(2015-08-14, 11:04)DanCooper Wrote: [ -> ] (2015-08-11, 11:47)solamnic Wrote: [ -> ] (2015-08-10, 17:19)DanCooper Wrote: [ -> ]I've checked your mail and found an unknown bug in movie source dialog... but that have nothing to do with your problem. But i think i know what can be the problem...
Please check if you have added your movie source(s) with Movies are in separate folders setting enabled. Otherwise it's not possible to rename movie folders.
I don't know if it works if you change this settings on an already existing source. Maybe you have to remove and readd the source to get work.
will do as soon as i return home and inform of the results
Any news with this issue?
sorry for the delay i was away due to work..
I have checked the separate folders, but still no luck... (also tried with separate folders unchecked... still nothing)
(2015-08-20, 19:08)solamnic Wrote: [ -> ] (2015-08-14, 11:04)DanCooper Wrote: [ -> ] (2015-08-11, 11:47)solamnic Wrote: [ -> ]will do as soon as i return home and inform of the results
You can't change the "separate" settings for already added movies. You have to remove this source, close settings to clean the database and readd the source with correct settings.
(2015-08-20, 19:36)DanCooper Wrote: [ -> ] (2015-08-20, 19:08)solamnic Wrote: [ -> ] (2015-08-14, 11:04)DanCooper Wrote: [ -> ]Any news with this issue?
it works... that seemed to be the problem..
thank you...
EMM seems to hang when I try to scrape a whole season of some TV series. I've scraped two different series (Star Trek TNG season 7 and Agatha Christie's Poirot season 5) and both hang after I finish the TV image selection. After that, I cannot on anything to make it work and there is no indication of anything going on. The only thing that works is File --> Exit or Donate. After exiting, it seems that everything's all right as all the necessary files are there in the series folder.
Known bug, please read the hints in download thread.
... and don't click Exit, use the Donate button ;-)
Hi guys
here is a short update of the upcoming release:
We are still working on some major bugs with episode scraping. There are some problems with multi episodes that are difficult to solve.
We also need to find a suitable solution to the problem that TMDB only uses the sorting method "Aired".
The Kodi Interface works for nearly perfectly (big up to Cocotus!) and it will make syncing with Kodi perfect.
We have also fixed nearly all known bugs. But do not worry, there will certainly be new and exciting bugs;-)
I'm currently working on new still image Select dialog. Filters are still missing, everything else works so far. Here's a screenshot:
This is one of the biggest code change we have ever done (approximately 270'00 lines of code). We have improved nearly all of the processes, the handling will now be much faster than yet.
So you can be curious if it is finally over. And no, I can not give an exact date.
Have a nice evening!
That's a real teaser
Can' wait to test it when you are ready
hehe this is like to hold a bottle of whiskey infront of an dry alkoholic
looks realy promissing - and better wait a bit longer and it works ( almost ) perfect - not like M$ or any other Game developer right now - first release something, wait for feedback and maybe one year later you will have an "almost" finished product
well done so far Team EMM !
A small glitch: some of my 4:3-aspect ratio movies are being marked as 576p even though they have a vertical resolution of 720 pixels.
(2015-08-23, 14:40)Boulder Wrote: [ -> ]A small glitch: some of my 4:3-aspect ratio movies are being marked as 576p even though they have a vertical resolution of 720 pixels.
Please add a ticket on our
Bug Tracker. Thx.
(2015-07-02, 22:15)Cocotus Wrote: [ -> ] (2015-07-01, 23:11)deh2k7 Wrote: [ -> ] (2015-06-25, 23:51)DanCooper Wrote: [ -> ]AD is crappy ;-) But we are working on a Kodi JSON interface addon to add all this extra arts directly to Kodi without AD or MSAA (for MovieSets).
Dan this would be FANTASTIC! I'm not happy with AD - it's very slow, and is a bit difficult to get the settings right. Plus the mod owner doesn't seem to like answering questions or receiving feedback about how to make things work more simply.
Is this a change coming soon or something that's farther out?
Im working on it right now
Some screenies from new KodiInterface module in Ember:
Right now it looks I will finish direct syncing of Ember movies/episodes to Kodi from context menu this weekend I think. I will probaby add some general functionality like "Updating Kodi Library", "Clean Library" in main menu bar too for a first release
Real time syncing support (meaning keeping Kodi and Ember library up to date and synced in backgroud all the time automatically) will still probably take some time though, but for a first step the above should be sufficient. Stay tuned!
This is so freaking awesome! I created the Feature Request ticket for this on your Bug Tracker way back when. I have long missed this feature and am so pumped it's coming back. I can't wait for the next beta. I had given up on ever seeing this again and just so happened to check the ticket yesterday (I don't even know why as I hadn't checked on it in over a year). I literally did a double take because I couldn't believe my eyes at first. Thanks so much for not forgetting about it all together.
You are absolutely right that your initial implementation is a great and welcomed first step. Hell, even if we never get anything more advanced it's still cool. But - and please don't take this to be unappreciative in any way! - real time syncing is the absolute best and would the cat's meow! Just so you know there are users who would look forward to it if that helps make it any more worth your time and effort to further develop it.
Thanks again and can't wait fir the release!!!
(2015-08-23, 00:26)DanCooper Wrote: [ -> ]This is one of the biggest code change we have ever done (approximately 270'00 lines of code). We have improved nearly all of the processes, the handling will now be much faster than yet.
Impressive. Keep up the good work!
