM every night.
Channel Number: 77
Days of the Week UMTWHFS
Time: 21:00
Episode Count: 20
Starting Episode: 136 (? this seems to randomly change)
Starting Date: 14/07/2015 (? Not what I entered, this seems to randomly change as well)
Here is a snippet from my settings2.xml (Note that this is from the very end of the file):
<setting id="Channel_78_type" value="0" />
<setting id="Channel_78_1" value="special://profile/playlists/video/CartoonNetwork.xsp" />
<setting id="Channel_78_rulecount" value="4" />
<setting id="Channel_78_rule_1_id" value="1" />
<setting id="Channel_78_rule_1_opt_1" value="CartoonNetwork" />
<setting id="Channel_78_rule_2_id" value="17" />
<setting id="Channel_78_rule_2_opt_1" value="No" />
<setting id="Channel_78_rule_3_id" value="15" />
<setting id="Channel_78_rule_3_opt_1" value="Yes" />
<setting id="Channel_78_changed" value="True" />
<setting id="Channel_77_type" value="0" />
<setting id="Channel_77_1" value="special://profile/playlists/video/AdultSwim.xsp" />
<setting id="Channel_77_rulecount" value="1" />
<setting id="Channel_77_rule_1_id" value="17" />
<setting id="Channel_77_rule_1_opt_1" value="No" />
<setting id="Channel_77_rule_2_id" value="5" />
<setting id="Channel_77_changed" value="False" />
<setting id="Channel_78_rule_4_id" value="3" />
<setting id="Channel_78_rule_4_opt_1" value="77" />
<setting id="Channel_78_rule_4_opt_2" value="UMTWHFS" />
<setting id="Channel_78_rule_4_opt_3" value="21:00" />
<setting id="Channel_78_rule_4_opt_4" value="20" />
<setting id="Channel_78_rule_4_opt_5" value="136" />
<setting id="Channel_78_rule_4_opt_6" value="14/07/2015" />
<setting id="Channel_78_lastscheduled" value="137" />
<setting id="Channel_77_2" value="" />
<setting id="Channel_77_3" value="" />
<setting id="Channel_77_4" value="" />
Now for some reason, when I put in the start date, it always changes the start date after I save it, and the starting episode (which I assume should be set to "1", I'm not sure as documentation on this particular feature seems scant) gets randomized to some other odd number.
How can I get this feature to work? This is a fully updated OpenELEC Kodi install using PTVL 0.6.4.
I got this to work last night. I corrected the date entry (it kept wanting to arbitrarily pick a date two days out) and ran the configuration cleanup tool. My Adult Swim schedule kicked off just fine after that.
Due to cost overhead, I'm forced to move ptvlguide.xml data to donor only. What is ptvlguide? it's a xmltv file filled with useful tv listings for varous online source (ilive,pluto.tv,ustvnow,sky,filmon,etc). The free ptvlguide will go offline in three days, and online for donors with the next update.
(2015-07-14, 19:29)Lunatixz Wrote: [ -> ]Due to cost overhead, I'm forced to move ptvlguide.xml data to donor only. What is ptvlguide? it's a xmltv file filled with useful tv listings for varous online source (ilive,pluto.tv,ustvnow,sky,filmon,etc). The free ptvlguide will go offline in three days, and online for donors with the next update.
Does this mean no updates for three more days?
Also I went to the website and I'm not seeing anything new there. Regardless, congratulations on two years of PseudoTV Live! Looking forward to seeing what the future brings!
Thanks for everything!
Out of curiosity, how many hits a day were you getting on that file? From my own experience, I bet it was an astronomical amount?
ok, WTF happened? i cant get to any menus anymore, it leads me to standard kodi, i cant get up the EPG anymore.. everything is wacked? whats that? this program seems to reverted to nothing..run away channel loads, no control... whats happening?
(2015-07-16, 03:33)wrichards Wrote: [ -> ]ok, WTF happened? i cant get to any menus anymore, it leads me to standard kodi, i cant get up the EPG anymore.. everything is wacked, and HUB edition? whats that? this program seems to reverted to nothing..
Any logs? Also, bugs should be reported to the bug thread.
(2015-07-16, 03:34)ryanmcclure Wrote: [ -> ] (2015-07-16, 03:33)wrichards Wrote: [ -> ]ok, WTF happened? i cant get to any menus anymore, it leads me to standard kodi, i cant get up the EPG anymore.. everything is wacked, and HUB edition? whats that? this program seems to reverted to nothing..
this is more than bug, is it running correct for you? can u get to the menus? tell me this is running as expected for you or anyone and ill do hard debug on my end, as is, have no idea if its just me its running wild. after inital load any attempt to get to epg defaults me to kodi interface, cant get back to guide, just dumps me into kodi. doing complete uninstall reinstall but totaly wild
(2015-07-16, 03:33)wrichards Wrote: [ -> ]ok, WTF happened? i cant get to any menus anymore, it leads me to standard kodi, i cant get up the EPG anymore.. everything is wacked? this program seems to reverted to nothing..run away channel loads, no control... whats happening?
Probably your unsupported custom skins?
(2015-07-16, 03:51)Lunatixz Wrote: [ -> ] (2015-07-16, 03:33)wrichards Wrote: [ -> ]ok, WTF happened? i cant get to any menus anymore, it leads me to standard kodi, i cant get up the EPG anymore.. everything is wacked, and HUB edition? whats that? this program seems to reverted to nothing..run away channel loads, no control... whats happening?
no i never use it untill i make sure everything is perfect with the update.. have no idea.. sorry for the freak out, keeps kicking me to kodi interface cant get epg back up once it kicks me to kodi. ill edit all these posts im just freaking out, bouncing to bug forum...
(2015-07-16, 03:55)wrichards Wrote: [ -> ] (2015-07-16, 03:51)Lunatixz Wrote: [ -> ] (2015-07-16, 03:33)wrichards Wrote: [ -> ]ok, WTF happened? i cant get to any menus anymore, it leads me to standard kodi, i cant get up the EPG anymore.. everything is wacked, and HUB edition? whats that? this program seems to reverted to nothing..run away channel loads, no control... whats happening?
Do u use yatse remote?
relax with the bug posts, bug thread requires logs!!
not that i know of... should i?
using standard keyboard no mods with same results... just someone tell me its working as expected on thier systemand ill tear my system apart to find to problem. it was perfect on last update. 4.b is what im asking about Beauler Beauler?
ill check back in a few hours.. loosing it and low on red bull
ok tracked it down to the mouse, im used to rt clicking to get out of things, if i rt click on the mouse, i loose all access to pstvl anythinng and it locks me into kodi standard interface, only way out is to hard close kodi flush memory and restart kodi/pstvl.. so on my end its connected to the mouse.
"It's working fine for me personally. What version of Kodi are you on? (You may have posted it...I just can't find it)"
sticking with helix untill isenguard supports pip
yea defintly a mouse issue triggering this, using only keyboard and or remote is fine, anything with mouse causes my problem... at least with me, anyone confirm this or jst me..
(2015-07-16, 04:12)wrichards Wrote: [ -> ]Do u use yatse remote?
