(2015-03-13, 01:16)ss4johnny Wrote: [ -> ]Thanks for your reply Dan. The zip trick worked. You might want to make a list of little tricks like that whenever they come up. Community might find it useful.
I've added "Clear cache" to the tv show context menu.
Anyone else have problems with remove --> Delete Movie (aka ctrl + delete)? I don't get any reaction at all when I try to do this. Worked in the last version for me. Not sure its a bug though. I'm running Windows 10 and updated EMM at the same time as the new version arrived. So hard to know witch one is the culprit. I get this error in the log.
[i][i]2015-03-20 19:49:09.4879 Ember_Media_Manager.frmMain Ember_Media_Manager.frmMain.cmnuMovieRemoveFromDisk_Click 1 ERROR cmnuMovieRemoveFromDisk_Click "EXCEPTION OCCURRED:System.ArgumentException: Det gick inte att hitta kolumnen med namnet idEpisode.
Parameternamn: columnName
vid System.Windows.Forms.DataGridViewCellCollection.get_Item(String columnName)
vid Ember_Media_Manager.frmMain.cmnuMovieRemoveFromDisk_Click(Object sender, EventArgs e)* vid System.Windows.Forms.DataGridViewCellCollection.get_Item(String columnName)
vid Ember_Media_Manager.frmMain.cmnuMovieRemoveFromDisk_Click(Object sender, EventArgs e)"[/i][/i]
Thanks alot for you awesome work!
(2015-03-20, 20:51)Gonzo Wrote: [ -> ]Anyone else have problems with remove --> Delete Movie (aka ctrl + delete)? I don't get any reaction at all when I try to do this. Worked in the last version for me. Not sure its a bug though. I'm running Windows 10 and updated EMM at the same time as the new version arrived. So hard to know witch one is the culprit. I get this error in the log.
Known bug and already fixed for next release.
(2015-03-23, 23:49)solamnic Wrote: [ -> ]ETA on next release?
Nearly done as always. Working on last steps of new features and creating new bugs ;-)
Think of a dark-skinned for their program. For it is clear, glare
(2015-03-25, 19:14)quade1337 Wrote: [ -> ]episode folder support
I've added new regex system for episodes.
I think now we can start to add the support for episode folders.
I'm just writing the changelog for a new release, but this will be without episode folder support.
New release 1.4.3.0 (2015-03-25) is online!
Changelog 1.4.3.0 (2015-03-25)
[Main]
fixed: CodecMapping is always converted to lowercase
fixed: ComboBox settings will not be saved after settings panel has changed
fixed: "Edit Actor" dialog size
fixed: bug with movie rating scraping
fixed: "Remove Movie from Disk"
fixed: confusing description of tv show reloading/refreshing
fixed: error with episode subtitles recognition/saving
fixed: "Clear All Cache" in tools menu (works now)
fixed: SQL error in "Movie Source" dialog
fixed: movie InfoPanel state after closing settings dialog
fixed: "Custom Scraper" New/Marked movies
fixed: movie/movieset/tvshow ID are not always trimmed after reading from NFOs
fixed: missing linktable cleaning in database
fixed: "Clean DB" does not remove all orphaned entries
fixed: "Clean DB" and "Clear All Cache" is not enabled if all lists are empty
added: option to disable "Image Select" dialog while single movie scraping
added: some checks to block editing/scraping if a movie/tv show/episode file/path is offline
added: option "Get Year from folder/file name" for movie sources
added: preferred tv show/season poster size "1000x1426"
added: more options for theming
added: a dark infopanel theme
added: "TMDB ID" to movie InfoPanel
added: new tv show regex system (based on Kodi regex system)
added: ability to add a custom rating string for not rated movies/tv shows
added: option "Use digit grouping symbol for Votes count" (based on Windows region settings)
added: field "Collection ID" to "Scrape Single Field" menu
added: DiscArt for MovieSets (as expert settings, MSAA does not support DiscArts)
added: new setting to add episode "Guest Stars" to actors list with role "Guest Star"
added: "Clear Cache" to tv show context menu
changed: replaced "Pref Movie(-Set) Banner Type" with "Banner Size"
removed: "Tags" from global movie scraper settings (we do not want support that)
[Renamer]
fixed: renamer does not rename new movies/episodes
fixed: some issues in preview
fixed: $D and $F support for season/episode renamer
fixed: episode actor thumbs folder handling
added: "Reset" button for all pattern fields
[Apple Trailers]
fixed: no download possible if preferred quality is set to "All"
[Trakt.tv]
fixed: episode playcount synchronization
fixed: database traffic while syncing
added: option to disable "Progress" status (get information faster from Trakt.tv)
[TMDB]
added: "Year" textbox to "Movie Search Results" dialog
[TVDB]
added: option to scrape episode "Guest Stars"
[MovieExporter]
fixed: some issues with new database
@Dan..
MANY THANKS ... for the new version...
Found two bugs, working on a hotfix:
- episode renaming does not work
- no TMDB search results if no year is set
New hotfix-release is online!
Changelog 1.4.3.1 (2015-03-25)
[Renamer]
fixed: episodes can not be renamed
[TMDB]
fixed: bug while search movies on TMDB
[MovieExporter]
fixed: no tv show list in exports
Also please check out the reactivated theme support - you can style your own template for right side view in Ember, i.e.
(check template in Theme folder)
