(2014-02-12, 19:56)Shryukt Wrote: [ -> ] (2014-02-12, 19:46)Cocotus Wrote: [ -> ]Thats weird -should more look like this:
Yeh I know ^_^
I use the 1.3.0.18 and an a previous beta and everything is ok (except béta bugs ^^) but this one... no way.
Maybe I miss something :
- I DL the .zip
- unzip
- start Ember Media Manager.exe
and ... voila ^_^
Ha ok, well I would suggest just to try the next version (Dan will post soon) and check if that works for you
(2014-02-12, 20:51)T-bird_se Wrote: [ -> ] (2014-02-12, 19:50)DanCooper Wrote: [ -> ]New release in 3h btw...
If you got time take a look at this bug
I sad yesterday that something was wrong in TVDB settings and now I now what
You can't change any setting for TVDB, the apply button never lights up, the only work around I found is to start write in api key field
Make your changes and clean api field, you are forced to a restart but you get your setting saved
And the leading text is wrong, it's not global setting it's scraper specific
And last, if you unactivate most modules you get massiv errors, I only run with renamer and notification active, all other is off
I'll fix it.
Hmmm, are you sure that there are errors and not tracer logs?
Great!
(2014-02-12, 10:53)DanCooper Wrote: [ -> ]Please don't remove or change the project settings, Dekker500 has fix this for futurer x64 support, see commit on GitHub: Link
I think the only "x86 only" file is MediaInfo.dll. I will try to build in x86 and x64.
Ok, will look into it and see if I find a solution.
(2014-02-12, 22:31)DanCooper Wrote: [ -> ] (2014-02-12, 20:51)T-bird_se Wrote: [ -> ] (2014-02-12, 19:50)DanCooper Wrote: [ -> ]New release in 3h btw...
I'll fix it.
Yes i'm sure
The error window pops up and this is an example from the log
[2014-02-12 19:31:35.7641;Ember_Media_Manager.dlgSettings;EmberAPI.ErrorLogger.Error;1;ERROR;"Objektreferensen har inte angetts till en instans av ett objekt.
vid generic.EmberCore.MovieExporter.MovieExporterModule.Disable() i C:\Users\Massimo\Documents\GitHub\Ember-MM-Newscraper\Addons\generic.EmberCore.MovieExport\Module.MovieExporter.vb:rad 101
vid generic.EmberCore.MovieExporter.MovieExporterModule.SaveSetup(Boolean DoDispose) i C:\Users\Massimo\Documents\GitHub\Ember-MM-Newscraper\Addons\generic.EmberCore.MovieExport\Module.MovieExporter.vb:rad 187
vid Ember_Media_Manager.dlgSettings.SaveSettings(Boolean isApply) i C:\Users\Massimo\Documents\GitHub\Ember-MM-Newscraper\EmberMediaManager\dlgSettings.vb:rad 4112"
New beta 2014-02-13 online, check first post.
Please use our Bug Track website:
http://www.bugs.embermediamanager.org
Changelog Ember Deploy 2014-02-13:
IMPORTANT:
- Ember requires from now on NET4.5 Framework installed! (before NET3.5)
- API Keys for all scrapers are now included in Ember! You can leave all API Key field empty. But you need a own TVDB API Key if you want use EpsisodeGuideURL
- Expert settings for movies are not fully integrated (NO Actor Thumbs, Extrafanart, Extrathumbs)
Changes:
- Added: .watched files for YAMJ @DanCooper
- Added: "Protect VIDEO_TS and BDMV Structure" setting. This will leave the VIDEO_TS and BDMV folder untouched (works only with Frodo, in this mode is not possible to save trailers, actor thumbs, extrafanarts or extrathumbs)
- Added: Expert Settings to allow custom naming scheme like (ie. movie.nfo, poster.jpg, fanart.jpg). You can use multiple filename, separated by comma: movie.nfo,<filename.nfo> @DanCooper
- Added: scraping title with year from folder/file @DanCooper
- Added: new Offline Media Manager (beta) @DanCooper
- Added: x86 and Any CPU to all projects to remove mixed processor builds. This is a pre-cursor to future x64 support. @Dekker500
- Added: Export movie (HTML Export) allows multiple <$MOVIE> loops @locuester
- Added: New global data scraper setting ("Always overwrite english plot/outline") @Cocotus
- Added: Clean Plot/Outline setting for data scraper -> will remove all brackets from plot (often used for actor name) @Cocotus
- Added: Updated HTML Export module in BETA 1.4 @Cocotus
- Added: Label of Ember version number is now docked on right side on main view -> update notification enabled @Cocotus
- Added: First implementation of poster & fanarts for movie sets (=Movie Set Artwork Automator plugin support (Single Folder configuration), Link: http://forum.xbmc.org/showthread.php?tid=153502) @Cocotus
- Added: DAEMON ToolsLite/VirtualCloneDrive Support -> Optimized DVD/BLURAY ISO metadata scanning @Cocotus
- Added: Moviepilot data scraper for german users, for german certification (FSK)/Outline scraping @Cocotus
- Added: extrathumbs and extrafanart @DanCooper
- Added: default to Frodo if no Use... selected @msavazzi
- Fixed: TVDB scraper settings save and load precedere
- Fixed: Set and activate default scrapers if no other is enabled after Install Wizard: movie data -> TMDB_Data, movie poster -> TMDB_Poster, movie trailer -> TMDB_Trailer, tv show data/poster -> TVDB_Data_Poster @DanCooper
- Fixed: Tweaked internal scraper/trailer behaviour @DanCooper
- Fixed: OFDB title handling @DanCooper
- Fixed: settings windows size & panel sizes @DanCooper
- Fixed: error if no IMDBID found on TMDB (japanese porn error) @DanCooper
- Fixed: reset scraper settings for EditMovie - now the Actorthumbs are not always reloaded when closing @DanCooper
- Fixed: renamer removes all dots in folder and filename @DanCooper
- Fixed: find year regex @DanCooper
- Fixed: path error while trailer scanning (VIDEO_TS/BDMV issue) @DanCooper
- Fixed: ConvertToSingle handling in Ember - User culture bug @Dekker500
- Fixed: Correct Open Issue Link Location in Error Viewer @QStick
- Fixed: labels in TMDB/TVDB - Fixed null values TMDB scraper @msavazzi
- Fixed: updated ffmpeg and MediaInfo @msavazzi
- Fixed: IMDB/TMDB data scraper behaviour (now scraper won't save empty scrape results and therefore overwrite existing data with empty values) @Cocotus
- Fixed: Metadata Language error messages @Cocotus
- Fixed: Only show movie on right side of setmanager if not already part in any movieset! (XMBC doesnt support movies belonging to multiple sets!) @Cocotus
- Fixed: Metadata AudioChannel error messages @Cocotus
- Fixed: Abbreviated Movie Titles that start with "A" are not handled correctly @Cocotus
- Fixed: Enabled/Disable of OFDB DataScraper @Cocotus
- Fixed: Use Metadata duration for NFO Runtime setting -> now correct duration will be stored in NFO if that settings is enabled @Cocotus
... and many thanks to all translators for their hard work!
First of all: Thanks for this great piece of software!
...although I seem simply unable to get any trailers at all.....(using today's (Feb 13, 2014) beta) :/
Options set:
Movie Scraper: TMDB
Image Scraper: TMDB / Fanart.tv
Scrapers General:
Enable Trailer Support (check)
Overwrite Existing (unchecked)
Delete Existing (unchecked)
Preferred Quality: 720p
Trailer Scraper: TMDB (switching to IMDB doesn't work either)
tried both own and no API keys, Preferred Language: en
Behaviour:
trying to add trailer to existing movie.
-> Edit movie
-> add trailer (the little green + icon in the movie details window)
-> Ember crashes with error message: Class not registered (Exeption from HRESULT: 0x80040154 (REGDB_E_CLASSNOTREG))
did I do anything wrong? and if yes, what was it? or is trailers simply not really implemented yet? (if that: sorry!)
thanks again for coding Ember.
Still the same bug for me
I tried to update net framework but it's up to date.
I tried on an another PC but same bug
I'm on windows 8.1 pro
I really don't understand.
Currently, Adobe Flash Player is required, otherwise it returns the error "Class not registered".
But we are already trying to replace the Flash Player by VLC (not everyone likes Adobe Flash).
We have also changed the download process while manually scraping:
The Trailer window give only the (quality) selected link back to edit movie window.
The Download start when you press OK in edit movie window (no status bar atm).
While autoscraping the trailers are downloaded automatically.
And, i know, from time to time, trailer and actor thumbs downloading are very slow. This is one thing i try to fix or improve in next days.
... and IMDB Trailer are broken (damn JW Player). I do not know if we fix it or removed completely.
Thanks for answering so quickly.
When trying to download Adobe Flash Player, the site says "Your Google Chrome browser already includes Adobe® Flash® Player built-in." ...so I do what now exactly? (sorry, for being a bit dump on that one. I normally aren't)
Ok, that's strange??!?
Please try to run this FlashTest.exe:
Link
If you can see a windows with a white recantgle like this: Your system is OK and we have a bug.
If you can not see the recantgle or the application can not be started/crashed, try to install
flash player.
But please try it first without reinstalling flash!
yeah! that's strange!....
so...got it working...well mostly.....long story short:
before you posted the flash test: I had found the 'install system plugin' link on the flash site (which said that Chrome has it included) and did that.
-> had a Flash Player in my Windows Control Panel
--> still didn't work.
downloaded your flash test. which crashed.
dug out Internet Explorer, went to flash install site, tried from there.
-> installed the same thing as the system plugin stuff before. did it anyway.
-> tried your flashtest again. ...............which worked..........
--> tried Ember Trailers again..........which worked fine.....(yay!)...no idea why.....obviously my flash had been kind of twisted........but why I had to install it twice....nobody knows....
only problem now: I only get 360 quality trailers.....would like 720p.....
thanks for getting me onto the right track....
720p works, 1080p and higher not.
Can you send me a YT link that has 720p and does not work?
will do as soon as I find one......could of course just be wrong titles saying 'HQ Trailer' without being one.......
just got a 720p one........so that's one happy user now
thanks a million.
btw: love the new movie sets and trailers windows! they're just great. so much better than before
EDIT:
so now it downloads the trailer as soon as I click ok in the movie details window. no problem if knowing that. BUT: it doesn't tell the user anywhere. it looks just as if it takes ages to close the window. maybe some information somewhere would be nice? or a download percent bar? just a thought
