Cool, thank you...both issues solved.
One last question... I thought the naming convention for poster and fanart was poster.jpg and fanart.jpg.
http://wiki.xbmc.org/index.php?title=Add...Downloader
Running Frodo or Gotham.
EMM does not recognize these from my folders and if I have it scrape its own it names them <movie>-poster.jpg and <movie>-fanart.jpg
(2014-06-01, 17:25)huttdes Wrote: [ -> ]Cool, thank you...both issues solved.
ArtworkDownloader use divergent filenames. I know, it's a mess.
But with this settings you can reduce the doublicate images to a minimum:
- deactivate poster and fanarts in AD
- add "banner.jpg" as additional banner filename to expert settings in Ember
Now Ember create <moviefilename>-banner.jpg and banner.jpg, AD can recognize banners and XBMC recognize posters and fanarts correctly.
Question: Is there an option to save the files like posters and so on in ANOTHER FOLDER so that nothing is saved where the main movie is?
(2014-06-02, 12:11)DanCooper Wrote: [ -> ] (2014-06-02, 02:49)RockDawg Wrote: [ -> ] (2014-06-01, 14:23)DanCooper Wrote: [ -> ]Please upload a screenshot of your movie folder and your expert settings.
Here ya go:
Untitled2 by rockdawg2232, on Flickr
Untitled by rockdawg2232, on Flickr
Hmmmm... i can't see any trailer file in your folder... Ember can't recognize invisible trailers
Wow was that stupid of me! Here we go:
Untitled by
(2014-06-03, 00:05)RockDawg Wrote: [ -> ]Wow was that stupid of me! Here we go:
Problem is your trailer is called movie-trailer.mov when it should be called 127 Hours (2010)-trailer.mov
If all your trailers are named like this, you can use
Rename Master to rename them all to the proper names.
To do this, put your filer to only find files named
movie-trailer.* and set the rename option to replace the entire filename to:
That will do it...
HTH
-Pr.
Sorry, it's a bug. I forgot to add the expert trailers into the scanner process. I'll fix.
(2014-06-02, 22:35)juan71287 Wrote: [ -> ]Question: Is there an option to save the files like posters and so on in ANOTHER FOLDER so that nothing is saved where the main movie is?
Just quote myself because mine is so small it was probably skipped. I searched online and looked at all the options and couldn't find anything except to save fan-art in a separate folder; but I think its in a folder inside the directory of the movie
. SO, is that the only way? Or can I save all the files on a specific directory not on the directory of the movie file?
Hi everyone,
I wanted to point out a problem with the latest beta. I'm running Windows 7 64-bit.
Many of the windows in EMM get "cut off" at the bottom, and there is no ability to resize / expand the window. So it's hard to tell where the buttons are for things like "ok" or "cancel", etc.
Is anyone else seeing this problem?
An example is the "sets manager".
dmcc
(2014-06-03, 14:02)juan71287 Wrote: [ -> ] (2014-06-02, 22:35)juan71287 Wrote: [ -> ]Question: Is there an option to save the files like posters and so on in ANOTHER FOLDER so that nothing is saved where the main movie is?
Just quote myself because mine is so small it was probably skipped. I searched online and looked at all the options and couldn't find anything except to save fan-art in a separate folder; but I think its in a folder inside the directory of the movie . SO, is that the only way? Or can I save all the files on a specific directory not on the directory of the movie file?
There is a setting called "Backdrop Folder". If this set to an existing folder, Ember will save the fanart also at this location.
Please tell me if it not works correctly.
(2014-06-03, 16:23)dmcc Wrote: [ -> ]Hi everyone,
dmcc
With witch desktop resolution?
I know, the most dialogs has fixed sizes, but I will not fix that before official release.
(2014-06-03, 16:56)DanCooper Wrote: [ -> ]With witch desktop resolution?
1920x1080 is the desktop resolution. The "sets" window for example is 1386x724.
dmcc
I have this problem on my TV. Will look for the used resolution later.
