Frodo work better, no necessary, any fix, it´s fine. Check if you have script extended info installed, only for gotham users is necessary fixes in script for work.
(2013-10-02, 05:36)Wanilton Wrote: [ -> ]Frodo work better, no necessary, any fix, it´s fine. Check if you have script extended info installed, only for gotham users is necessary fixes in script for work.
OK I Will check.
Umm how do i run the script?
Its OK got it working... THANKS FOR YOUR HELP!!
(2013-10-02, 00:43)MarcosQui Wrote: [ -> ]@TrailFoX works fine in Frodo:
Try run Artwork downloader again. Top menu in auto mode.
done, but the downloader putt´s the logos in the main (root) folder and they dont show up,
only if i putt the logo in the session folder from the tv show the coming up crazy
Please please give the option for media cases in TV SHOWS WALL VIEW...like you have it in Mq3 and Mq4
Hey Marcos,
just checked your latest baby MQ5 and played with it about an hour...
From what I can tell: AWESOME! You got me back to use AEON MQ again!
The skin has a few elements that I missed since V2.2 and a lot of improvements! Also speed is incredible on my machine...
Maybe I need a few tweaks for myself
One request though:
Is it possible to show only the cover of the current playing album in home menu while playing music. So cover instead of artist slideshow? That option would be superb
cheers,
mad-max
Marcos, theres a slight design problem with the trakt.tv context menu..
I posted a picture on the brasilian forum
(2013-10-02, 09:10)TrailFoX Wrote: [ -> ] (2013-10-02, 00:43)MarcosQui Wrote: [ -> ]@TrailFoX works fine in Frodo:
Hmm I tried running AWD again and still nothing (movie logos and Cleararts work in pause/info menu) but not TV Shows. WEIRD!
I'm using 12.2 frodo too.
Aeon MQ 5 - 1.3.0 RC2 - available in Google Drive (for those who have access) - Frodo and Gotham
Changelog:
Added: Greek Fonts. (thanks to CutSickAss)
Added: TvTunes script - Button in Video Info to get Movie Themes and Tv Show Themes/solo mode.
Added: Widgets - Option to set between 4/8 or 12 itens.
Added: Season info for all List views.
Fixed: Widgets for Next Aired and Favourites are not displayed correctly.
Fixed: Music/submenu - Clean Library and Update Library.
Fixed: Multiplex view - Uniform size of posters.
Fixed: Showcase view - Layout details in panel info for TvShow and Season.
Fixed: Typo in Variables/Music Genres Fanart - (thanks to Cocotus)
Fixed: Main Menu Settings/Info Panel - Missing info panel if activate Clean Mode.
Improved: Watched flag and Scroll Bar - Skin respects the color used in color selector.
Improved: Font used in main menu - Skin respects the font style used in main menu/widget title/playback time.
Changed: TvTunes - is activated by default.
Changed: TvTunes - removed the button for get themes within the collection.
This version has auto-reconfiguration, so maybe you may need to redo some adjustments.
Soon this update will be open to all users.
(2013-10-02, 09:43)mad-max Wrote: [ -> ]Hey Marcos,
One request though:
cheers,
mad-max
Hello my old friend. I'm glad in read this, thank you.
About your request, not is possible, no have place to this, would that change the layout.
(2013-10-02, 10:28)Skank Wrote: [ -> ]Marcos, theres a slight design problem with the trakt.tv context menu..
Everything is ok here, again I think you are using a skin nonstandard 16:9.
you had me at movie sets..
awesome! trying this as soon as i get home
(2013-10-02, 16:39)MarcosQui Wrote: [ -> ] (2013-10-02, 09:43)mad-max Wrote: [ -> ]Hey Marcos,
One request though:
cheers,
mad-max
great work with new RC!
strange nonstandard skin? im just using your skin, i dunno why its not visible, ill check my settings
installed latest. thank you MQ + team
Only thing I can say is "WOW!"
But 2 questions:
- I use music without database mode. Here I can't change viewmode (by name, by date etc.).
Can you change this?
- I have "view lyrics" activated, but also hear very often remixes.
Can you build in that the lyrics windows disappears then automatically if no lyrics are found?
Thankz 4 this fantastic skin!
