(2013-10-14, 16:20)SystemCrash Wrote: [ -> ]Thank you very much for the Tip. Its worked very good.
But only on issue left. (In the linked thread, the same issue appears...but there arent any solution suggestion for it)
I´ve set up a smart playlist and added it to the main menu. The normal informations like Name, Cover, Storie etc are shown.
But if i open the folder wich contains the files. The folder is empty.
Did some have the final idea?
Thank you for the patience with me.
Sorry, I'm not sure what you mean.
Have you got some screen shots you could post?
(2013-10-14, 17:24)bwall244 Wrote: [ -> ]I am finding load time on some artwork to be getting slower and slower. Upon startup the posters for the tv and movie widgets first display as placeholders and then take 2-4 seconds to load. More importantly though when I go into TV shows (using logos) my fanart appears but the logos show blank quite often for up to 10-15 seconds.
That's not something I have experienced, and I've been using the skin for a couple of months. If the artwork has been cached properly, it should only take as long as XBMC can pull it from your hard drive.
Im sorry that i cant explain it better.
I hope with the screens now it will work.
With the normal acces on the tv shows. I can choose wich episode i want to watch.
But with the Smartlist after your tutorial link i only got empty lists.
Hoping you could follow me.
Thank you in advance.
(2013-10-06, 10:01)activate Wrote: [ -> ]Awesome stuff.
Is there any way to change this back to use the artist fanart, rather than the collage of artist pictures (in the background)? I find the collage to be a bit too noisy.
Hi everyone!
I was on Ace and extensivly using MQ5 now. Good job Marcos!
I have a small problem. I was changing the viewtype in Tv Shows and when selecting one, XBMC crashed. It was working well in right list, banners, etc.
But now, i am unable to go back in my TvSeries and crash XBMC instantly.
Anyone know where i can change a config file somewhere to Right list so i may be able to go back in my Tv Series?
thanks a bunch!
sly
(2013-10-14, 19:48)fnwc Wrote: [ -> ] (2013-10-06, 10:01)activate Wrote: [ -> ]Awesome stuff.
Go to the OSD Menu > Settings and you can change it from there. It looks nice but I also find a bit too "noisy"
I go for viewing to have a slideshow of the artist (whole). Loads of nice options there though.
Would someone try and confirm this bug for me? In showcase view with automatic panel, if I press up before the panel has dropped the system crashes.
brewer try pressing the menu button
Can i add video add-on icons to the main menu? I.E. Adding the "YouTube" icon to a "Streaming" menu on the homescreen
(2013-10-14, 23:27)Samu-rai Wrote: [ -> ]Would someone try and confirm this bug for me? In showcase view with automatic panel, if I press up before the panel has dropped the system crashes.
Nothing here. Works great. ( with 4sec delay)
(2013-10-15, 11:31)godson Wrote: [ -> ]Can i add video add-on icons to the main menu? I.E. Adding the "YouTube" icon to a "Streaming" menu on the homescreen
What do you mean by icon? A background?
(2013-10-15, 11:50)GuiZ Wrote: [ -> ] (2013-10-14, 23:27)Samu-rai Wrote: [ -> ]Would someone try and confirm this bug for me? In showcase view with automatic panel, if I press up before the panel has dropped the system crashes.
OK. I'll check how many seconds I have it set too as that may be a factor. It just seems strange as it happens every single time.
(2013-10-07, 14:20)iiixtream Wrote: [ -> ]Great skin and super fast. Love all the reworks and all the sub-menu options. This skin is truly amazing. Only problem I come across is when using the Pandora plug-in after about 2 or 3 songs I get stuck in a constant loop and can't get out. It just keeps changing songs every time I hit esc. The same happened in ace but not in other skins. This makes the wife angry then see calls me at work to complain. Thanks for this wonderful skin and all that has contributed.
does anyone know how to fix this. Any help would be great.
(2013-10-15, 13:14)Samu-rai Wrote: [ -> ][quote='godson' pid='1528201' dateline='1381829493']
(2013-10-15, 11:50)GuiZ Wrote: [ -> ][quote='Samu-rai' pid='1527890' dateline='1381786041']
Samurai i got it to work - thanks.
Another question - is it possible to have a Movies and Kids Movies?
I.E. Movies showing all my bluray stuff only and then Kids Movies showing all kids-friendly movies only. I've got them sorted in different folders. Only issue is i still haven't worked out how to do it or is it is possible.
I would like both to have the widgets: i.e. recently added movies etc.
(2013-10-15, 14:40)godson Wrote: [ -> ] (2013-10-15, 13:14)Samu-rai Wrote: [ -> ][quote='godson' pid='1528201' dateline='1381829493']
Try this by Samu-rai:
http://forum.xbmc.org/showthread.php?tid=150934
I use Smart Playlists to accomplish exactly what you are trying to do, it is real easy if you already have the Media in separate folders.
(2013-10-14, 17:54)Samu-rai Wrote: [ -> ] (2013-10-14, 16:20)SystemCrash Wrote: [ -> ]Thank you very much for the Tip. Its worked very good.
Do you have any thoughts on how I can diagnose this issue? I am correct in thinking Logoart is stored local to XBMC and not local to the media correct?
