Full Version: Ember Media Manager 1.4.x BETA - Discussion Thread
New build working great on my end.
Only problem so far for me: the Settings window is still not resizing to my laptop resolution - 1366x768.
(2014-10-20, 00:37)DanCooper Wrote: [ -> ]Start "Clean Database" if you have added the excluded paths to an existing database with already registred movies. Clean DB will remove all movies from DB which are in the excluded paths.
I tried this already. Does not work for me.
The only thing that works is manually deleting all entries from the DB via the context menu and then updating the DB.
@dan why h264 movies are displayed as mpeg4(divx) ? ( also in nfo file mpeg4 is written)
(2014-10-20, 06:38)solamnic Wrote: [ -> ]@dan why h264 movies are displayed as mpeg4(divx) ? ( also in nfo file mpeg4 is written)
What do MediaInfo (standalone software) say?
Finally made the move and upgraded to the beta - was always running 1.3.
Boy the speed improvement is amazing! Should have moved a long time ago Smile
DanCooper
I think the mass renamer has an error not load movies v.1.4.0.4
THANKS FOR YOUR WORK.
(2014-10-20, 10:00)jtm010101 Wrote: [ -> ]DanCooper
Please upload your error log.
(2014-10-20, 10:59)DanCooper Wrote: [ -> ]
2014-10-20 11:16:32.5157    EmberAPI.ModulesManager    EmberAPI.ModulesManager.loadScrapersModules_Movie    6    TRACE    Scraper Added: scraper.Trailer.TrailerDavestrailerpage.ScraperModule.Davestrailerpage_Trailer_Movie
2014-10-20 11:16:32.5277    EmberAPI.ModulesManager    EmberAPI.ModulesManager.loadScrapersModules_Movie    6    TRACE    Scraper Added: scraper.Trailer.TrailerHDTrailersNet.ScraperModule.HDTrailerdNet_Trailer_Movie
2014-10-20 11:16:32.5437    EmberAPI.ModulesManager    EmberAPI.ModulesManager.loadScrapersModules_Movie    6    TRACE    loadMovieScrapersModules finished
2014-10-20 11:16:35.8509    EmberAPI.HTTP    EmberAPI.HTTP.DownloadImage    39    ERROR    "DownloadImage    <http://image.tmdb.org/t/p/original/nISERu1XbLVgX4OffyA8nnfBEpq.jpg>"    "EXCEPTION OCCURRED:System.Net.WebException: Anulada la solicitud: La solicitud fue cancelada.
   en System.Net.ConnectStream.Read(Byte[] buffer, Int32 offset, Int32 size)
   en EmberAPI.HTTP.DownloadImage()*   en System.Net.ConnectStream.Read(Byte[] buffer, Int32 offset, Int32 size)
   en EmberAPI.HTTP.DownloadImage()"
2014-10-20 11:16:41.4982    generic.EmberCore.BulkRename.dlgBulkRenamer    generic.EmberCore.BulkRename.dlgBulkRenamer.bwLoadInfo_DoWork    4    ERROR    bwLoadInfo_DoWork    "EXCEPTION OCCURRED:System.NullReferenceException: Referencia a objeto no establecida como instancia de un objeto.
   en generic.EmberCore.BulkRename.FileFolderRenamer.FileRename.set_FileSource(String value)
   en generic.EmberCore.BulkRename.dlgBulkRenamer.bwLoadInfo_DoWork(Object sender, DoWorkEventArgs e)*   en generic.EmberCore.BulkRename.FileFolderRenamer.FileRename.set_FileSource(String value)
   en generic.EmberCore.BulkRename.dlgBulkRenamer.bwLoadInfo_DoWork(Object sender, DoWorkEventArgs e)"
2014-10-20 11:16:41.5432    generic.EmberCore.BulkRename.dlgBulkRenamer    generic.EmberCore.BulkRename.dlgBulkRenamer.bwLoadInfo_DoWork    4    ERROR    bwLoadInfo_DoWork    "EXCEPTION OCCURRED:System.NullReferenceException: Referencia a objeto no establecida como instancia de un objeto.
2014-10-20 11:16:41.5822    generic.EmberCore.BulkRename.dlgBulkRenamer    generic.EmberCore.BulkRename.dlgBulkRenamer.bwLoadInfo_DoWork    4    ERROR    bwLoadInfo_DoWork    "EXCEPTION OCCURRED:System.NullReferenceException: Referencia a objeto no establecida como instancia de un objeto.
2014-10-20 11:16:41.6372    generic.EmberCore.BulkRename.dlgBulkRenamer    generic.EmberCore.BulkRename.dlgBulkRenamer.bwLoadInfo_DoWork    4    ERROR    bwLoadInfo_DoWork    "EXCEPTION OCCURRED:System.NullReferenceException: Referencia a objeto no establecida como instancia de un objeto.
2014-10-20 11:16:41.6902    generic.EmberCore.BulkRename.dlgBulkRenamer    generic.EmberCore.BulkRename.dlgBulkRenamer.bwLoadInfo_DoWork    4    ERROR    bwLoadInfo_DoWork    "EXCEPTION OCCURRED:System.NullReferenceException: Referencia a objeto no establecida como instancia de un objeto.
2014-10-20 11:16:41.7362    generic.EmberCore.BulkRename.dlgBulkRenamer    generic.EmberCore.BulkRename.dlgBulkRenamer.bwLoadInfo_DoWork    4    ERROR    bwLoadInfo_DoWork    "EXCEPTION OCCURRED:System.NullReferenceException: Referencia a objeto no establecida como instancia de un objeto.
2014-10-20 11:16:41.7692    generic.EmberCore.BulkRename.dlgBulkRenamer    generic.EmberCore.BulkRename.dlgBulkRenamer.bwLoadInfo_DoWork    4    ERROR    bwLoadInfo_DoWork    "EXCEPTION OCCURRED:System.NullReferenceException: Referencia a objeto no establecida como instancia de un objeto.
2014-10-20 11:16:41.8272    generic.EmberCore.BulkRename.dlgBulkRenamer    generic.EmberCore.BulkRename.dlgBulkRenamer.bwLoadInfo_DoWork    4    ERROR    bwLoadInfo_DoWork    "EXCEPTION OCCURRED:System.NullReferenceException: Referencia a objeto no establecida como instancia de un objeto.
2014-10-20 11:16:41.8712    generic.EmberCore.BulkRename.dlgBulkRenamer    generic.EmberCore.BulkRename.dlgBulkRenamer.bwLoadInfo_DoWork    4    ERROR    bwLoadInfo_DoWork    "EXCEPTION OCCURRED:System.NullReferenceException: Referencia a objeto no establecida como instancia de un objeto.
2014-10-20 11:16:41.9142    generic.EmberCore.BulkRename.dlgBulkRenamer    generic.EmberCore.BulkRename.dlgBulkRenamer.bwLoadInfo_DoWork    4    ERROR    bwLoadInfo_DoWork    "EXCEPTION OCCURRED:System.NullReferenceException: Referencia a objeto no establecida como instancia de un objeto.
2014-10-20 11:16:41.9572    generic.EmberCore.BulkRename.dlgBulkRenamer    generic.EmberCore.BulkRename.dlgBulkRenamer.bwLoadInfo_DoWork    4    ERROR    bwLoadInfo_DoWork    "EXCEPTION OCCURRED:System.NullReferenceException: Referencia a objeto no establecida como instancia de un objeto.
2014-10-20 11:16:42.0022    generic.EmberCore.BulkRename.dlgBulkRenamer    generic.EmberCore.BulkRename.dlgBulkRenamer.bwLoadInfo_DoWork    4    ERROR    bwLoadInfo_DoWork    "EXCEPTION OCCURRED:System.NullReferenceException: Referencia a objeto no establecida como instancia de un objeto.
2014-10-20 11:16:42.0472    generic.EmberCore.BulkRename.dlgBulkRenamer    generic.EmberCore.BulkRename.dlgBulkRenamer.bwLoadInfo_DoWork    4    ERROR    bwLoadInfo_DoWork    "EXCEPTION OCCURRED:System.NullReferenceException: Referencia a objeto no establecida como instancia de un objeto.
2014-10-20 11:16:42.1563    generic.EmberCore.BulkRename.dlgBulkRenamer    generic.EmberCore.BulkRename.dlgBulkRenamer.bwLoadInfo_DoWork    4    ERROR    bwLoadInfo_DoWork    "EXCEPTION OCCURRED:System.NullReferenceException: Referencia a objeto no establecida como instancia de un objeto.
2014-10-20 11:16:42.2003    generic.EmberCore.BulkRename.dlgBulkRenamer    generic.EmberCore.BulkRename.dlgBulkRenamer.bwLoadInfo_DoWork    4    ERROR    bwLoadInfo_DoWork    "EXCEPTION OCCURRED:System.NullReferenceException: Referencia a objeto no establecida como instancia de un objeto.
2014-10-20 11:16:42.2473    generic.EmberCore.BulkRename.dlgBulkRenamer    generic.EmberCore.BulkRename.dlgBulkRenamer.bwLoadInfo_DoWork    4    ERROR    bwLoadInfo_DoWork    "EXCEPTION OCCURRED:System.NullReferenceException: Referencia a objeto no establecida como instancia de un objeto.
2014-10-20 11:16:42.2873    generic.EmberCore.BulkRename.dlgBulkRenamer    generic.EmberCore.BulkRename.dlgBulkRenamer.bwLoadInfo_DoWork    4    ERROR    bwLoadInfo_DoWork    "EXCEPTION OCCURRED:System.NullReferenceException: Referencia a objeto no establecida como instancia de un objeto.
2014-10-20 11:16:42.3393    generic.EmberCore.BulkRename.dlgBulkRenamer    generic.EmberCore.BulkRename.dlgBulkRenamer.bwLoadInfo_DoWork    4    ERROR    bwLoadInfo_DoWork    "EXCEPTION OCCURRED:System.NullReferenceException: Referencia a objeto no establecida como instancia de un objeto.
2014-10-20 11:16:42.3903    generic.EmberCore.BulkRename.dlgBulkRenamer    generic.EmberCore.BulkRename.dlgBulkRenamer.bwLoadInfo_DoWork    4    ERROR    bwLoadInfo_DoWork    "EXCEPTION OCCURRED:System.NullReferenceException: Referencia a objeto no establecida como instancia de un objeto.
2014-10-20 11:16:42.4363    generic.EmberCore.BulkRename.dlgBulkRenamer    generic.EmberCore.BulkRename.dlgBulkRenamer.bwLoadInfo_DoWork    4    ERROR    bwLoadInfo_DoWork    "EXCEPTION OCCURRED:System.NullReferenceException: Referencia a objeto no establecida como instancia de un objeto.
2014-10-20 11:16:42.5763    generic.EmberCore.BulkRename.dlgBulkRenamer    generic.EmberCore.BulkRename.dlgBulkRenamer.bwLoadInfo_DoWork    4    ERROR    bwLoadInfo_DoWork    "EXCEPTION OCCURRED:System.NullReferenceException: Referencia a objeto no establecida como instancia de un objeto.
2014-10-20 11:16:42.6313    generic.EmberCore.BulkRename.dlgBulkRenamer    generic.EmberCore.BulkRename.dlgBulkRenamer.bwLoadInfo_DoWork    4    ERROR    bwLoadInfo_DoWork    "EXCEPTION OCCURRED:System.NullReferenceException: Referencia a objeto no establecida como instancia de un objeto.
2014-10-20 11:16:42.6783    generic.EmberCore.BulkRename.dlgBulkRenamer    generic.EmberCore.BulkRename.dlgBulkRenamer.bwLoadInfo_DoWork    4    ERROR    bwLoadInfo_DoWork    "EXCEPTION OCCURRED:System.NullReferenceException: Referencia a objeto no establecida como instancia de un objeto.
2014-10-20 11:16:42.7233    generic.EmberCore.BulkRename.dlgBulkRenamer    generic.EmberCore.BulkRename.dlgBulkRenamer.bwLoadInfo_DoWork    4    ERROR    bwLoadInfo_DoWork    "EXCEPTION OCCURRED:System.NullReferenceException: Referencia a objeto no establecida como instancia de un objeto.
2014-10-20 11:16:42.7723    generic.EmberCore.BulkRename.dlgBulkRenamer    generic.EmberCore.BulkRename.dlgBulkRenamer.bwLoadInfo_DoWork    4    ERROR    bwLoadInfo_DoWork    "EXCEPTION OCCURRED:System.NullReferenceException: Referencia a objeto no establecida como instancia de un objeto.
2014-10-20 11:16:42.8183    generic.EmberCore.BulkRename.dlgBulkRenamer    generic.EmberCore.BulkRename.dlgBulkRenamer.bwLoadInfo_DoWork    4    ERROR    bwLoadInfo_DoWork    "EXCEPTION OCCURRED:System.NullReferenceException: Referencia a objeto no establecida como instancia de un objeto.
2014-10-20 11:16:42.8613    generic.EmberCore.BulkRename.dlgBulkRenamer    generic.EmberCore.BulkRename.dlgBulkRenamer.bwLoadInfo_DoWork    4    ERROR    bwLoadInfo_DoWork    "EXCEPTION OCCURRED:System.NullReferenceException: Referencia a objeto no establecida como instancia de un objeto.
2014-10-20 11:16:42.9063    generic.EmberCore.BulkRename.dlgBulkRenamer    generic.EmberCore.BulkRename.dlgBulkRenamer.bwLoadInfo_DoWork    4    ERROR    bwLoadInfo_DoWork    "EXCEPTION OCCURRED:System.NullReferenceException: Referencia a objeto no establecida como instancia de un objeto.
2014-10-20 11:16:42.9533    generic.EmberCore.BulkRename.dlgBulkRenamer    generic.EmberCore.BulkRename.dlgBulkRenamer.bwLoadInfo_DoWork    4    ERROR    bwLoadInfo_DoWork    "EXCEPTION OCCURRED:System.NullReferenceException: Referencia a objeto no establecida como instancia de un objeto.
2014-10-20 11:16:42.9973    generic.EmberCore.BulkRename.dlgBulkRenamer    generic.EmberCore.BulkRename.dlgBulkRenamer.bwLoadInfo_DoWork    4    ERROR    bwLoadInfo_DoWork    "EXCEPTION OCCURRED:System.NullReferenceException: Referencia a objeto no establecida como instancia de un objeto.
2014-10-20 11:16:43.0353    generic.EmberCore.BulkRename.dlgBulkRenamer    generic.EmberCore.BulkRename.dlgBulkRenamer.bwLoadInfo_DoWork    4    ERROR    bwLoadInfo_DoWork    "EXCEPTION OCCURRED:System.NullReferenceException: Referencia a objeto no establecida como instancia de un objeto.
2014-10-20 11:16:43.1013    generic.EmberCore.BulkRename.dlgBulkRenamer    generic.EmberCore.BulkRename.dlgBulkRenamer.bwLoadInfo_DoWork    4    ERROR    bwLoadInfo_DoWork    "EXCEPTION OCCURRED:System.NullReferenceException: Referencia a objeto no establecida como instancia de un objeto.
2014-10-20 11:16:43.1493    generic.EmberCore.BulkRename.dlgBulkRenamer    generic.EmberCore.BulkRename.dlgBulkRenamer.bwLoadInfo_DoWork    4    ERROR    bwLoadInfo_DoWork    "EXCEPTION OCCURRED:System.NullReferenceException: Referencia a objeto no establecida como instancia de un objeto.
2014-10-20 11:16:43.1953    generic.EmberCore.BulkRename.dlgBulkRenamer    generic.EmberCore.BulkRename.dlgBulkRenamer.bwLoadInfo_DoWork    4    ERROR    bwLoadInfo_DoWork    "EXCEPTION OCCURRED:System.NullReferenceException: Referencia a objeto no establecida como instancia de un objeto.
2014-10-20 11:16:43.2413    generic.EmberCore.BulkRename.dlgBulkRenamer    generic.EmberCore.BulkRename.dlgBulkRenamer.bwLoadInfo_DoWork    4    ERROR    bwLoadInfo_DoWork    "EXCEPTION OCCURRED:System.NullReferenceException: Referencia a objeto no establecida como instancia de un objeto.
2014-10-20 11:16:43.2823    generic.EmberCore.BulkRename.dlgBulkRenamer    generic.EmberCore.BulkRename.dlgBulkRenamer.bwLoadInfo_DoWork    4    ERROR    bwLoadInfo_DoWork    "EXCEPTION OCCURRED:System.NullReferenceException: Referencia a objeto no establecida como instancia de un objeto.
2014-10-20 11:16:43.3323    generic.EmberCore.BulkRename.dlgBulkRenamer    generic.EmberCore.BulkRename.dlgBulkRenamer.bwLoadInfo_DoWork    4    ERROR    bwLoadInfo_DoWork    "EXCEPTION OCCURRED:System.NullReferenceException: Referencia a objeto no establecida como instancia de un objeto.
2014-10-20 11:16:43.3773    generic.EmberCore.BulkRename.dlgBulkRenamer    generic.EmberCore.BulkRename.dlgBulkRenamer.bwLoadInfo_DoWork    4    ERROR    bwLoadInfo_DoWork    "EXCEPTION OCCURRED:System.NullReferenceException: Referencia a objeto no establecida como instancia de un objeto.
2014-10-20 11:16:43.4293    generic.EmberCore.BulkRename.dlgBulkRenamer    generic.EmberCore.BulkRename.dlgBulkRenamer.bwLoadInfo_DoWork    4    ERROR    bwLoadInfo_DoWork    "EXCEPTION OCCURRED:System.NullReferenceException: Referencia a objeto no establecida como instancia de un objeto.
2014-10-20 11:16:43.4713    generic.EmberCore.BulkRename.dlgBulkRenamer    generic.EmberCore.BulkRename.dlgBulkRenamer.bwLoadInfo_DoWork    4    ERROR    bwLoadInfo_DoWork    "EXCEPTION OCCURRED:System.NullReferenceException: Referencia a objeto no establecida como instancia de un objeto.
2014-10-20 11:16:43.5153    generic.EmberCore.BulkRename.dlgBulkRenamer    generic.EmberCore.BulkRename.dlgBulkRenamer.bwLoadInfo_DoWork    4    ERROR    bwLoadInfo_DoWork    "EXCEPTION OCCURRED:System.NullReferenceException: Referencia a objeto no establecida como instancia de un objeto.
2014-10-20 11:16:43.5613    generic.EmberCore.BulkRename.dlgBulkRenamer    generic.EmberCore.BulkRename.dlgBulkRenamer.bwLoadInfo_DoWork    4    ERROR    bwLoadInfo_DoWork    "EXCEPTION OCCURRED:System.NullReferenceException: Referencia a objeto no establecida como instancia de un objeto.
2014-10-20 11:16:43.6173    generic.EmberCore.BulkRename.dlgBulkRenamer    generic.EmberCore.BulkRename.dlgBulkRenamer.bwLoadInfo_DoWork    4    ERROR    bwLoadInfo_DoWork    "EXCEPTION OCCURRED:System.NullReferenceException: Referencia a objeto no establecida como instancia de un objeto.
2014-10-20 11:16:43.6683    generic.EmberCore.BulkRename.dlgBulkRenamer    generic.EmberCore.BulkRename.dlgBulkRenamer.bwLoadInfo_DoWork    4    ERROR    bwLoadInfo_DoWork    "EXCEPTION OCCURRED:System.NullReferenceException: Referencia a objeto no establecida como instancia de un objeto.
2014-10-20 11:16:43.7173    generic.EmberCore.BulkRename.dlgBulkRenamer    generic.EmberCore.BulkRename.dlgBulkRenamer.bwLoadInfo_DoWork    4    ERROR    bwLoadInfo_DoWork    "EXCEPTION OCCURRED:System.NullReferenceException: Referencia a objeto no establecida como instancia de un objeto.
2014-10-20 11:16:43.7613    generic.EmberCore.BulkRename.dlgBulkRenamer    generic.EmberCore.BulkRename.dlgBulkRenamer.bwLoadInfo_DoWork    4    ERROR    bwLoadInfo_DoWork    "EXCEPTION OCCURRED:System.NullReferenceException: Referencia a objeto no establecida como instancia de un objeto.
2014-10-20 11:16:43.8033    generic.EmberCore.BulkRename.dlgBulkRenamer    generic.EmberCore.BulkRename.dlgBulkRenamer.bwLoadInfo_DoWork    4    ERROR    bwLoadInfo_DoWork    "EXCEPTION OCCURRED:System.NullReferenceException: Referencia a objeto no establecida como instancia de un objeto.
2014-10-20 11:16:43.8553    generic.EmberCore.BulkRename.dlgBulkRenamer    generic.EmberCore.BulkRename.dlgBulkRenamer.bwLoadInfo_DoWork    4    ERROR    bwLoadInfo_DoWork    "EXCEPTION OCCURRED:System.NullReferenceException: Referencia a objeto no establecida como instancia de un objeto.
2014-10-20 11:16:43.8974    generic.EmberCore.BulkRename.dlgBulkRenamer    generic.EmberCore.BulkRename.dlgBulkRenamer.bwLoadInfo_DoWork    4    ERROR    bwLoadInfo_DoWork    "EXCEPTION OCCURRED:System.NullReferenceException: Referencia a objeto no establecida como instancia de un objeto.
2014-10-20 11:16:43.9454    generic.EmberCore.BulkRename.dlgBulkRenamer    generic.EmberCore.BulkRename.dlgBulkRenamer.bwLoadInfo_DoWork    4    ERROR    bwLoadInfo_DoWork    "EXCEPTION OCCURRED:System.NullReferenceException: Referencia a objeto no establecida como instancia de un objeto.
2014-10-20 11:16:43.9874    generic.EmberCore.BulkRename.dlgBulkRenamer    generic.EmberCore.BulkRename.dlgBulkRenamer.bwLoadInfo_DoWork    4    ERROR    bwLoadInfo_DoWork    "EXCEPTION OCCURRED:System.NullReferenceException: Referencia a objeto no establecida como instancia de un objeto.
2014-10-20 11:16:44.0314    generic.EmberCore.BulkRename.dlgBulkRenamer    generic.EmberCore.BulkRename.dlgBulkRenamer.bwLoadInfo_DoWork    4    ERROR    bwLoadInfo_DoWork    "EXCEPTION OCCURRED:System.NullReferenceException: Referencia a objeto no establecida como instancia de un objeto.
2014-10-20 11:16:44.0744    generic.EmberCore.BulkRename.dlgBulkRenamer    generic.EmberCore.BulkRename.dlgBulkRenamer.bwLoadInfo_DoWork    4    ERROR    bwLoadInfo_DoWork    "EXCEPTION OCCURRED:System.NullReferenceException: Referencia a objeto no establecida como instancia de un objeto.
2014-10-20 11:16:44.1244    generic.EmberCore.BulkRename.dlgBulkRenamer    generic.EmberCore.BulkRename.dlgBulkRenamer.bwLoadInfo_DoWork    4    ERROR    bwLoadInfo_DoWork    "EXCEPTION OCCURRED:System.NullReferenceException: Referencia a objeto no establecida como instancia de un objeto.
2014-10-20 11:16:44.1734    generic.EmberCore.BulkRename.dlgBulkRenamer    generic.EmberCore.BulkRename.dlgBulkRenamer.bwLoadInfo_DoWork    4    ERROR    bwLoadInfo_DoWork    "EXCEPTION OCCURRED:System.NullReferenceException: Referencia a objeto no establecida como instancia de un objeto.
2014-10-20 11:16:44.2184    generic.EmberCore.BulkRename.dlgBulkRenamer    generic.EmberCore.BulkRename.dlgBulkRenamer.bwLoadInfo_DoWork    4    ERROR    bwLoadInfo_DoWork    "EXCEPTION OCCURRED:System.NullReferenceException: Referencia a objeto no establecida como instancia de un objeto.
2014-10-20 11:16:44.2634    generic.EmberCore.BulkRename.dlgBulkRenamer    generic.EmberCore.BulkRename.dlgBulkRenamer.bwLoadInfo_DoWork    4    ERROR    bwLoadInfo_DoWork    "EXCEPTION OCCURRED:System.NullReferenceException: Referencia a objeto no establecida como instancia de un objeto.
2014-10-20 11:16:44.3594    generic.EmberCore.BulkRename.dlgBulkRenamer    generic.EmberCore.BulkRename.dlgBulkRenamer.bwLoadInfo_DoWork    4    ERROR    bwLoadInfo_DoWork    "EXCEPTION OCCURRED:System.NullReferenceException: Referencia a objeto no establecida como instancia de un objeto.
2014-10-20 11:16:44.4074    generic.EmberCore.BulkRename.dlgBulkRenamer    generic.EmberCore.BulkRename.dlgBulkRenamer.bwLoadInfo_DoWork    4    ERROR    bwLoadInfo_DoWork    "EXCEPTION OCCURRED:System.NullReferenceException: Referencia a objeto no establecida como instancia de un objeto.
2014-10-20 11:16:44.4524    generic.EmberCore.BulkRename.dlgBulkRenamer    generic.EmberCore.BulkRename.dlgBulkRenamer.bwLoadInfo_DoWork    4    ERROR    bwLoadInfo_DoWork    "EXCEPTION OCCURRED:System.NullReferenceException: Referencia a objeto no establecida como instancia de un objeto.
2014-10-20 11:16:44.4984    generic.EmberCore.BulkRename.dlgBulkRenamer    generic.EmberCore.BulkRename.dlgBulkRenamer.bwLoadInfo_DoWork    4    ERROR    bwLoadInfo_DoWork    "EXCEPTION OCCURRED:System.NullReferenceException: Referencia a objeto no establecida como instancia de un objeto.
2014-10-20 11:16:44.5424    generic.EmberCore.BulkRename.dlgBulkRenamer    generic.EmberCore.BulkRename.dlgBulkRenamer.bwLoadInfo_DoWork    4    ERROR    bwLoadInfo_DoWork    "EXCEPTION OCCURRED:System.NullReferenceException: Referencia a objeto no establecida como instancia de un objeto.
2014-10-20 11:16:44.5894    generic.EmberCore.BulkRename.dlgBulkRenamer    generic.EmberCore.BulkRename.dlgBulkRenamer.bwLoadInfo_DoWork    4    ERROR    bwLoadInfo_DoWork    "EXCEPTION OCCURRED:System.NullReferenceException: Referencia a objeto no establecida como instancia de un objeto.
2014-10-20 11:16:44.6364    generic.EmberCore.BulkRename.dlgBulkRenamer    generic.EmberCore.BulkRename.dlgBulkRenamer.bwLoadInfo_DoWork    4    ERROR    bwLoadInfo_DoWork    "EXCEPTION OCCURRED:System.NullReferenceException: Referencia a objeto no establecida como instancia de un objeto.
2014-10-20 11:16:44.6874    generic.EmberCore.BulkRename.dlgBulkRenamer    generic.EmberCore.BulkRename.dlgBulkRenamer.bwLoadInfo_DoWork    4    ERROR    bwLoadInfo_DoWork    "EXCEPTION OCCURRED:System.NullReferenceException: Referencia a objeto no establecida como instancia de un objeto.
2014-10-20 11:16:44.7314    generic.EmberCore.BulkRename.dlgBulkRenamer    generic.EmberCore.BulkRename.dlgBulkRenamer.bwLoadInfo_DoWork    4    ERROR    bwLoadInfo_DoWork    "EXCEPTION OCCURRED:System.NullReferenceException: Referencia a objeto no establecida como instancia de un objeto.
2014-10-20 11:16:44.7774    generic.EmberCore.BulkRename.dlgBulkRenamer    generic.EmberCore.BulkRename.dlgBulkRenamer.bwLoadInfo_DoWork    4    ERROR    bwLoadInfo_DoWork    "EXCEPTION OCCURRED:System.NullReferenceException: Referencia a objeto no establecida como instancia de un objeto.
2014-10-20 11:16:44.8214    generic.EmberCore.BulkRename.dlgBulkRenamer    generic.EmberCore.BulkRename.dlgBulkRenamer.bwLoadInfo_DoWork    4    ERROR    bwLoadInfo_DoWork    "EXCEPTION OCCURRED:System.NullReferenceException: Referencia a objeto no establecida como instancia de un objeto.
2014-10-20 11:16:44.8654    generic.EmberCore.BulkRename.dlgBulkRenamer    generic.EmberCore.BulkRename.dlgBulkRenamer.bwLoadInfo_DoWork    4    ERROR    bwLoadInfo_DoWork    "EXCEPTION OCCURRED:System.NullReferenceException: Referencia a objeto no establecida como instancia de un objeto.
2014-10-20 11:16:44.9194    generic.EmberCore.BulkRename.dlgBulkRenamer    generic.EmberCore.BulkRename.dlgBulkRenamer.bwLoadInfo_DoWork    4    ERROR    bwLoadInfo_DoWork    "EXCEPTION OCCURRED:System.NullReferenceException: Referencia a objeto no establecida como instancia de un objeto.
2014-10-20 11:16:44.9644    generic.EmberCore.BulkRename.dlgBulkRenamer    generic.EmberCore.BulkRename.dlgBulkRenamer.bwLoadInfo_DoWork    4    ERROR    bwLoadInfo_DoWork    "EXCEPTION OCCURRED:System.NullReferenceException: Referencia a objeto no establecida como instancia de un objeto.
2014-10-20 11:16:45.0094    generic.EmberCore.BulkRename.dlgBulkRenamer    generic.EmberCore.BulkRename.dlgBulkRenamer.bwLoadInfo_DoWork    4    ERROR    bwLoadInfo_DoWork    "EXCEPTION OCCURRED:System.NullReferenceException: Referencia a objeto no establecida como instancia de un objeto.
2014-10-20 11:16:45.0464    generic.EmberCore.BulkRename.dlgBulkRenamer    generic.EmberCore.BulkRename.dlgBulkRenamer.bwLoadInfo_DoWork    4    ERROR    bwLoadInfo_DoWork    "EXCEPTION OCCURRED:System.NullReferenceException: Referencia a objeto no establecida como instancia de un objeto.
2014-10-20 11:16:45.0974    generic.EmberCore.BulkRename.dlgBulkRenamer    generic.EmberCore.BulkRename.dlgBulkRenamer.bwLoadInfo_DoWork    4    ERROR    bwLoadInfo_DoWork    "EXCEPTION OCCURRED:System.NullReferenceException: Referencia a objeto no establecida como instancia de un objeto.
2014-10-20 11:16:45.2054    generic.EmberCore.BulkRename.dlgBulkRenamer    generic.EmberCore.BulkRename.dlgBulkRenamer.bwLoadInfo_DoWork    4    ERROR    bwLoadInfo_DoWork    "EXCEPTION OCCURRED:System.NullReferenceException: Referencia a objeto no establecida como instancia de un objeto.
2014-10-20 11:16:45.2544    generic.EmberCore.BulkRename.dlgBulkRenamer    generic.EmberCore.BulkRename.dlgBulkRenamer.bwLoadInfo_DoWork    4    ERROR    bwLoadInfo_DoWork    "EXCEPTION OCCURRED:System.NullReferenceException: Referencia a objeto no establecida como instancia de un objeto.
2014-10-20 11:16:45.2974    generic.EmberCore.BulkRename.dlgBulkRenamer    generic.EmberCore.BulkRename.dlgBulkRenamer.bwLoadInfo_DoWork    4    ERROR    bwLoadInfo_DoWork    "EXCEPTION OCCURRED:System.NullReferenceException: Referencia a objeto no establecida como instancia de un objeto.
2014-10-20 11:16:45.3454    generic.EmberCore.BulkRename.dlgBulkRenamer    generic.EmberCore.BulkRename.dlgBulkRenamer.bwLoadInfo_DoWork    4    ERROR    bwLoadInfo_DoWork    "EXCEPTION OCCURRED:System.NullReferenceException: Referencia a objeto no establecida como instancia de un objeto.
2014-10-20 11:16:45.3904    generic.EmberCore.BulkRename.dlgBulkRenamer    generic.EmberCore.BulkRename.dlgBulkRenamer.bwLoadInfo_DoWork    4    ERROR    bwLoadInfo_DoWork    "EXCEPTION OCCURRED:System.NullReferenceException: Referencia a objeto no establecida como instancia de un objeto.
2014-10-20 11:16:45.4444    generic.EmberCore.BulkRename.dlgBulkRenamer    generic.EmberCore.BulkRename.dlgBulkRenamer.bwLoadInfo_DoWork    4    ERROR    bwLoadInfo_DoWork    "EXCEPTION OCCURRED:System.NullReferenceException: Referencia a objeto no establecida como instancia de un objeto.
2014-10-20 11:16:45.4834    generic.EmberCore.BulkRename.dlgBulkRenamer    generic.EmberCore.BulkRename.dlgBulkRenamer.bwLoadInfo_DoWork    4    ERROR    bwLoadInfo_DoWork    "EXCEPTION OCCURRED:System.NullReferenceException: Referencia a objeto no establecida como instancia de un objeto.
2014-10-20 11:16:45.5374    generic.EmberCore.BulkRename.dlgBulkRenamer    generic.EmberCore.BulkRename.dlgBulkRenamer.bwLoadInfo_DoWork    4    ERROR    bwLoadInfo_DoWork    "EXCEPTION OCCURRED:System.NullReferenceException: Referencia a objeto no establecida como instancia de un objeto.
2014-10-20 11:16:45.5814    generic.EmberCore.BulkRename.dlgBulkRenamer    generic.EmberCore.BulkRename.dlgBulkRenamer.bwLoadInfo_DoWork    4    ERROR    bwLoadInfo_DoWork    "EXCEPTION OCCURRED:System.NullReferenceException: Referencia a objeto no establecida como instancia de un objeto.
2014-10-20 11:16:45.6244    generic.EmberCore.BulkRename.dlgBulkRenamer    generic.EmberCore.BulkRename.dlgBulkRenamer.bwLoadInfo_DoWork    4    ERROR    bwLoadInfo_DoWork    "EXCEPTION OCCURRED:System.NullReferenceException: Referencia a objeto no establecida como instancia de un objeto.
2014-10-20 11:16:45.6715    generic.EmberCore.BulkRename.dlgBulkRenamer    generic.EmberCore.BulkRename.dlgBulkRenamer.bwLoadInfo_DoWork    4    ERROR    bwLoadInfo_DoWork    "EXCEPTION OCCURRED:System.NullReferenceException: Referencia a objeto no establecida como instancia de un objeto.
2014-10-20 11:16:45.7255    generic.EmberCore.BulkRename.dlgBulkRenamer    generic.EmberCore.BulkRename.dlgBulkRenamer.bwLoadInfo_DoWork    4    ERROR    bwLoadInfo_DoWork    "EXCEPTION OCCURRED:System.NullReferenceException: Referencia a objeto no establecida como instancia de un objeto.
2014-10-20 11:16:45.7695    generic.EmberCore.BulkRename.dlgBulkRenamer    generic.EmberCore.BulkRename.dlgBulkRenamer.bwLoadInfo_DoWork    4    ERROR    bwLoadInfo_DoWork    "EXCEPTION OCCURRED:System.NullReferenceException: Referencia a objeto no establecida como instancia de un objeto.
2014-10-20 11:16:45.8145    generic.EmberCore.BulkRename.dlgBulkRenamer    generic.EmberCore.BulkRename.dlgBulkRenamer.bwLoadInfo_DoWork    4    ERROR    bwLoadInfo_DoWork    "EXCEPTION OCCURRED:System.NullReferenceException: Referencia a objeto no establecida como instancia de un objeto.
2014-10-20 11:16:45.8575    generic.EmberCore.BulkRename.dlgBulkRenamer    generic.EmberCore.BulkRename.dlgBulkRenamer.bwLoadInfo_DoWork    4    ERROR    bwLoadInfo_DoWork    "EXCEPTION OCCURRED:System.NullReferenceException: Referencia a objeto no establecida como instancia de un objeto.
2014-10-20 11:16:45.9025    generic.EmberCore.BulkRename.dlgBulkRenamer    generic.EmberCore.BulkRename.dlgBulkRenamer.bwLoadInfo_DoWork    4    ERROR    bwLoadInfo_DoWork    "EXCEPTION OCCURRED:System.NullReferenceException: Referencia a objeto no establecida como instancia de un objeto.
2014-10-20 11:16:45.9495    generic.EmberCore.BulkRename.dlgBulkRenamer    generic.EmberCore.BulkRename.dlgBulkRenamer.bwLoadInfo_DoWork
(2014-10-20, 11:24)jtm010101 Wrote: [ -> ]
Thank you.
Bug found, i will fix it for the todays release.
DanCooper
Thanks for your work.
(2014-10-18, 20:10)AnthonyJS02 Wrote: [ -> ]Think I found a bug when using the theme downloader for movies. When you scrape and then there is no theme and you try to cancel to close window. It comes up with a Object Reference window and then Ember crashes.
It's fixed for next release.
DanCooper
No looks MPAA watching
<id TMDB="166822">tt1830713</id>
  <title>Big Ass Spider!</title>
  <originaltitle>Big Ass Spider!</originaltitle>
  <year>2013</year>
  <releasedate>18/10/2013</releasedate>
  <country>United States of America</country>
  <rating>5.4</rating>
  <votes>13</votes>
  <certification>USA:PG-13</certification>
  <genre>Ciencia Ficci├│n</genre>
  <studio>Epic Pictures Group</studio>
  <studio>Snowfort Pictures</studio>
  <director>Mike Mendez</director>
movie ---> Big Ass Spider
2014-10-20 11:58:42.7244    Ember_Media_Manager.frmMain    Ember_Media_Manager.frmMain.bwMovieScraper_DoWork    6    TRACE    Starting MOVIE scrape
2014-10-20 11:58:42.7244    Ember_Media_Manager.frmMain    Ember_Media_Manager.frmMain.bwMovieScraper_DoWork    6    TRACE    Start scraping: Brick Mansions (La Fortaleza)
2014-10-20 11:58:42.7774    EmberAPI.ModulesManager    EmberAPI.ModulesManager.RunGeneric    6    WARN    No generic modules defined <BeforeEditMovie>
2014-10-20 11:58:42.7774    EmberAPI.ModulesManager    EmberAPI.ModulesManager.ScrapeData_Movie    6    TRACE    Scraping movie data using <TMDB_Data>
2014-10-20 11:58:42.7774    ScraperModule.TMDB_Data    ScraperModule.TMDB_Data.Scraper    6    TRACE    Started TMDB Scraper
2014-10-20 11:58:42.7774    EmberAPI.clsAdvancedSettings    EmberAPI.clsAdvancedSettings.GetSetting    6    INFO    GetSetting    "EXCEPTION OCCURRED:System.NullReferenceException: Referencia a objeto no establecida como instancia de un objeto.
   en EmberAPI.clsAdvancedSettings.GetSetting(String key, String defvalue, String cAssembly, Content_Type cContent)*   en EmberAPI.clsAdvancedSettings.GetSetting(String key, String defvalue, String cAssembly, Content_Type cContent)"
2014-10-20 11:58:44.1615    ScraperModule.TMDB_Data    ScraperModule.TMDB_Data.Scraper    6    TRACE    Finished TMDB Scraper
2014-10-20 11:58:44.6095    EmberAPI.ModulesManager    EmberAPI.ModulesManager.RunGeneric    6    TRACE    Run generic module <Renamer>
2014-10-20 11:58:44.7545    EmberAPI.ModulesManager    EmberAPI.ModulesManager.RunGeneric    6    WARN    No generic modules defined <OnMovieNFOSave>
2014-10-20 11:58:45.0746    EmberAPI.ModulesManager    EmberAPI.ModulesManager.RunGeneric    6    WARN    No generic modules defined <MovieSync>
2014-10-20 11:58:45.0746    Ember_Media_Manager.frmMain    Ember_Media_Manager.frmMain.bwMovieScraper_DoWork    6    TRACE    Ended MOVIE scrape
2014-10-20 11:58:45.0746    EmberAPI.ModulesManager    EmberAPI.ModulesManager.RunGeneric    1    TRACE    Run generic module <Notifications>
2014-10-20 11:58:52.9700    EmberAPI.ModulesManager    EmberAPI.ModulesManager.RunGeneric    1    WARN    No generic modules defined <BeforeEditMovie>
2014-10-20 11:58:52.9920    EmberAPI.ModulesManager    EmberAPI.ModulesManager.RunGeneric    1    TRACE    Run generic module <Frame Extractor>
2014-10-20 11:59:27.7670    EmberAPI.Localization    EmberAPI.Localization.GetHelpString    1    INFO    GetHelpString
2014-10-20 11:59:27.7980    EmberAPI.Localization    EmberAPI.Localization.GetHelpString    1    INFO    GetHelpString
2014-10-20 11:59:27.8260    EmberAPI.clsAdvancedSettings    EmberAPI.clsAdvancedSettings.GetSetting    1    INFO    GetSetting    "EXCEPTION OCCURRED:System.NullReferenceException: Referencia a objeto no establecida como instancia de un objeto.
2014-10-20 11:59:27.8290    EmberAPI.Localization    EmberAPI.Localization.GetHelpString    1    INFO    GetHelpString
2014-10-20 11:59:27.8460    EmberAPI.clsAdvancedSettings    EmberAPI.clsAdvancedSettings.GetSetting    1    INFO    GetSetting    "EXCEPTION OCCURRED:System.NullReferenceException: Referencia a objeto no establecida como instancia de un objeto.
2014-10-20 11:59:27.8460    EmberAPI.Localization    EmberAPI.Localization.GetHelpString    1    INFO    GetHelpString
2014-10-20 11:59:27.8800    EmberAPI.clsAdvancedSettings    EmberAPI.clsAdvancedSettings.GetSetting    1    INFO    GetSetting    "EXCEPTION OCCURRED:System.NullReferenceException: Referencia a objeto no establecida como instancia de un objeto.
2014-10-20 11:59:27.8800    EmberAPI.Localization    EmberAPI.Localization.GetHelpString    1    INFO    GetHelpString
2014-10-20 11:59:27.8930    EmberAPI.Localization    EmberAPI.Localization.GetHelpString    1    INFO    GetHelpString
2014-10-20 11:59:27.9230    EmberAPI.clsAdvancedSettings    EmberAPI.clsAdvancedSettings.GetSetting    1    INFO    GetSetting    "EXCEPTION OCCURRED:System.NullReferenceException: Referencia a objeto no establecida como instancia de un objeto.
2014-10-20 11:59:27.9230    EmberAPI.Localization    EmberAPI.Localization.GetHelpString    1    INFO    GetHelpString
2014-10-20 11:59:27.9940    EmberAPI.clsAdvancedSettings    EmberAPI.clsAdvancedSettings.GetSetting    1    INFO    GetSetting    "EXCEPTION OCCURRED:System.NullReferenceException: Referencia a objeto no establecida como instancia de un objeto.
2014-10-20 11:59:27.9940    EmberAPI.Localization    EmberAPI.Localization.GetHelpString    1    INFO    GetHelpString
2014-10-20 11:59:28.0000    EmberAPI.Localization    EmberAPI.Localization.GetHelpString    1    INFO    GetHelpString
2014-10-20 11:59:28.0160    EmberAPI.clsAdvancedSettings    EmberAPI.clsAdvancedSettings.GetSetting    1    INFO    GetSetting    "EXCEPTION OCCURRED:System.NullReferenceException: Referencia a objeto no establecida como instancia de un objeto.
2014-10-20 11:59:28.0160    EmberAPI.Localization    EmberAPI.Localization.GetHelpString    1    INFO    GetHelpString
2014-10-20 11:59:28.0320    EmberAPI.Localization    EmberAPI.Localization.GetHelpString    1    INFO    GetHelpString
2014-10-20 11:59:28.0580    EmberAPI.Localization    EmberAPI.Localization.GetHelpString    1    INFO    GetHelpString
2014-10-20 11:59:28.0690    EmberAPI.Localization    EmberAPI.Localization.GetHelpString    1    INFO    GetHelpString
2014-10-20 11:59:28.0810    EmberAPI.Localization    EmberAPI.Localization.GetHelpString    1    INFO    GetHelpString
2014-10-20 11:59:28.1100    EmberAPI.clsAdvancedSettings    EmberAPI.clsAdvancedSettings.GetSetting    1    INFO    GetSetting    "EXCEPTION OCCURRED:System.NullReferenceException: Referencia a objeto no establecida como instancia de un objeto.
2014-10-20 11:59:28.1100    EmberAPI.Localization    EmberAPI.Localization.GetHelpString    1    INFO    GetHelpString
2014-10-20 11:59:28.1560    EmberAPI.Localization    EmberAPI.Localization.GetHelpString    1    INFO    GetHelpString
2014-10-20 11:59:28.1920    EmberAPI.Localization    EmberAPI.Localization.GetHelpString    1    INFO    GetHelpString
2014-10-20 11:59:28.2030    EmberAPI.Localization    EmberAPI.Localization.GetHelpString    1    INFO    GetHelpString
2014-10-20 11:59:28.3030    EmberAPI.clsAdvancedSettings    EmberAPI.clsAdvancedSettings.GetSetting    1    INFO    GetSetting    "EXCEPTION OCCURRED:System.NullReferenceException: Referencia a objeto no establecida como instancia de un objeto.
2014-10-20 11:59:28.3460    EmberAPI.Localization    EmberAPI.Localization.GetHelpString    1    INFO    GetHelpString
2014-10-20 11:59:28.3680    EmberAPI.Localization    EmberAPI.Localization.GetHelpString    1    INFO    GetHelpString
2014-10-20 11:59:28.3930    EmberAPI.Localization    EmberAPI.Localization.GetHelpString    1    INFO    GetHelpString
2014-10-20 11:59:28.4700    EmberAPI.Localization    EmberAPI.Localization.GetHelpString    1    INFO    GetHelpString
2014-10-20 11:59:28.4840    EmberAPI.Localization    EmberAPI.Localization.GetHelpString    1    INFO    GetHelpString
2014-10-20 11:59:28.5000    EmberAPI.Localization    EmberAPI.Localization.GetHelpString    1    INFO    GetHelpString
2014-10-20 11:59:28.5150    EmberAPI.Localization    EmberAPI.Localization.GetHelpString    1    INFO    GetHelpString
2014-10-20 11:59:28.5310    EmberAPI.Localization    EmberAPI.Localization.GetHelpString    1    INFO    GetHelpString
2014-10-20 11:59:28.6240    EmberAPI.Localization    EmberAPI.Localization.GetHelpString    1    INFO    GetHelpString
2014-10-20 11:59:28.6400    EmberAPI.Localization    EmberAPI.Localization.GetHelpString    1    INFO    GetHelpString
2014-10-20 12:00:16.2238    Ember_Media_Manager.frmMain    Ember_Media_Manager.frmMain.bwMovieScraper_DoWork    49    TRACE    Starting MOVIE scrape
2014-10-20 12:00:16.2238    Ember_Media_Manager.frmMain    Ember_Media_Manager.frmMain.bwMovieScraper_DoWork    49    TRACE    Start scraping: Brick Mansions (La Fortaleza)
2014-10-20 12:00:16.2728    EmberAPI.ModulesManager    EmberAPI.ModulesManager.RunGeneric    49    WARN    No generic modules defined <BeforeEditMovie>
2014-10-20 12:00:16.2728    EmberAPI.ModulesManager    EmberAPI.ModulesManager.ScrapeData_Movie    49    TRACE    Scraping movie data using <TMDB_Data>
2014-10-20 12:00:16.2728    ScraperModule.TMDB_Data    ScraperModule.TMDB_Data.Scraper    49    TRACE    Started TMDB Scraper
2014-10-20 12:00:18.2609    ScraperModule.TMDB_Data    ScraperModule.TMDB_Data.Scraper    49    TRACE    Finished TMDB Scraper
2014-10-20 12:00:18.4109    EmberAPI.ModulesManager    EmberAPI.ModulesManager.RunGeneric    49    TRACE    Run generic module <Renamer>
2014-10-20 12:00:18.5509    EmberAPI.ModulesManager    EmberAPI.ModulesManager.RunGeneric    49    WARN    No generic modules defined <OnMovieNFOSave>
2014-10-20 12:00:18.8369    EmberAPI.ModulesManager    EmberAPI.ModulesManager.RunGeneric    49    WARN    No generic modules defined <MovieSync>
2014-10-20 12:00:18.8369    Ember_Media_Manager.frmMain    Ember_Media_Manager.frmMain.bwMovieScraper_DoWork    49    TRACE    Ended MOVIE scrape
2014-10-20 12:00:18.8369    EmberAPI.ModulesManager    EmberAPI.ModulesManager.RunGeneric    1    TRACE    Run generic module <Notifications>
Is the TV show section still a work in progress?
The 'watched' function doesnt seem to be working for me, i.e. not writing 'playcount 1' into the nfo (it does for movies, just not for TV).
(2014-10-20, 12:08)jtm010101 Wrote: [ -> ]DanCooper
  <year>2013</year>
  <votes>13</votes>
This movie is not rated on IMDB: Link
(2014-10-20, 12:53)flekz Wrote: [ -> ]Is the TV show section still a work in progress?
The 'watched' function doesnt seem to be working for me, i.e. not writing 'playcount 1' into the nfo.
All parts of Ember are work in progress Wink
But watched works for me, playcount is writen to NFO if I change the state.
Edit: Sorry, it's working only in episodes. The Watched in season and show context menu does not working Big Grin
(2014-09-05, 13:19)cibu Wrote: [ -> ]I have a problem changing the values in "Bei der Sortierung ignorieren". Every change is followed by the error message "Der Wert 48 ist für Value ungültig. Value sollte zwischen 'minimum' und 'maximum' liegen. Parametername: Value " and the program shuts down.
Is there anything I can do about it?
This problem is still there. What can I do about it?
