Cool! Great work, again. I'm starting repeating myself here.
gradinaruvasile
yeah I forgot that I had to add a line break at the end, so that the patch doesn't end unexpectedly.
Thanks again @
fritsch and ckoenig for fixing it right away
according to the launchpad page:
=== Using VDPAU/XvMC accelerated video ===
Supported XvMC drivers: softpipe, r300, r600, radeonsi, nouveau
Supported VDPAU drivers: softpipe, r300, r600, radeonsi, nouveau
how do I know that I'm using the radeonsi drivers? is there an *. so file for that or is this the default? for the /XvMCConfig file?
i see the entries in /usr/lib/dri for all except radeonsi -- this is why i ask.
I don't compile myself, thus I'm on the "official" track.
Today I updated Xorg, now white screen if VDPAU and Mixer are ON, but the video plays if only Mixer is ON
I'm with official releases, waiting for the new Mesa, installed yesterday and noticed big improvement to response in guy and low CPU usage. Vdpau give white or green screen.
In the mean time, can the OP update the kernel with aufs support too? Its not enabled, I was using it to join multiple HDs.
PPA updates are currently building… won't be very long now
@nihues: no - if you have advanced needs, that go beyond standard Ubuntu kernel config, you have to build yourself.
@all: There was another build problem in mesa, which got fixed two mins ago - so fabio needs to rebuild the ppa again.
While testing the 3.12rc4 kernel from the ArchLinux AUR (
https://aur.archlinux.org/packages/linux-mainline) I noticed some increase in frame drops/skips, especially with 1080i content. dmesg reports that while playing videos the gpu perfomance class sticks to "uvd_hd", while with the 3.11.4 repo kernel it sticks to "uvd". Clocks seem quite different:
$ dmesg | grep -i uvd
[ 1.839809] [drm] UVD initialized successfully.
[ 1.902422] internal class: uvd_hd
[ 1.902428] uvd vclk: 38824 dclk: 30000
[ 1.902439] internal class: uvd
[ 1.902445] uvd vclk: 55000 dclk: 41250
Same while running qvdpautest, so obviously there is quite a difference too:
3.11.4 repo kernel:
qvdpautest 0.5.2
AMD E-450 APU with Radeon(tm) HD Graphics
Unknown GPU
VDPAU API version : 1
VDPAU implementation : G3DVL VDPAU Driver Shared Library version 1.0
MPEG DECODING (1920x1080): 60 frames/s
MPEG DECODING (1280x720): 92 frames/s
H264 DECODING (1920x1080): 38 frames/s
H264 DECODING (1280x720): 70 frames/s
MPEG4 DECODING (1920x1080): 52 frames/s
MIXER WEAVE (1920x1080): 301 frames/s
MIXER BOB (1920x1080): 502 fields/s
MIXER TEMPORAL (1920x1080): 593 fields/s
MIXER TEMPORAL + IVTC (1920x1080): 593 fields/s
MIXER TEMPORAL + SKIP_CHROMA (1920x1080): 592 fields/s
MIXER TEMPORAL_SPATIAL (1920x1080): 593 fields/s
MIXER TEMPORAL_SPATIAL + IVTC (1920x1080): 593 fields/s
MIXER TEMPORAL_SPATIAL + SKIP_CHROMA (1920x1080): 592 fields/s
MIXER TEMPORAL_SPATIAL (720x576 video to 1920x1080 display): 713 fields/s
MULTITHREADED MPEG DECODING (1920x1080): 58 frames/s
MULTITHREADED MIXER TEMPORAL (1920x1080): 602 fields/s
3.12rc4 kernel:
qvdpautest 0.5.2
Unknown GPU
MPEG DECODING (1920x1080): 41 frames/s
MPEG DECODING (1280x720): 63 frames/s
H264 DECODING (1920x1080): 27 frames/s
H264 DECODING (1280x720): 49 frames/s
MPEG4 DECODING (1920x1080): 37 frames/s
MIXER WEAVE (1920x1080): 302 frames/s
MIXER BOB (1920x1080): 503 fields/s
MIXER TEMPORAL (1920x1080): 594 fields/s
MIXER TEMPORAL + SKIP_CHROMA (1920x1080): 594 fields/s
MIXER TEMPORAL_SPATIAL (1920x1080): 594 fields/s
MIXER TEMPORAL_SPATIAL + IVTC (1920x1080): 594 fields/s
MIXER TEMPORAL_SPATIAL + SKIP_CHROMA (1920x1080): 594 fields/s
MULTITHREADED MPEG DECODING (1920x1080): 43 frames/s
MULTITHREADED MIXER TEMPORAL (1920x1080): 415 fields/s
Does anybody know what's going on? Why does the rc kernel stick to the lower performance class? Both kernels have the HDA and CEA patches applied, if that matters. It's actually not a big deal right now, since with the 3.11 kernel xbmc works smooth as butter. I'm just curious.
There is a reason I tell to use 3.11.
3.12-rc4 has a bug, that does not go to the max UVD clock, which is not fixed yet.
Thank you, I was just testing around, not blaming you for anything
Did not assume so :-) All fine for my part.
(2013-10-11, 18:49)fritsch Wrote: [ -> ]@nihues: no - if you have advanced needs, that go beyond standard Ubuntu kernel config, you have to build yourself.
But I was using the standard kernel. I was thinking this was a modified kernel config. And aufs is in kernel not patched or anything.
Thanks anyway
That's indeed a vanilla kernel with Ubuntu kernel config. I did not like that the ubuntu guys need ages to port pointreleases to their saucy kernel tree... but i can in deed build the normal ubuntu git source in the future, would be even easier to maintain, as I can use git.
