You are saying that you don't have the 'Select Track' button available in the information screen?
(2014-04-16, 14:49)Samu-rai Wrote: [ -> ]You are saying that you don't have the 'Select Track' button available in the information screen?
No I have not found the key icon to select the poster fanart Discart etc ...
In my TV show menu I have a slider for display collection fanart. For my movies, I have smart playlists to separate 3D and non-3D movies and neither has the collection fanart selection. How do I get that to appear or how do I get that fanart background in smart playlist menus? I'd still like to see random movies in my Movies and 3D movies menus.
Hi
could it be possible to add an option / mod to have media case(movies in the set) in the set view. For example when I select a SET I can have the movies in that set in 3D or Normal I will like to know which is the 3D ....
it'll be very nice and usefull.
thanks.
(2014-04-16, 14:56)fabris74 Wrote: [ -> ] (2014-04-16, 14:49)Samu-rai Wrote: [ -> ]You are saying that you don't have the 'Select Track' button available in the information screen?
You should have two buttons for getting artwork, in the Movie title info page.
Get Thumb and
Get Fanart or whatever they are called in your language
See my screen shot
If you select
Get Thumb button you will have various options to choose from as shown in the screen shot below
If you select the
Get Fanart button from the Movie info page, you will only be shown different fanart background images you can choose from, as shown in the screen shot below
When also having the Artwork Downloader add-on installed. you can use the context menu on a Movie Title and use the
Get Logo/ClearArt - Solo Mode or
Get Logo/ClearArt - GUI Mode options
Hi
This is not strictly related to Aeon MQ5, but does anyone else also have issues with the Skin Widgets and recently added Movies ?
Sometimes when I add new movie titles some of them do not appear in the recently added area for Movies, yet other new titles do appear in there OK.
I haven't figured out why this might happen?
Cheers
(2014-04-16, 16:08)cw-kid Wrote: [ -> ]Hi
Cheers
How do you have them set to appear?
I think by default, the recently added movies are shown by the date the file was created.
So if you add a movie which was created some time ago, it won't show in the widgets.
You can change this behaviour in the advancedsettings.xml though.
(2014-04-16, 16:14)Samu-rai Wrote: [ -> ] (2014-04-16, 16:08)cw-kid Wrote: [ -> ]Hi
Cheers
Hi Samu-rai
Whatever the default settings are? where ever they are located? I've not changed any settings relating to this.
But your explanation sounds quite likely to be part of the issue.
Looking in the Skin Widget addon settings under Recent Items there are three options
1. Recent Items - ON
2. Only Unplayed and Unfinished - ON
3. Update each time you enter the home screen - OFF
(2014-04-16, 15:01)patseguin Wrote: [ -> ]In my TV show menu I have a slider for display collection fanart. For my movies, I have smart playlists to separate 3D and non-3D movies and neither has the collection fanart selection. How do I get that to appear or how do I get that fanart background in smart playlist menus? I'd still like to see random movies in my Movies and 3D movies menus.
No, that option doesn't exist for playlists.
A work around is to manually create a folder full of fanarts, and point the playlist to that folder via the 'Use multiple backgrounds' option.
(2014-04-16, 16:16)cw-kid Wrote: [ -> ]Hi Samu-rai
Yeah, you need to add a tag to advanced settings. I can't remember what it is off the top of my head.
I'll have a look when I get home and let you know.
Edit:
I think its:
<videolibrary>
<dateadded>0</dateadded>
</videolibrary>
I think this thread explains the situation:
http://forum.xbmc.org/showthread.php?tid=132867
"here is what is needed in the advancedsettings.xml. the '0' will return the sorting to when added to the library, as before."
<videolibrary>
</videolibrary>
Will give it a try see if it works?
(2014-04-16, 16:30)Samu-rai Wrote: [ -> ]Lol yeah. See my edit
I have added that line to my advancedsettings.xml file and rebooted the HTPC. I have then removed the movie title I was having issues with from the library. I then ran an update video library scan again and this time this particular movie title is now showing in the recently added area!
So looks like its now working, if it is I will be well happy as this issue has bugged me for ages.
Many thanks.
(2014-04-16, 16:24)Samu-rai Wrote: [ -> ][quote='patseguin' pid='1683606' dateline='1397653264']
Is it possible a folder like this might exist already since I get fanart backgrounds when I select discs?
Yep. Probably in the Artwork Organizer app_data folder.
