Is there any option to change the colour of the titles?
I mean , when i see all my movie's folders , in the upper left side of the screen , there is the title of each movie or Tv Show , in white colour.
Can i change this colour and how?
Thanks for your attention .................
No, title in top corner is white, only.
(2013-10-18, 00:58)MarcosQui Wrote: [ -> ]No, title in top corner is white, only.
OK Marcos , and thanks for your answer ............
(2013-10-18, 09:42)SALAMINOMACHOS Wrote: [ -> ] (2013-10-18, 00:58)MarcosQui Wrote: [ -> ]No, title in top corner is white, only.
Use logo instead. Much cooler
Thank's Marcos,
look forward to getting the update
(2013-10-16, 01:16)MarcosQui Wrote: [ -> ]Aeon MQ 5 - 1.4.4 PRE-RC3 - Available in Google Drive - FOR TEST ONLY - only who has access
Changelog:
Added: Button to access Artwork Downloader script in Context Menu - Solo mode and Gui Mode.
Added: Support to Video Extras script - access by Video Info window.
Added: Watched Flag Selector - Including style and color selector.
Added: ShowArt view - Support to episodes.
Added: CleartLogo and ClearArt - Support to Season level and Episodes level.
Added: 3D Wall view - Watched Flag.
Added: RCB - Auto instalation.
Added: RCB - Multiplex view.
Added: Button to reset the default settings - Just re-apply major settings, is not a full reset.
Added: Video Furniture - option to show full, partial or hidden mode.
Improved: Multiplex view - Layout details.
Changed: Banner view - Removed dimmer.
Changed: Logo and Clearart in full screen mode to prevent missing art.
Fixed: LandScapeX view - Missing information in panel.
Fixed: trakt script/Context menu - layout details.
Fixed: Showcase view/Flat mode - Uniform size of posters.
Fixed: Weather Window - Missing buttons in top menu.
Fixed: Missing Rating Flag in some cases. (thanks to CutSickAss)
Fixed: Weather Widgets - Layout details in mode Weekend or 36 hour.
To put an end in long issue of 'watched label' in this version I have includes a selector, is possible choose style and set the color of the label.
Among other things I also includes a new button that makes the Re-configuration manually, it solves small problems and avoid having to do a full reset of the skin.
This version has the self-reconfiguration, so you'll have to redo some adjustments.
Have to say this is a near-perfect Skin. Well done guys on all your hard work.
Only two things that i would say that requires improvements:
1 - customizing the OSD icons: would be excellent if you had the ability to change this
2 - changing the loading/buffering message (which i think are displayed on the top left). Right now it is red and in lower-case which doesn't fit with the skin.
But apart from that well done guys.
Whats the videos extra script?
(2013-10-18, 09:55)Samu-rai Wrote: [ -> ] (2013-10-18, 09:42)SALAMINOMACHOS Wrote: [ -> ] (2013-10-18, 00:58)MarcosQui Wrote: [ -> ]No, title in top corner is white, only.
Can you please give me , more specific instructions?
How can i use these logos?
Where can i find them?
Skank, for info about how work video extras, look here:
http://forum.xbmc.org/showthread.php?tid=125024
Script you get here
https://robwebset.googlecode.com/svn/rel...-0.0.1.zip
Or install repo developer robwebset for get latest release videoextras script
http://robwebset.googlecode.com/svn/rele...-1.0.0.zip
This is really just DvdExtras with the Movie Themes removed as this is now covered by the latest TvTunes.
There is a small change which I think prevents some sound-loss when using it with the latest TvTunes (Actually backing out a previous work-around)
Please remove DvDExtras if you are going to use this.
About dvdextras, look here
http://wiki.xbmc.org/index.php?title=Add-on:DVD_Extras
Script associate extras (stunts, trailers, alternative versions and others extra videos to a movie/TV show title)
In info video have button for extras
and result list list extras items
Create folder extras, and put files there, for XBMC don´t scraper use this in advancedsettings.xml
<video>
<excludefromscan>
<regexp>-extras-</regexp>
<regexp>/Extras/</regexp>
<regexp>Extras</regexp>
<regexp>/extras/</regexp>
<regexp>extras</regexp>
<regexp>-trailer</regexp>
<regexp>[\\/]Extras[\\/]</regexp>
<regexp>[\\/]extras[\\/]</regexp>
</excludefromscan>
<excludetvshowsfromscan>
</excludetvshowsfromscan>
</video>
(2013-10-18, 13:42)SALAMINOMACHOS Wrote: [ -> ] (2013-10-18, 09:55)Samu-rai Wrote: [ -> ] (2013-10-18, 09:42)SALAMINOMACHOS Wrote: [ -> ]OK Marcos , and thanks for your answer ............
You need to have the logos downloaded first.
If you haven't got these already, you need to run artwork downloader.
In library view, move to the top menu and on the third column select Artwork Downloader - Auto Mode.
Once you have the logos downloaded, go to the top menu again and choose 'use logos instead of title'. I think this is on the third column from the left again.
I have a problem with coverflow under TVShows. the same thing happens with ace for me.
I scroll from left to the right side there is a jump from one show to the other show. The image jumping a little bit up and goes down. But from the right to the left side it goes well.
@ Samu-rai
Thanks a lot for the info
I'll try it.
Is it only me or the skin doesn't support local files "disc.png" and "clearart.png" in the skin?
To see the CD thing, the only way is to grab it from Artwork Downloader... If I already have the local files ready, it never uses them....
I have all local file:
But if I force to get them in XBMC (using the addon I presume):
sfnetwork, it´s default in XBMC frodo and gotham, for show arts like disc.png and clearart, it´s necessary always run ArtWork Downloader It only stores the links in the database and then xbmc caches them on the local disk. If you enable local files (addon setting) it will download them to the movie folders and then xbmc still caches the files to local disk. If don´t have link in database don´t show.
(2013-10-18, 17:44)Wanilton Wrote: [ -> ]sfnetwork, it´s default in XBMC frodo and gotham, for show arts like disc.png and clearart, it´s necessary always run ArtWork Downloader It only stores the links in the database and then xbmc caches them on the local disk. If you enable local files it will download them to the movie folders and then xbmc still caches the files to local disk.
ah, ok, thanks... Good to know..
Is there a way to link existing local artwork to database without grabbing them again on Internet? (during library scans)
