(2014-06-23, 11:18)megalodon Wrote: [ -> ] (2014-06-22, 19:30)craigey1 Wrote: [ -> ]Is there a way to reposition the disc art if it's just a single movie. I can move the disc art for moviesets, but just can't see what value needs to be changed to move the disc from behind the media case.
Never mind - found it!
Im trying to find this through the forum as well. My single discs need moving to the left slightly as they are off centre. Where did you find it in the rightlist.xml?
For solo disc
<control type="group"><!-- CDART VIDEO -->
<animation type="WindowOpen">
<effect type="slide" start="-100,0" end="0,0" time="500" delay="500" tween="cubic" easing="out"/>
<effect type="fade" start="0" end="100" time="500" delay="500"/>
</animation>
<animation type="Visible">
</animation>
<animation effect="fade" start="100" end="0" time="200">WindowClose</animation>
<animation type="Hidden">
<effect type="slide" start="0,0" end="-100,0" time="300" tween="cubic" easing="out"/>
<effect type="fade" start="100" end="0" time="200"/>
</animation>
<animation effect="slide" time="200" start="0,0" end="0,-20" tween="cubic" easing="out" condition="!Skin.HasSetting(norightlistvideocase)">Conditional</animation>
<visible>![IsEmpty(ListItem.Art(discart)) | Skin.HasSetting(norightlistdiscart) | SubString(ListItem.Path,videodb://movies/sets,left)] + Window.IsActive(25) + Control.IsVisible(9923)</visible>
<control type="image">
<posx>660</posx>
<posy>220</posy>
<width>130</width>
<height>130</height>
Obviously alter to affect left / right, up / down, size.
Mine is here so it matches where my set CDs go.
