I think I got it. 101 doesn't read correctly. S01E01 works fine. Dang. That took hours.
Good news:
(2014-06-14, 18:18)Martijn Wrote: [ -> ]Update:
Currently working on default support using <moviefilename>-<arttype>.ext
This means it will download and name MOVIE artwork according to this.
Example: "9 (2009)-disc.png" instead of "disc.png"
It will also force rename any old files using "<arttype>.ext" to "<moviefilename>-<arttype>.ext"
It will not yet force update the database to point to the new file if renamed. Still working on that.
It may be finished and ready for testing during next week.
Still a lot untested. Just wanted to let you know.
I think we will change the default filenames for discart, clearart... to <filename>-disc.png, <filename>-clearart.png.
Dan ! just a quick mention .. I am not sure whether you are aware of this or not .
XBMC gotham possibly but Helix for sure is going to have animated GIF support.
So there is work being done to have animated folder/ poster support....
Heres the Link
just a heads up to see would ember be then worked to support for scraping the animated gif posters whatever may come !!
Cheers Buddy
If you add animated GIF support, could you please add an option to not download thumbs for animated posters etc? (Assuming the poster sites support telling the difference?)
I don't really want animated posters (especially in a 256-colour format; yuck) so it would save bandwidth at both ends to not bother even downloading the thumbs.
(Thinking about it, is it possible to set a language restriction somewhere in the settings? Every thumb with the text in a language I don't use is wasting bandwidth as well...)
(2014-06-23, 15:15)shaktoo Wrote: [ -> ]Dan ! just a quick mention .. I am not sure whether you are aware of this or not .
Heres the Link
Cheers Buddy
Haha, i thinks it's also funny for a porn library ;-)
I will check this later.
Any known source for GIF posters?
(2014-06-24, 11:34)Tiny Clanger Wrote: [ -> ]If you add animated GIF support, could you please add an option to not download thumbs for animated posters etc? (Assuming the poster sites support telling the difference?)
Yes, i can add "language only" option, but only for TMDB and Fanart.tv. All other websites/API has no language informations.
Also i can add "ignore GIF".
(2014-06-25, 02:17)Wanilton Wrote: [ -> ]Dancooper, you deserve
From Wanilton himself !
my tongue is scraping the floor !
(2014-06-23, 11:53)DanCooper Wrote: [ -> ]Good news:
That's why i already use expert settings to use this naming convention
Nudging this again to see if you want me to put it in as a "bug" or if it seems legit.
This should NOT be "pink" since it was auto-named by the bulk renamer to match.
(2014-06-27, 18:51)gregoryx Wrote: [ -> ]Nudging this again to see if you want me to put it in as a "bug" or if it seems legit.
The problem is that you have used "List Title" (...., The) and not "Movie Title" for renaming.
"Out of tolerance" compares always the "Movie Title" with filename.
question: which skin support themes? and sets?
I use Aeon MW but not sure they are used (or I was not able to enable them)
Also trailers... how can I see them?
m.savazzi, all mentioned work and have support Aeon MQ5, including trailers.
Short answer
Themes - need have file theme (mp3, wav, flac) in respective movie, concert or tv show folders (by default run when you are in video info (i), if you like playing theme in collection, need configure addon for play in this area too (tvtunes addon).
About sets, skin have specific view for sets (look submenu item for see), active in settings, video, for use sets. Need active sets view first.
About trailers - at home if you start from widget you see 3 options (play movie, play trailer, play cinema experience), or in collection, select movie with trailer available (need addon youtube for it), press c (context menu), you see one option for playing trailer.
Dan how's the latest masterpiece coming along?
(2014-06-28, 13:57)Wanilton Wrote: [ -> ]m.savazzi, all mentioned work and have support Aeon MQ5, including trailers.
Short answer
Great thank you! will test.
