Full Version: [RELEASE] Aeon MQ 5
Aeon MQ 5 - 2.0.2 - 2/7/2013 - Available in oficial repo for XBMC Frodo and XBMC Gotham
Full Changelog - online
WHAT'S NEW IN AEON MQ 5?
REPLACE MENU
Right now you can forget everything that you ever saw about main menu customization.
In Aeon MQ 5 the new resource REPLACE do not only do the reorganization of the items but also do it as a complete integration betwen menu and submenu.
You can change any item of your submenu directly to the main menu or the reverse operation, this is the dream of any user.
The reorder as it is know on Aeon MQ 4 is also available. However is much better and simpler to use.
CLONE SUBMENU
Besides being able to reorganize the submenu in however way you like, you can also personalize this submenu with the items that you want or then clone other items in any other submenu.
Create a Playlist menu and clone the Movies submenu in just a few seconds, all very simple and effective.
SUBMENU AND MORE SUBMENUS
The Aeon MQ 5 holds all the submenus in an individual way, the total number of supported submenus is bigger than 2400 itens!
Each menu has its own set of submenus, some menus allow up to 20 customizable submenus.
MAIN MENU PRESETS
Organize the main menu the way you wish, then save these settings as a preset. Reorder the main menu for your wife or your kids and save it as another preset.
You can also arrange a menu fully optimized for video, one for music and so on, you can have up to 10 presets independently of each other.
So with just two clicks you can switch between the pre-saved settings, very fast and convenient.
REORDER MENU
A resource from Aeon MQ 4, now even more powerful and easier to use. You can create a totally customized menu of your personal way.
Which menu do you want to put as the main focus? Movies, Series, or any other? In Aeon MQ 5 you can do whatever you want.
MY MENU 1 and MENU 2
Now you have got the double of items to customize, every My Menu supports a total of 12 items.
Dozens of menus scattered around? Not anymore!
Concentrate all your Playlists or emulators in a single list.
THE SUPER SKIN THAT WORKS LIKE A LITE SKIN
The Aeon MQ 5 uses in the base the Ace Skin code, with this was possible to include many resources in the code without sacrificing performance.
The Aeon MQ 5 has a performance a lot superior compared to its predecessor Aeon MQ 4.
EXTRA PACKAGE
Would not be great to acquire all the themes, background images for the weather, icons and logotypes with only a click?
In Aeon MQ 5 this actually exists, you download only one package and gain access to all the extra package.
NEW STANDARD THEME
Rubro, is the name of the new theme. New background images with red colors for a impacting visual.
Besides the new theme, trough the extra package you still have 5 other themes available or can create your own theme.
THEMES ROTATION
It is possible to upload a different theme each time the skin is initiated, with a different appearence and unique images.
WIDGETS FOR MOVIES AND MUCH MORE
There are 12 newer items, random or in progress for Movies, Tv shows, Music Videos, Music and Playlists.
Now you also have widgets for Next Aired Episodes, to Favorite items and also for your most played games.
REFORMULATED VIEWS
The Aeon MQ 5 has more than 15 types of views for collections.
All underwent a makeover (since skin Ace) and now pratically all have support to Set of films, including the display of up to 10 disc art per set, plus other improvements.
The result is a faster navegation, with a cleaner and fresh visual.
QUIOSQUE SMART
It makes the TOP MENU accessible with the basic functions and hides all aptions of adjustments.
QUIOSQUE CODE
Disables temporarily the quiosque mode using a sequency of pre defined comands.
More convenience for everyone that wish to protect the adjustments inside the collections without the need to change it.
SIMPLE NAVEGATION
Using the arrows left/right you can regress ou avance to a window or comand, is really simple to operate Aeon MQ 5.
COLORS AND TRANSPARENCIES
A new color picker to the main menu and other parts of the skin with 23 samples available to choose, you can now also set the level of transparency for panels, main menu and also to the bar of media flags.
STYLE SELECTOR
It became much easier to choose a style, navigate between the types available and choose the one you like the best.
SOURCES SELECTOR
You can choose a new font for the main menu regardless of the style or theme, much more customization with base on your personal taste.
MEDIA CASE SELECTOR
Customize the your case by your own way, define what you want to use for each type of media.
AND MANY OTHER NEWS AT THE SKIN...
AEON MQ 5, YOU HAVE NEVER SAW A SKIN LIKE THIS.
AEON MQ 5 ALBUM
watch gallery
ALBUM BY SAMU-RAI
watch gallery
SUPPORTED SCRIPTS (AUTOMATIC INSTALLATION)
Aeon MQ 5 extrapack by malte, Wanilton, MarcosQui
Advanced Launcher by Angelscry - http://forum.xbmc.org/showthread.php?tid=85724
Artist Slideshow by ronie/kyleejohnson (pkscuot) - http://forum.xbmc.org/showthread.php?tid=124880
Artwork Downloader by Martijn - http://forum.xbmc.org/showthread.php?tid=114633
CU LRC Lyrics by Taxigps|ronie - http://forum.xbmc.org/showthread.php?tid...tid=126495
Favourites script by ronie|`Black - http://forum.xbmc.org/showthread.php?tid=114671
Random and Last items script by MikeBZH44, Martijn - http://forum.xbmc.org/showthread.php?tid=122448
Rom Collection Browser by carabalb, jimyx17, malte, redkiller - http://forum.xbmc.org/showthread.php?tid=70115
Skin Widgets by Martijn - http://forum.xbmc.org/showthread.php?tid=142389
TV Show - Next Aired by Ppic, Frost, ronie, `Black - http://forum.xbmc.org/showthread.php?tid=79493
Video Language Script by `Black - http://forum.xbmc.org/showthread.php?tid=155693
XBMC Subtitles by amet, mr_blobby - http://forum.xbmc.org/showthread.php?tid=126495
SUPPORTED SCRIPTS (MANUAL INSTALLATION)
Artwork Organizer by ronie - http://forum.xbmc.org/showthread.php?tid=109304
cdART Manager by Giftie - http://forum.xbmc.org/showthread.php?tid=77031
Cinema Experience by nuka1195-giftie-ackbarr - http://forum.xbmc.org/showthread.php?tid=87563
ExtendedInfo Script by phil65 - http://forum.xbmc.org/showthread.php?tid=160558
Global Search by ronie - http://forum.xbmc.org/showthread.php?tid=109301
Library Editor Script by phil65 - http://forum.xbmc.org/showthread.php?tid=158775
Metadata Actors by Frost (passion-xbmc.org) - http://forum.xbmc.org/showthread.php?tid=123578
TvTunes by Ppic, Frost, ronie - http://forum.xbmc.org/showthread.php?tid=83925
trakt.tv by rectifyer - http://forum.xbmc.org/showthread.php?tid...t=trakt.tv
Video Extras by rob_webset - http://wiki.xbmc.org/index.php?title=Add-on:VideoExtras
THANKS AND CREDITS:
Translation and support coordinator: Wanilton
International relationships and assistance: Samu-rai
Translators: Arabic - kim1406© - Bulgarian - alex95sv© - Catalan - mrfloffy© - Chinese - taxigps© - Croatian - mitaok© - Czech - Fery© - Danish - tenzion©, denver99(T) - Dutch - schumi2004©, Skank(T) - Finnish - hatiac© - French - GuiZ©, Mati24(T) - Galician - xurxo© - German - janusreith©, zawaponga s(T), Ash(T) - Greek - CutSickAss© - Hebrew - BuSHari© , yakirp88(T) , dhead666(T) - Hindi - amanker© - Hungarian - attilazsigus©, pulse117(T) - Icelandic - passer© - Italian - peppe_sr©, Simzer0(T) - Japanese - shaolin© - Korean - piodio© - Lithuanian - ArtX38© - Norwegian - magnusalex© - Polish - Etharr© - Portuguese - nelsonamen© , Pingo.Mister(T) - Romanian - sergiocos© - Russian - SergeiAK© - Slovenian - tadej© - Spanish - terratec© - Spanish (Argentina) - LinkinStg© - Spanish (Mexico) - Palalisimo© - Swedish - thedarer© JohNan(T) - Thai - devilshura© - Ukrainian - Godfazzer© - Vietnamese - dukevn©, tess_vn(T)
Super special thanks: To all the people who believed in my work and collaborated in some way to make this project possible. To all of you, thank you from my heart.
The Original Aeon Skin and its name are intelectual property of djh_. The Aeon MQ 5 however has a independent code and does not use any texture of Original Aeon. A big thanks to the master djh_ for creating the masterpiece that is original Aeon.
Congratulations MarcosQui, awesome job again, as always still the best skin!
I just had to do a double take, because when I saw the title, I could not believe my eyes! You've done a great job. Honestly. The interface is so clean and smooth yet more options are available. Great skin. I echo Wanilton. Congrats.
I was testing this skin with Gotham since a few weeks and i must say ii's by far the best skin i ever used (and i used *A LOT* of skins). More, it's incredibly fast and really an huge improvement upon AEON MQ4. I can even say it's nothing comparable to AEON MQ4, it's like a brand new, shiny and gorgeous skin, with absolutely all the whistles and the bells that XBMC can brings.
So, thanks a million for this incredible piece of work MarcosQui!
Thanks for this fine release.
So lets start with the suggestions:
1.the NR (not rated) Movie Flag is missing.
2. the movie Posters should all have the same size, stretch when necessary would be nice.
3. when movie file name contains "AC3D" ( i have some of those) the 3D icon is displayed, but these are not 3D Movies.
4. HDDVD is showing DVD flag
still testing.....
Was by chance I came and looked in here today, awesome work! The menus feel a lot quicker to use for me, and it looks fantastic!
Just a little thing: with Gotham, widgets for video playlist doesn't seem to work, message: script failed, random and last items (or maybe i'm doing something wrong)
How do I access view types? I can't get there from either movies or tv, also the default fonts seem just a hair too small but that might be my old eyes
double post
(2013-09-28, 22:00)macrho Wrote: [ -> ]How do I access view types? I can't get there from either movies or tv, also the default fonts seem just a hair too small but that might be my old eyes
Double tap up, like you would to view trailers in MQ4, I had to figure that out as well.
(2013-09-28, 20:01)Wanilton Wrote: [ -> ]Congratulations MarcosQui, awesome job again, as always still the best skin!
Come on , we all know ,you are creating the skins together.
Anyway many THANKS .....................
P.S Very important
In View options/Change View , there is one option only.
Poster View and others , like in Ace Skin , are missing......
Have been waiting for this. Great work. Loving it so far. Thank you!!
Looking nice I switched to Nox when MQ was pretty much unuseable with Frodo but the shiny glass look of MQ looks so nice.
Trying to get back in to the different style now Wink
stupid question, is there any way to create your own submenu?
whilst in view options/change view..push up and then up again to get a screen to enable/disable the additional views
