2013-09-11, 20:19
Just bought a Denon Piccolo today because it has no CD player (who needs it in 2013 ??), and also because it's dlna (upnp) certified.
Music is playing great from Xbmc, sound is amasing, but, on some albums I've a nice error message on the Piccolo :
"File Format Error" (or something like that)
So, I checked into the Xbmc log, and saw what happens :
Xbmc sent the covert (in JPEG) to Piccolo, and as it just try to play it without checking the format, the error pops up.
If I "clean" the directory, then retry to play it, it's working (very !!!) well.
Is there any option to ask Xbmc to not send unsupported formats to client ?
(I didn't found anything useful for this case in system/parameters/upnp)
Some infos about version I used :
15:12:45 T:140260266235840 NOTICE: -----------------------------------------------------------------------
15:12:45 T:140260266235840 NOTICE: Starting XBMC (12.2 Git:20130502-32b1a5e), Platform: Linux (Debian GNU/Linux 7.1 (wheezy), 3.9.9 x86_64). Built on Jun 25 2013
15:12:45 T:140260266235840 NOTICE: special://xbmc/ is mapped to: /usr/local/share/xbmc
15:12:45 T:140260266235840 NOTICE: special://xbmcbin/ is mapped to: /usr/local/lib/xbmc
15:12:45 T:140260266235840 NOTICE: special://masterprofile/ is mapped to: /home/freevo/.xbmc/userdata
15:12:45 T:140260266235840 NOTICE: special://home/ is mapped to: /home/freevo/.xbmc
15:12:45 T:140260266235840 NOTICE: special://temp/ is mapped to: /home/freevo/.xbmc/temp
15:12:45 T:140260266235840 NOTICE: The executable running is: /usr/local/lib/xbmc/xbmc.bin
15:12:45 T:140260266235840 NOTICE: Local hostname: stargate
15:12:45 T:140260266235840 NOTICE: Log File is located: /home/freevo/.xbmc/temp/xbmc.log
Locally compiled Xbmc because as I use latest Nvidia drivers I patched like that :
Many thanks for your help
18:50:27 T:140259010414336 DEBUG: Preparing upnp object for item 'musicdb://2/214/?albumartistsonly=false'
18:50:27 T:140259010414336 DEBUG: Building didl for object 'musicdb://2/214/?albumartistsonly=false'
18:50:27 T:140259010414336 DEBUG: Returning UPnP response with 50 items out of 274 total matches
18:50:29 T:140259010414336 DEBUG: UPnP Translated id to 'musicdb://2/279/?albumartistsonly=false'
18:50:29 T:140259010414336 INFO: UPnP: Received Browse DirectChildren request for object 'musicdb://2/279/?albumartistsonly=false', with sort criteria +dc:title
18:50:29 T:140259010414336 DEBUG: GetAlbumsByWhere query: SELECT albumview.* FROM albumview WHERE albumview.idAlbum IN (SELECT song.idAlbum FROM song JOIN song_artist ON song.idSong = song_artist.idSong WHERE song_artist.idArtist = 279) OR albumview.idAlbum IN (SELECT album_artist.idAlbum FROM album_artist WHERE album_artist.idArtist = 279)
18:50:30 T:140259010414336 DEBUG: GetAlbumsByWhere - query took 132 ms
18:50:30 T:140259010414336 DEBUG: Album format left = [%B]
18:50:30 T:140259010414336 DEBUG: Album format right = [%A]
18:50:30 T:140259010414336 DEBUG: Building UPnP response with filter '@childCount,dc:creator,upnp:album,upnp:artist,res,res@protection,res@duration,res@size,upnp:albumArtURI,upnp:searchClass', starting @ 0 with 50 requested
18:50:30 T:140259010414336 DEBUG: Preparing upnp object for item 'musicdb://2/279/-1/?albumartistsonly=false&artistid=279'
18:50:30 T:140259010414336 DEBUG: Building didl for object 'musicdb://2/279/-1/?albumartistsonly=false&artistid=279'
18:50:30 T:140259010414336 DEBUG: Preparing upnp object for item 'musicdb://2/279/683/?albumartistsonly=false&artistid=279'
18:50:30 T:140259010414336 DEBUG: Building didl for object 'musicdb://2/279/683/?albumartistsonly=false&artistid=279'
18:50:30 T:140259010414336 DEBUG: Preparing upnp object for item 'musicdb://2/279/682/?albumartistsonly=false&artistid=279'
18:50:30 T:140259010414336 DEBUG: Building didl for object 'musicdb://2/279/682/?albumartistsonly=false&artistid=279'
18:50:30 T:140259010414336 DEBUG: Preparing upnp object for item 'musicdb://2/279/684/?albumartistsonly=false&artistid=279'
18:50:30 T:140259010414336 DEBUG: Building didl for object 'musicdb://2/279/684/?albumartistsonly=false&artistid=279'
18:50:30 T:140259010414336 DEBUG: Preparing upnp object for item 'musicdb://2/279/685/?albumartistsonly=false&artistid=279'
18:50:30 T:140259010414336 DEBUG: Building didl for object 'musicdb://2/279/685/?albumartistsonly=false&artistid=279'
18:50:30 T:140259010414336 DEBUG: Returning UPnP response with 5 items out of 5 total matches
18:50:44 T:140259010414336 DEBUG: Received request to serve '4DA32258B2AB0AF22A56646139256830/folder.jpg' = 'image://%2fnfs4exports%2fhome%2faudio%2fJe.Dis.Aime_M_1999%2ffolder.jpg/'
stargate:/home/xbmc/frodo# git diff
diff --git a/xbmc/Util.cpp b/xbmc/Util.cpp
index a503ee5..758da6d 100644
--- a/xbmc/Util.cpp
+++ b/xbmc/Util.cpp
@@ -1632,6 +1632,15 @@ bool CUtil::Command(const CStdStringArray& arrArgs, bool waitExit)
int n = 0;
if (child == 0)
+ if (!waitExit)
+ // fork again in order not to leave a zombie process
+ child = fork();
+ if (child == -1)
+ _exit(2);
+ else if (child != 0)
+ _exit(0);
close(0);
close(1);
close(2);
@@ -1646,7 +1655,7 @@ bool CUtil::Command(const CStdStringArray& arrArgs, bool waitExit)
else
- if (waitExit) waitpid(child, &n, 0);
+ waitpid(child, &n, 0);
return (waitExit) ? (WEXITSTATUS(n) == 0) : true;
diff --git a/xbmc/main/main.cpp b/xbmc/main/main.cpp
index 8fe4226..81181a0 100644
--- a/xbmc/main/main.cpp
+++ b/xbmc/main/main.cpp
@@ -66,13 +66,6 @@ int main(int argc, char* argv[])
if (setrlimit(RLIMIT_CORE, &rlim) == -1)
CLog::Log(LOGDEBUG, "Failed to set core size limit (%s)", strerror(errno));
#endif
- // Prevent child processes from becoming zombies on exit if not waited upon. See also Util::Command
- struct sigaction sa;
- memset(&sa, 0, sizeof(sa));
- sa.sa_flags = SA_NOCLDWAIT;
- sa.sa_handler = SIG_IGN;
- sigaction(SIGCHLD, &sa, NULL);
#endif
setlocale(LC_NUMERIC, "C");
g_advancedSettings.Initialize();
