(2015-07-16, 04:12)wrichards Wrote: [ -> ]Do u use yatse remote?
not that i know of... should i?
using standard keyboard no mods with same results... just someone tell me its working as expected on thier systemand ill tear my system apart to find to problem. it was perfect on last update. 4.b is what im asking about Beauler Beauler?
before I push a release I run it in my house for at least a day or two... it was okay by me so I pushed the update.
did u try rebooting system, uninstalling and reinstalling ptvl?
"before I push a release I run it in my house for at least a day or two... it was okay by me so I pushed the update.
did u try rebooting system, uninstalling and reinstalling ptvl?"
yea complete reboot, re-install mem flush, seems to be the mouse at least for me on my end.. i really try to be complete before posting (no really), just have no idea if its just me initaly your pretty damn good at the releases and theres no way you could reproduce every combination of systems out there. I run this program on several systems with varying configs, so i try a couple of my systems before i post
"It's working fine for me personally. What version of Kodi are you on? (You may have posted it...I just can't find it)"
can you try playing w a mouse for selection and rt button see if its acting up for u? this would dtop me from pulling out my hair.. thanks again for the feedback, i lost it there for a min sorry everyone
(2015-07-16, 04:38)wrichards Wrote: [ -> ]"It's working fine for me personally. What version of Kodi are you on? (You may have posted it...I just can't find it)"
I use a remote for my PTVL rather than a mouse, so am stuck with basically a "keyboard" setup, if you will.
Mouse?? PTVL doesn't support mouse functions... if it works or worked, that was just a chance thing...
did you enable the global context menu? thats not working yet and could cause issues...
"Mouse?? PTVL doesn't support mouse functions... if it works or worked, that was just a chance thing...
did you enable the global context menu? thats not working yet and could cause issues..."
the mouse is a habbit somtimes, as im running pstvl usualy in a window while im surfing or such. as it stand now, it seems to be working fine AS LONG AS I dont rt click the mouse while pstvl is an active window. again this is new to 4.x didnt happen in all pervious incarnations. I did notice the global contex menu item in settings but didnt touch it.
hope this helps, i doubt im the only one doing other things whith pstvl is in a window..
anyway now I know on my end not to use mouse.
also noting a much longer delay to bring up menus or esc to exit them, with the "delay" option in settings unchecked.
(2015-07-16, 04:49)wrichards Wrote: [ -> ]"Mouse?? PTVL doesn't support mouse functions... if it works or worked, that was just a chance thing...
k, i think my global context code is running when it's not meant to... thought I left it all disabled...
if that's the issue it will be fixed in v.0,6.4c
First of all, thanks for the update and fixing Donor for us. I really missed having almost three hundred channels and when things were broken I was reduced to only a hundred channels. Glad to see my numbers back up.
Secondly I have to ask if this is planned or completely random? I went to the VH1 Classic Channel and immediately encountered Rick Astley singing "Never gonna give you up"!!!
Finally I have my information in USATVNow, but I seem to be getting random ghost channels from there. Will post link to a log in the bug thread once PseudoTV finishes exiting.
(2015-07-16, 05:36)bornagainpengui Wrote: [ -> ]First of all, thanks for the update and fixing Donor for us. I really missed having almost three hundred channels and when things were broken I was reduced to only a hundred channels. Glad to see my numbers back up.
lol then don't update to v.0.6.4b, I disabled all com and donor stuff while I update a few things.
Sorry...
(2015-07-16, 05:36)bornagainpengui Wrote: [ -> ]I went to the VH1 Classic Channel and immediately encountered Rick Astley singing "Never gonna give you up"!!!
Rick-rolled by PTVL...you have just won all of the internet!
(2015-07-16, 06:05)Lunatixz Wrote: [ -> ] (2015-07-16, 05:36)bornagainpengui Wrote: [ -> ]First of all, thanks for the update and fixing Donor for us. I really missed having almost three hundred channels and when things were broken I was reduced to only a hundred channels. Glad to see my numbers back up.
Sorry...
Ahhhh! :exclamation:
I really wish I'd had seen this before I updated it...
Posted in the suggested features thread. Also, do you automatically get logs submitted via program settings or do we manually need to log in to the email and post the link in the bug thread? Asking to avoid spamming you with logs.
(2015-07-16, 08:00)ryanmcclure Wrote: [ -> ] (2015-07-16, 05:36)bornagainpengui Wrote: [ -> ]I went to the VH1 Classic Channel and immediately encountered Rick Astley singing "Never gonna give you up"!!!
I know right?
luna
Just out of curiosity what do you use for a controller in the living room? Seems to be my biggest hurdle to overcome finding something that "fits".
(2015-07-16, 16:13)XvMMvX Wrote: [ -> ]@luna
I use my old cable remotes, from when I had a settop cable box... They are remapped using Eventghost...
So i feel like im retarded.
I try to activate community lists with inputting a gmail address. Is this the gmail account i set up with at pseudotvlive.com or just any random one or what? No matter what i enter, it doesnt verify it for me.
Donor activates fine, just cant activate community lists.
Any help?
(2015-07-16, 16:22)aib37 Wrote: [ -> ]So i feel like im retarded.
Any help?
i made a special user just for that (as luna suggested) and it works ok, i submitted several channels yesterday
Go buy a flirc from flirc.TV or Amazon. You can use any existing remote.l with them.
