Great work on the beta so far. I still seem to be having issues scraping the MPAA for movies. It gets the certification but the MPAA column scrapes as "none." Is this still being worked on? Thanks
(2014-08-27, 04:13)shadrach47 Wrote: [ -> ]Great work on the beta so far. I still seem to be having issues scraping the MPAA for movies. It gets the certification but the MPAA column scrapes as "none." Is this still being worked on? Thanks
Should work...
What have you set as the MPAA country, what additional settings for MPAA / Certification?
And what scraper are you using?
Hi love the 1.4 beta works like a charm.
I found a bug that is still there "use plot for outline if outline is empty" if this is on it ignores outline and uses plot for outline I use imdb scraper and have tested it with a couple of movies I know have Outline.
regarding Tvshow I am hoping for a little help.
I have my Tvshows named like this if they are no longer running "True Blood [Ended]" and it seem to make ember not find anything for shows can I in regex tell ember to ignore the [Ended] and if so please tell me how ?
secondly I am still strugling to figure out how to get dvd order to work so figured I would try and ask again.
for the tv show Firefly I have my episodes name by dvd order and in edit show I have it set to dvd order but no matter what I do after scrape they are listed in aired order
this is how my files are named (DVDorder)
after scrape with dvd order selected they get overridden with aired order it seems dvd order is just ignored.
S01E01 Serenity --> after scrape - The Train Job
S01E02 The Train Job --> after scrape - Bushwhacked
S01E03 Bushwhacked --> after scrape - Our Mrs. Reynolds
S01E04 Shindig --> after scrape - Jaynestown
S01E05 Safe --> after scrape - Out of Gas
S01E06 Our Mrs. Reynolds --> after scrape - Shindig
S01E07 Jaynestown --> after scrape - Safe
S01E08 Out of Gas --> after scrape - Ariel
S01E09 Ariel --> after scrape - War Stories
S01E10 War Stories --> after scrape - Objects in Space
S01E11 Trash --> after scrape - Serenity
S01E12 The Message --> after scrape - Heart of Gold
S01E13 Heart of Gold --> after scrape - Trash
S01E14 Objects in Space --> after scrape - The Message
I've received the following error message when trying to scrape a file named "Deep.Cover.(1992)[Uncut]", using the most recent download of Ember. Upon selecting ignore and continue, it worked.
Thanks for your hard work!
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.ArgumentException: Parameter is not valid.
at System.Drawing.Image.get_Width()
at System.Drawing.Image.get_Size()
at System.Windows.Forms.PictureBox.ImageRectangleFromSizeMode(PictureBoxSizeMode mode)
at System.Windows.Forms.PictureBox.OnPaint(PaintEventArgs pe)
at System.Windows.Forms.Control.PaintWithErrorHandling(PaintEventArgs e, Int16 layer)
at System.Windows.Forms.Control.WmPaint(Message& m)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.0.30319.18444 built by: FX451RTMGDR
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
Ember Media Manager
Assembly Version: 1.4.0.0
Win32 Version: 1.4.0.0
CodeBase: file:///C:/Ember%20Media%20Manager%20BETA/Ember%20Media%20Manager.exe
Microsoft.VisualBasic
Assembly Version: 10.0.0.0
Win32 Version: 11.0.50938.18408 built by: FX451RTMGREL
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
System
Win32 Version: 4.0.30319.18408 built by: FX451RTMGREL
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Core
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Runtime.Remoting
Win32 Version: 4.0.30319.34108 built by: FX45W81RTMGDR
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Remoting/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
NLog
Assembly Version: 3.1.0.0
Win32 Version: 3.1.0.0
CodeBase: file:///C:/Ember%20Media%20Manager%20BETA/NLog.DLL
System.Configuration
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
System.ServiceModel
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.ServiceModel/v4.0_4.0.0.0__b77a5c561934e089/System.ServiceModel.dll
System.Data
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_32/System.Data/v4.0_4.0.0.0__b77a5c561934e089/System.Data.dll
System.Runtime.Serialization
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Serialization/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Serialization.dll
EmberAPI
CodeBase: file:///C:/Ember%20Media%20Manager%20BETA/EmberAPI.DLL
Microsoft.GeneratedCode
Assembly Version: 1.0.0.0
System.Web
Win32 Version: 4.0.30319.18446 built by: FX451RTMGDR
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_32/System.Web/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Web.dll
System.Xml.Linq
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml.Linq/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.Linq.dll
EntityFramework
Assembly Version: 6.0.0.0
Win32 Version: 6.1.30610.0
CodeBase: file:///C:/Ember%20Media%20Manager%20BETA/Modules/EntityFramework.dll
System.ComponentModel.DataAnnotations
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.ComponentModel.DataAnnotations/v4.0_4.0.0.0__31bf3856ad364e35/System.ComponentModel.DataAnnotations.dll
System.Transactions
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_32/System.Transactions/v4.0_4.0.0.0__b77a5c561934e089/System.Transactions.dll
System.Data.SQLite
Assembly Version: 1.0.93.0
Win32 Version: 1.0.93.0
CodeBase: file:///C:/Ember%20Media%20Manager%20BETA/System.Data.SQLite.DLL
System.EnterpriseServices
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_32/System.EnterpriseServices/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.EnterpriseServices.dll
EntityFramework.SqlServer
CodeBase: file:///C:/Ember%20Media%20Manager%20BETA/Modules/EntityFramework.SqlServer.dll
EntityFramework
CodeBase: file:///C:/Ember%20Media%20Manager%20BETA/EntityFramework.DLL
FanartTVAPI
CodeBase: file:///C:/Ember%20Media%20Manager%20BETA/Modules/FanartTVAPI.dll
RestSharp
Assembly Version: 104.4.0.0
Win32 Version: 104.4.0.0
CodeBase: file:///C:/Ember%20Media%20Manager%20BETA/RestSharp.DLL
generic.EmberCore.BulkRename
CodeBase: file:///C:/Ember%20Media%20Manager%20BETA/Modules/generic.EmberCore.BulkRename.dll
generic.EmberCore.Extractor
CodeBase: file:///C:/Ember%20Media%20Manager%20BETA/Modules/generic.EmberCore.Extractor.dll
generic.EmberCore.GenresEditor
CodeBase: file:///C:/Ember%20Media%20Manager%20BETA/Modules/generic.EmberCore.GenresEditor.dll
generic.EmberCore.MediaFileManager
CodeBase: file:///C:/Ember%20Media%20Manager%20BETA/Modules/generic.EmberCore.MediaFileManager.dll
generic.EmberCore.MediaSources
CodeBase: file:///C:/Ember%20Media%20Manager%20BETA/Modules/generic.EmberCore.MediaSources.dll
generic.EmberCore.MetadataEditor
CodeBase: file:///C:/Ember%20Media%20Manager%20BETA/Modules/generic.EmberCore.MetadataEditor.dll
generic.EmberCore.MovieExporter
CodeBase: file:///C:/Ember%20Media%20Manager%20BETA/Modules/generic.EmberCore.MovieExporter.dll
generic.EmberCore.Notifications
CodeBase: file:///C:/Ember%20Media%20Manager%20BETA/Modules/generic.EmberCore.Notifications.dll
generic.EmberCore.Trakt
CodeBase: file:///C:/Ember%20Media%20Manager%20BETA/Modules/generic.EmberCore.Trakt.dll
ICSharpCode.SharpZipLib
Assembly Version: 0.86.0.518
Win32 Version: 0.86.0.518
CodeBase: file:///C:/Ember%20Media%20Manager%20BETA/Modules/ICSharpCode.SharpZipLib.dll
NLog
CodeBase: file:///C:/Ember%20Media%20Manager%20BETA/Modules/NLog.dll
RestSharp
CodeBase: file:///C:/Ember%20Media%20Manager%20BETA/Modules/RestSharp.dll
scraper.Data.IMDB
CodeBase: file:///C:/Ember%20Media%20Manager%20BETA/Modules/scraper.Data.IMDB.dll
scraper.Data.MoviepilotDE
CodeBase: file:///C:/Ember%20Media%20Manager%20BETA/Modules/scraper.Data.MoviepilotDE.dll
scraper.Data.OFDB
CodeBase: file:///C:/Ember%20Media%20Manager%20BETA/Modules/scraper.Data.OFDB.dll
scraper.Data.TMDB
CodeBase: file:///C:/Ember%20Media%20Manager%20BETA/Modules/scraper.Data.TMDB.dll
scraper.Image.FanartTV
CodeBase: file:///C:/Ember%20Media%20Manager%20BETA/Modules/scraper.Image.FanartTV.dll
scraper.Image.IMDB
CodeBase: file:///C:/Ember%20Media%20Manager%20BETA/Modules/scraper.Image.IMDB.dll
WatTmdb
CodeBase: file:///C:/Ember%20Media%20Manager%20BETA/WatTmdb.DLL
scraper.Image.IMPA
CodeBase: file:///C:/Ember%20Media%20Manager%20BETA/Modules/scraper.Image.IMPA.dll
scraper.Image.MPDB
CodeBase: file:///C:/Ember%20Media%20Manager%20BETA/Modules/scraper.Image.MPDB.dll
scraper.Image.TMDB
CodeBase: file:///C:/Ember%20Media%20Manager%20BETA/Modules/scraper.Image.TMDB.dll
scraper.Theme.GoEar
CodeBase: file:///C:/Ember%20Media%20Manager%20BETA/Modules/scraper.Theme.GoEar.dll
scraper.Theme.TelevisionTunes
CodeBase: file:///C:/Ember%20Media%20Manager%20BETA/Modules/scraper.Theme.TelevisionTunes.dll
scraper.Trailer.Apple
CodeBase: file:///C:/Ember%20Media%20Manager%20BETA/Modules/scraper.Trailer.Apple.dll
scraper.Trailer.IMDB
CodeBase: file:///C:/Ember%20Media%20Manager%20BETA/Modules/scraper.Trailer.IMDB.dll
scraper.Trailer.TMDB
CodeBase: file:///C:/Ember%20Media%20Manager%20BETA/Modules/scraper.Trailer.TMDB.dll
scraper.TVDB
CodeBase: file:///C:/Ember%20Media%20Manager%20BETA/Modules/scraper.TVDB.dll
System.Data.SQLite
CodeBase: file:///C:/Ember%20Media%20Manager%20BETA/Modules/System.Data.SQLite.dll
System.Data.SQLite.EF6
CodeBase: file:///C:/Ember%20Media%20Manager%20BETA/Modules/System.Data.SQLite.EF6.dll
System.Numerics
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Numerics/v4.0_4.0.0.0__b77a5c561934e089/System.Numerics.dll
System.Data.SQLite.Linq
CodeBase: file:///C:/Ember%20Media%20Manager%20BETA/Modules/System.Data.SQLite.Linq.dll
System.Data.Entity
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Data.Entity/v4.0_4.0.0.0__b77a5c561934e089/System.Data.Entity.dll
TrakttvAPI
CodeBase: file:///C:/Ember%20Media%20Manager%20BETA/Modules/TrakttvAPI.dll
WatTmdb
CodeBase: file:///C:/Ember%20Media%20Manager%20BETA/Modules/WatTmdb.dll
FanartTVAPI
CodeBase: file:///C:/Ember%20Media%20Manager%20BETA/FanartTVAPI.DLL
scraper.Data.TMDB
CodeBase: file:///C:/Ember%20Media%20Manager%20BETA/scraper.Data.TMDB.DLL
TrakttvAPI
CodeBase: file:///C:/Ember%20Media%20Manager%20BETA/TrakttvAPI.DLL
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
Extrafanarts and Extrathumbs do not get saved... Even if you select them manually...
In the Bulk Renamer, the $J uses the original Audio Codec instead of the mapped codec
(2014-08-28, 05:02)eb0la Wrote: [ -> ]I've received the following error message when trying to scrape a file named "Deep.Cover.(1992)[Uncut]", using the most recent download of Ember. Upon selecting ignore and continue, it worked.
I need the log file from Ember (.Ember Media Manager\log\*.cvs) to check that.
(2014-08-28, 05:05)Pr.Sinister Wrote: [ -> ]Extrafanarts and Extrathumbs do not get saved... Even if you select them manually...
Do you have only enabled extrathumbs and extrafanarts in expert settings?
These settings will be ignored (I forgot to fix it)
(2014-08-28, 05:22)Pr.Sinister Wrote: [ -> ]In the Bulk Renamer, the $J uses the original Audio Codec instead of the mapped codec
No, Renamer use always the strings they are saved in database.
Maybe you need to rescrape your metadata(?).
Hello, i can use everything i need in ember with last beta (so thx for this release you're doin a great job) except renamer : it seems to be broken when movie rating is not an integer
2014-08-28 12:55:48.3046;generic.EmberCore.BulkRename.FileFolderRenamer;generic.EmberCore.BulkRename.FileFolderRenamer.ProccessPattern;1;ERROR;ProccessPattern;"EXCEPTION OCCURRED:System.InvalidCastException: La conversion de la chaîne ""8.2"" en type 'Double' n'est pas valide. ---> System.FormatException: Le format de la chaîne d'entrée est incorrect.
à Microsoft.VisualBasic.CompilerServices.Conversions.ParseDouble(String Value, NumberFormatInfo NumberFormat)
à Microsoft.VisualBasic.CompilerServices.Conversions.ToDouble(String Value, NumberFormatInfo NumberFormat)
--- Fin de la trace de la pile d'exception interne ---
à Microsoft.VisualBasic.CompilerServices.Conversions.ToDouble(String Value)
à generic.EmberCore.BulkRename.FileFolderRenamer.ProccessPattern(FileRename f, String opattern)* à Microsoft.VisualBasic.CompilerServices.Conversions.ToDouble(String Value, NumberFormatInfo NumberFormat)
à generic.EmberCore.BulkRename.FileFolderRenamer.ProccessPattern(FileRename f, String opattern)"
2014-08-28 12:55:48.3136;Ember_Media_Manager.My.MyApplication;Ember_Media_Manager.My.MyApplication.MyApplication_UnhandledException;1;ERROR;System.Core;"EXCEPTION OCCURRED:System.InvalidOperationException: La séquence ne contient aucun élément.
à System.Linq.Enumerable.Last[TSource](IEnumerable`1 source)
à generic.EmberCore.BulkRename.FileFolderRenamer.RenameSingle(DBMovie& _tmpMovie, String folderPattern, String filePattern, Boolean BatchMode, Boolean toNfo, Boolean ShowError, Boolean toDB)
à generic.EmberCore.BulkRename.BulkRenamerModule.FolderSubMenuItemAuto_Click(Object sender, EventArgs e)
à System.Windows.Forms.ToolStripItem.RaiseEvent(Object key, EventArgs e)
à System.Windows.Forms.ToolStripMenuItem.OnClick(EventArgs e)
à System.Windows.Forms.ToolStripItem.HandleClick(EventArgs e)
à System.Windows.Forms.ToolStripItem.HandleMouseUp(MouseEventArgs e)
à System.Windows.Forms.ToolStripItem.FireEventInteractive(EventArgs e, ToolStripItemEventType met)
à System.Windows.Forms.ToolStripItem.FireEvent(EventArgs e, ToolStripItemEventType met)
à System.Windows.Forms.ToolStrip.OnMouseUp(MouseEventArgs mea)
à System.Windows.Forms.ToolStripDropDown.OnMouseUp(MouseEventArgs mea)
à System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
à System.Windows.Forms.Control.WndProc(Message& m)
à System.Windows.Forms.ScrollableControl.WndProc(Message& m)
à System.Windows.Forms.ToolStrip.WndProc(Message& m)
à System.Windows.Forms.ToolStripDropDown.WndProc(Message& m)
à System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
à System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
à System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)* à System.Linq.Enumerable.Last[TSource](IEnumerable`1 source)
à System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)"
2014-08-28 12:55:50.5776;Ember_Media_Manager.frmMain;Ember_Media_Manager.frmMain.frmMain_FormClosed;1;INFO;====Ember Media Manager exiting====;
(2014-08-28, 12:21)DanCooper Wrote: [ -> ]Do you have only enabled extrathumbs and extrafanarts in expert settings?
Yeah i think very highly of myself so i use expert settings
(2014-08-28, 05:22)DanCooper Wrote: [ -> ]No, Renamer use always the strings they are saved in database.
That did it... I changed the mapping after movies were already scraped. Rescraping fixed it.
Danke!
I think I am doing something wrong. I am updating to the latest beta, but not using my old settings and advanced settings files. I installed the new beta and copied over my media.emm file and my temp folder as has been instructed in the past, but when I load ember and put my sources in, everything I had in the past is basically not there. Is this correct? I had marked several tv shows as locked and such and now none of that is there.
I updated from the 5/whatever beta to the 8/26 beta. I feel like when I updated from three to 4 and to other betas this did not happen.
It looks like as far as ember is concerned, I am starting from scratch except that there are pre existing nfos. Am I forgetting something or is that just what is going on and I have to deal with it. I feel like in the past, it still retained most of my info as far as the database stuff was concerned but maybe the newest system does not allow that because of the changes made?
(2014-08-28, 21:12)sanjonny Wrote: [ -> ]I think I am doing something wrong. I am updating to the latest beta, but not using my old settings and advanced settings files. I installed the new beta and copied over my media.emm file and my temp folder as has been instructed in the past, but when I load ember and put my sources in, everything I had in the past is basically not there. Is this correct? I had marked several tv shows as locked and such and now none of that is there.
Thats correct. The new beta use a new filename for the database (MyVideos2.emm). The old database is no longer compatible. Now we use a file name with a number to identify the database version to merge it in a new database schema in future.
This is not said in a bitchy or cranky tone at all, but its good to know that stuff with the release. i spent quite awhile trying different things before I even posted because I thought I was just forgetting something. I thought maybe it was because I am 64 bit or I forgot a file and all kinds of stuff. In hindsight, I am a moron.
I have no issues with working on the beta and finding issues, I thought I had a setting wrong or something and probably because I was not thinking about it enough, I should have figured out that but did not.
I always figure I am not very tech challenged but if I screw something up or make stupid in hindsight assumptions, probably others will too.
Anyway, thanks for all the hard work, will see if I can break it so you can keep making it better and better.
(2014-08-28, 02:16)ztrust Wrote: [ -> ]Hi love the 1.4 beta works like a charm.
We are still working on a new solution for a better data scraper handling. I will check this if we are done.
(2014-08-28, 02:16)ztrust Wrote: [ -> ]regarding Tvshow I am hoping for a little help.
Add this to the TV Show Folder/File Filter:
(2014-08-28, 02:16)ztrust Wrote: [ -> ]secondly I am still strugling to figure out how to get dvd order to work so figured I would try and ask again.
The procedure should be as:
- change the ordering in Edit TV Show dialog, click OK to save
- rescrape the whole tv show
is there a way for ember to show poster movies that are saved as .jpg ? (it shows only posters saved as -poster.jpg)
