2013-09-09, 13:50
2013-09-09, 13:53
Have you enabled the advance settings on the left side. ( http://xbmc.org/xbmc-13-gotham-april-and-may-cycles/ )
on a PC I push the remote to the left in the default skin, I am guessing there is a tab or something, you can choose a setting there and more options will show up.
2013-09-09, 14:06
(2013-09-09, 13:53)Saner Wrote: [ -> ]Have you enabled the advance settings on the left side. ( http://xbmc.org/xbmc-13-gotham-april-and-may-cycles/ )
wow.. thank you for the fast response and help. That worked
