I have a 6400k APU, governor is ondemand, so current frequency is 1.8ghz.
My cpu is at 10-12% with xbmc idle. Why is this? With the default xbmc (on debian) cpu was at 1% with algorithmdirtyregions=3 and nofliptimeout=0.
Also, my cpu usage is high when playing movies. (40-60%), did I do something wrong? I'm running XBMC 12.3 with the PPAs listed here and 3.13.0 kernel
might help to post some logs...
also, you should be running Gotham = XBMC 13.xxx -- also on the first post.
1% -- wow!!! is that even possible?
@Jarlakxen: You did at least not follow the howto concerning your username. Did you set all permissions correctly?
I see lots of unplayable items in your home directory. Even the mp4 file that gets "half" opened, does not want to open vdpau at all.
(2014-02-02, 05:50)deivid Wrote: [ -> ]I have a 6400k APU, governor is ondemand, so current frequency is 1.8ghz.
Check the "Keep Audio alive" and your Vsync settings. Ah and 12.3 is totally wrong.
(2014-02-01, 18:28)locomot1f Wrote: [ -> ]@schnappi -- question, are you using passthrough?
i believe this is a known issue with linux + passthrough
i too am having the same issues.
after fiddeling around with mplayer and alsa I hope to be on the right path.
please try the following. maybe it is a problem according power management found on
http://wiki.ubuntuusers.de/Soundkarten_k...edirect=no
sudo echo 0 | sudo tee /sys/module/snd_hda_intel/parameters/power_save
sudo echo N | sudo tee /sys/module/snd_hda_intel/parameters/power_save_controller
(2014-02-02, 09:30)fritsch Wrote: [ -> ] (2014-02-02, 05:50)deivid Wrote: [ -> ]I have a 6400k APU, governor is ondemand, so current frequency is 1.8ghz.
You are right. It was Gothal alpha 11 or 12 I can't remember. Gonna check that, thanks.
wsnipex. Bravo. The update today with mesa 10.02 (from 10.1) and driver and xbmc, so far, seems to have really improved PQ and occasional microjudders on 1080i 29.97 h.264 happague-hdpvr playback. Playback looks VERY good now. Thank you.
@wsnipex: will the test branch be reverted back to 10.1 devel when they get the looping issue fixed?
(2014-02-03, 17:08)wsnipex Wrote: [ -> ] (2014-02-03, 16:33)libgradev Wrote: [ -> ]@wsnipex: will the test branch be reverted back to 10.1 devel when they get the looping issue fixed?
if needed
what is the status of that issue?
do you need more logs?
is there anything i (we) can do to help?
if needed
It's just for the MPEG-2 issues with my card (which were improving, if not yet fixed, under 10.1 dev)
Pssst, don't tell anyone:
http://sprunge.us/geNf
Before:
Quote:VDPAU implementation : G3DVL VDPAU Driver Shared Library version 1.0
FATAL: get_bits failed : No backend implementation could be loaded.!!
MPEG DECODING (1920x1080): 60 frames/s
MPEG DECODING (1280x720): 85 frames/s
H264 DECODING (1920x1080): 33 frames/s
H264 DECODING (1280x720): 61 frames/s
Profile unsupported.
MPEG4 DECODING (1920x1080): 45 frames/s
MIXER WEAVE (1920x1080): 301 frames/s
MIXER BOB (1920x1080): 511 fields/s
MIXER TEMPORAL (1920x1080): 144 fields/s
MIXER TEMPORAL + IVTC (1920x1080): 139 fields/s
MIXER TEMPORAL + SKIP_CHROMA (1920x1080): 153 fields/s
MIXER TEMPORAL_SPATIAL (1920x1080): 147 fields/s
MIXER TEMPORAL_SPATIAL + IVTC (1920x1080): 140 fields/s
MIXER TEMPORAL_SPATIAL + SKIP_CHROMA (1920x1080): 155 fields/s
MIXER TEMPORAL_SPATIAL (720x576 video to 1920x1080 display): 252 fields/s
MULTITHREADED MPEG DECODING (1920x1080): 20 frames/s
MULTITHREADED MIXER TEMPORAL (1920x1080): 138 fields/s
After:
Quote:AMD A4-5000 APU with Radeon HD Graphics
Unknown GPU
VDPAU API version : 1
MPEG DECODING (1920x1080): 110 frames/s
MPEG DECODING (1280x720): 244 frames/s
H264 DECODING (1920x1080): 44 frames/s
H264 DECODING (1280x720): 115 frames/s
MPEG4 DECODING (1920x1080): 69 frames/s
MIXER BOB (1920x1080): 509 fields/s
MIXER TEMPORAL (1920x1080): 142 fields/s
MIXER TEMPORAL + IVTC (1920x1080): 142 fields/s
MIXER TEMPORAL + SKIP_CHROMA (1920x1080): 155 fields/s
MIXER TEMPORAL_SPATIAL (1920x1080): 141 fields/s
MIXER TEMPORAL_SPATIAL + IVTC (1920x1080): 138 fields/s
MIXER TEMPORAL_SPATIAL + SKIP_CHROMA (1920x1080): 158 fields/s
MULTITHREADED MPEG DECODING (1920x1080): 24 frames/s
MULTITHREADED MIXER TEMPORAL (1920x1080): 137 fields/s
1080p60 works now!!!
1080p50 also
That's brilliant - I tested on my Kabini.
Samples:
https://dl.dropboxusercontent.com/u/5572...f-HDTV.mkv
https://dl.dropboxusercontent.com/u/5572...recode.mkv
(2014-02-03, 21:49)fritsch Wrote: [ -> ]Pssst, don't tell anyone: http://sprunge.us/geNf
Before:
After:
Unknown GPU
1080p50 also
Samples:
@Fritch: Firstly thank you for the excellent howto. How would I go about applying this patch?
Before:
After:
Unknown GPU
1080p50 also
Samples:
WOW - blooming impressive bit of work
