Full Version: Radeon OSS with vdpau (howto)
(2014-06-08, 14:59)wsnipex Wrote: [ -> ]you might not have realized it, but this is NOT a Xbmc problem. Its broken SDL packages in most distros
I forgot to mention,
opensuse 13.1 has sdl 1.2.15 - this is the version mentioned in post 1. So I should not need to set this -bs - right?
(2014-06-08, 15:03)fritsch Wrote: [ -> ]To add:
For mpeg-4 I have now posted alone 5 times in this thread, that mpeg-4 hw decoding has something to do with luck, there are a whole lot different encodings out there - just disable it in expert settings.
Nobody has forced you to use opensuse, but don't make your OS incapabilities to xbmc's
thanks for the mp4 info. sorry to hear that its so difficult. will it ever be fixed completely?
on the opensuse-issue:
which incapabilities? the HD-sound not working? As I said it worked in the alpha12 days. Do you still think it is an opensuse problem?
The other 2 problems (tearing, mp4): If I understood that correct, they appear also on ubuntu.
and on the "nobody forced you to" issue:
some people like to stick to distros they are used to - at least I am, since I use suse since more than 10 years.
I really just hoped that xbmc 13.0 would work with r600/vdpau, but I guess I´ll have to wait until xbmc14. and as I said, I appreciate your hard work and don´t want to sound unthankful.
(2014-06-07, 21:02)fritsch Wrote: [ -> ]You should better use alpha software.
Quote:[ 24.679] (==) RADEON(0): Backing store enabled
See the init script from post 1.
Thanks, it worked.
Why is this?
Distributions have fucked it up - we need to workaround it :-)
And the 3.15 kernel is released.
Yeah, revert the offending commit and rebuild - it's a very good kernel overall.
Edit: We do the same in OpenELEC: https://github.com/OpenELEC/OpenELEC.tv/...fc5b804f28
will do, git pulling as i type. Smile
btw. use: install kernel-package, use ubunut config, make oldconfig and use make-kpkg to build 3.15 images and then upload them :-) just use append-to-version="amdfixes1" or something and revision 1.0
Thanks in advance :-)
Now building Smile
EDIT: arghh the VM ran out of room.
EDIT: standby, checking something.
Hai today after long waiting i did a new install on ubuntu 14.04 , i was running ubuntu 12.04 with xbmc xbva, which was running great, but now it is really bad.
here are my logs
http://paste.ubuntu.com/7619487/
http://paste.ubuntu.com/7619491/
http://paste.ubuntu.com/7619492/
http://paste.ubuntu.com/7619493/
http://paste.ubuntu.com/7619495/
is someone can look in to this, that would be great.
install is done as exact what the howto tells me.
The mesa repo is not installed.
For some reason im getting only low resolutions ( 1400x1050 ) or something.
Very slow screen movement..
i did the same install at a friend of mine, and there its working great.
what did i miss??
grrrrrrrrrrrrrr
Quote:acpi=off noapic nolapic bootdegraded=1 apparmor=0 nomodeset quiet splash nomdmonddf nomdmonisw
Are you kidding me?
sorry.. just found the nomodeset...
(oeps) big sorry..
and without : acpi=off noapic nolapic i dont have keyboard after the ubuntu install.
don't turn acpi off, really don't the apic is okay if you don't need it - but don't keep acpi turned off.
You know the difference between acpi and apic? You should.
and.. hdmi dropped out on the back.. it's a "that kind" of Monday...
Now, its all ok again, thank you for the very quick reply fritsch...
